[Solved] LG 32LF510U: Seeking Newer Software Version Beyond 05/03/45 for Blue Dominant Image Issue
kazikszach 35967 4
  • #1 18196042
    kazikszach
    Help: 513
    Rate: 1100
    TV as in the title, blue picture.
    This is the third LG TV with a similar damage, they are connected by the software used in them, it is the version 5/3/45 and on the official LG website only the older 05/03/37 is available.
    Does anyone have newer software than the factory installed on 05/03/45 and will it help with this fault?
    badael
    Help: 136
    Rate: 207
    Led diodes are not good on this LG series.
    robokop
    Help: 1762
    Rate: 6359
    As above - backlight failure - damaged LEDs are blue instead of white.
    VINZA
    Help: 49
    Rate: 163
    replace the led bars, you can buy them here:https://it.aliexpress.com/item/33000633421.html?spm=a2g0s.9042311.0.0.27424c4do5qjbv
  • #5 18197509
    kazikszach
    Help: 513
    Rate: 1100
    In fact, blue light can be seen through the holes.
    Another LG sell with a production date of January 2016.
    Thank you for the hints, I was confused by the youth of these TV sets.
