Discord Mic Detection Issue: Audio Pickup Without Voice, Plus Image Sharing Failure
Qlik123 44535 5
  • #1 18180814
    Qlik123
    Hello, I have a problem with the microphone in discord, only in this app. TS3 and skype work without a problem, in the discord it detects the microphone and checks that the microphone works. Discord is picking up audio, but private and group calls don't work. Also, the image does not work while sharing.
  • #2 18189294
    rafald83r
    Rate: 15
    Are you an admin? If not then it may be a question of your permissions on this server :-)
    Added after 8 [minutes]:
    In addition, you can also:
    Remove and install Discord again.
    If this does not help, and you have the option, install discord on another computer and check the microphone on it.
  • #3 18190648
    Qlik123
    I'm an admin, I have permissions
    Reinstall the discord already, and the microphone works, because I normally use it on TS3
  • #4 18491384
    gufi24
    Rate: 38
    I have the same problem, did you find the solution?
  • #5 18701870
    Cosmo21
    Do you have a solution to the same problem?
  • #6 18701996
    gufi24
    Rate: 38
    It solved itself only after some update.
