Seeking ABM338 Sliding Gate Control Board or Repair Tips After Impact Damage
andruelectricgates04 1581 4
  • #1 20884249
    Hi everyone, I am looking for a control board for an ABM338 SLIDING, or if there is any way that I can repair mine, this would help as well.
    My gate opens but will not close. It was hit by the pedestrian gate. Any help will do.
  • #2 20884717
    xury
    Automation specialist
    Help: 878
    Rate: 1494
    Check your photocells circuit.
  • #3 20885615
    Darek0026
    Help: 224
    Rate: 382
    Hi, could you show any Photo of broken cuntrol board? Cuntrol board show some message or LED blinking combintion? In my opinion you should try to turn off photocels.
  • #4 20894682
    I have removed photocells completely from the system with no changes, so I am looking for a replacement control board.
  • #5 20895048
    kotbury
    Gantry automation specialist
    Help: 2096
    Rate: 3619
    Short terminal GND with input PHOTO and test. if the gate starts closing, you have faulty photocells or their cables.
    What do you mean?
    If it was collision gate with obstactle - check a relay connected to the motor output "CLOSE", maybe relay is damaged.
