[Solved] Discord Microphone Issue on Win10: Mic Works in Other Apps, Tried Reinstallation - Any Solutions?
Kadojam 34923 2
  • #1 18714947
    Kadojam
    Rate: 45
    As in the topic in the discord application on win 10, the microphone does not work, although the system itself shows the use of the microphone by discord. the microphone is working properly in other applications. I've already tried such basics as reinstallation ... Anyone had a similar problem?
    Kon36
    Rate: 15
    Check in the Control Panel if you are not muted by accident.
  • #3 18716496
    Kadojam
    Rate: 45
    It works, thanks ... weird that it worked in other programs
