Correct Connection for FAAC 740 Gate Automation with Closing Photocells: Wiring Diagram and Guide
piomar93 14169 3
  • #1 16478130
    piomar93
    Rate: 14
    Hello gentlemen!
    I have to do two automation for FAAC 740 gates. If I add the option - connecting a pair of closing photocells, have I made the connections correctly. I add a scheme in which I virtually connected the system.
    albino
    Help: 83
    Rate: 95
    This way it will work properly when closing.
  • #3 19516948
    Brcg
    albino wrote:
    This way it will work properly when shutting down.
    Is the jumper between negative and stop correct?
    There is no such thing on any of the diagrams?
  • #4 19517029
    kotbury
    Gantry automation specialist
    Help: 2104
    Rate: 3639
    It is in diagram 4.
    This input is open from the minus side to permanently block the drive.
    It is useful for a safety switch (red "mushroom" - sometimes required) or for blocking the entire gate, if the built-in wicket is open (it happens). If you do not have the above mentioned gear - jumper.
