ABM 338 Switchboard: Functions, Connections, Sliding Gate (Voltage, Ground, Photocell, OPN, CIR)
DARFFF 21570 9
How do I wire the ABM 338 board photocell, OPN and cir inputs, and what do these terminals do for opening and closing a sliding gate?
Wire the photocells by powering them from +15V and GND, then connect the photocell signal contact between PHOTO and GND; the input is a dry-contact/short-circuit signal, and when the beam is broken during closing the gate stops and reverses/opening [#18217994][#19473726] OPN is the keyboard input, and cir is the manual open/close button input [#18383527] The control inputs work by shorting contacts rather than applying 12 V, and one user reported open/stop/close behavior on the numbered terminals when they are shorted to GND [#18216264] DIP switch 4 controls obstacle detection and it works only when switch 4 is OFF; DIP switches 2 and 3 set automatic closing to disabled, 5 s, 10 s, or 20 s [#18383527] If the photocell action is reversed, change the MOTOR ROTATION switch and reset the limit switches [#19688562]
  • #1 18176717
    DARFFF
    Rate: 25
    Does anyone know what these functions are for?
    +15V - voltage 15V
    GND - ground
    Photo - photocell
    OPN - ? (probably opening)
    cir - ? (perhaps cycle)
    circulation button - ?
    jumper - two limit one - ?
    Motor rotation - left or right
    Remote coding button:
    1s coding
    12s delete
    Potentiometer - closing force
    DP switches
    1 - soft start
    2, 3 - automatic closing
    4 - obstacle
    Connect the photocell to +15 V and GND and back to Photo and GND?
    GND is common to all (Photo, OPN, cir) output and input?
    If I give a 12 V impulse under OPN and GND, the gate will open?
    How can I close it again?
    • ABM 338 Switchboard: Functions, Connections, Sliding Gate (Voltage, Ground, Photocell, OPN, CIR) 20190919_112503.jpg (1.34 MB) You must be logged in to download this attachment.
    • ABM 338 Switchboard: Functions, Connections, Sliding Gate (Voltage, Ground, Photocell, OPN, CIR) 20190918_202230.jpg (4.44 MB) You must be logged in to download this attachment.
    • ABM 338 Switchboard: Functions, Connections, Sliding Gate (Voltage, Ground, Photocell, OPN, CIR) 20190918_202216.jpg (3.25 MB) You must be logged in to download this attachment.
  • #2 18216264
    marbakMB
    Rate: 14
    Thank you very much for posting pictures with English descriptions. I bought a machine and I have a plate - the same symbol - but the descriptions are only in Chinese.
    I'm having trouble connecting the photocells. By trial and error - a short circuit on terminals 2(GND)-5 is a manual opening. They operate on a short-circuit principle: 1 - opening, 2 - stop, 3 - closing, possibly 4 also stop.
    The first terminal description +15V has 18V, and between GND - the other 3, 4, 5 - there is +5V.
    I wanted to use the old photocells, maybe 12? - 24V, but they don't want to work on +15V power supply - they don't pop at the break. Have you figured out how to connect the photocells?
    I also have an old receiver with Nice remote controls, I wanted to connect additionally, I also did not find where, especially in Chinese.
    Or maybe you need to move this circulation jumper how are the photocells supposed to work?
  • #3 18217994
    marbakMB
    Rate: 14
    I had broken photocells, I connected new ones. + 15 and GND - terminals 1 and 2 from the left -> are for powering the photocells, and 2 and 3 - GND and photo - for sending the disconnection signal from the photocells. If an obstacle appears during closing, the gate reverses. I haven't changed anything with the jumpers yet. Maybe someone will find this information useful.
  • #4 18316789
    Brunocap
    Qualcuno ha uno schema dettagliato dei collegamenti?
    Non mi blocca il cancello passando davanti alle photocellule.
    Translation:
    Does anyone have a detailed wiring diagram?
    The gate does not block my passage in front of the photocells.
    ABM 338 Switchboard: Functions, Connections, Sliding Gate (Voltage, Ground, Photocell, OPN, CIR) ABM 338 Switchboard: Functions, Connections, Sliding Gate (Voltage, Ground, Photocell, OPN, CIR)
    Dalle foto si vede dei contatti saldati storti pu? dipendere da quello?
    Limit two e one che cosa ??
    Translation:
    From the photos you can see some crooked welded contacts or it may depend on it?
    Limit two and one, what is it?
  • #5 18317535
    marbakMB
    Rate: 14
    Photo from left -> terminals (1; 2) + 15; GND - >> (+ 15V; 0V) - photocell nr1 power supply ( + photocells are connected by 2 wires between each other)
    terminals (2; 3) GND; Photo - >> (0V; + 5V) - photocell signal - short circuit
  • #6 18383527
    DARFFF
    Rate: 25
    circulatian - button - manual opening closing
    DP switches
    1 - soft start
    2.3 - automatic closing (5,10,20s description on the board)
    2 off 3 off - disabled
    2 on 3 off - 5s
    2 off 3 on - 10s
    2 on 3 on - 20s
    4 - obstruction (works when DP 4 is OFF) does not work when the switch is ON. There is also a dependence on how the MOTOR ROTATION switch is set - it works when closing and does not work when opening and vice versa it works when opening and does not work when closing.
    OPN - keyboard
  • #7 18851806
    bk82
    Rate: 14
    Does anyone have instructions on how to code the above driver? I would like the gate to only work with one button. i.e. open-stop-close etc.
  • #8 18886256
    wertu123
    Has anyone solved the problem of connecting photocells to work as an obstacle? Now I installed this control panel and I have the same problem.
  • #9 19473726
    neon78
    Rate: 16
    Does anyone have a diagram of how to connect these photos?
    Close-up of a gate controller board with colored wires connected to terminals. Circuit board with connected wires of various colors.
    I have, I already fell quite by accident, connected according to the instructions, then bridge pin 3com to 1 (-) looking from the left. Set the jumper to no.
    Close-up of the inside of a photocell showing electronic components and connected wires.
    In the control panel, we connect No. 4 from the photocell to Photo and it works, but only when closing. When we cut the photocell, the gate stops and starts to open.
  • #10 19688562
    wirgin
    Help: 19
    Rate: 46
    Wiring diagram for connecting photocells to a control board.
    Photocell connection diagram:
    Wiring diagram of photocells in a 220V electric sliding door system.
    If the gate movement works in the opposite way when we cover the photocells - move the switch marked on the diagram (turnsforward and backward) and set the limit switches again (change up/down).
✨ The discussion revolves around the functions and connections of the ABM 338 switchboard, specifically addressing the terminals for voltage (+15V), ground (GND), photocell (Photo), and operational controls (OPN, CIR). Users share their experiences with connecting photocells, troubleshooting issues, and understanding the wiring diagrams. Key functionalities include manual opening/closing, soft start, automatic closing, and obstacle detection. The importance of jumper settings and the role of limit switches in controlling gate movement are also highlighted. Several users seek detailed wiring diagrams and solutions for integrating photocells effectively.
