  • #1 14440855
    cosmin-daniel
    Hi, I have the same problem, do you please specify in English if possible, if you resolve that?
    And how come?
    Thanks in advance
    PS- I replaced the t-con module but it is the same....
  • #3 14529449
    cosmindaniel
    Ha, finally I resolve that. I put some sponge between metal housing and ribbon electrical circuit of the display.
    Now I have the very good image.
    This defect is very popular due to shock, or those circuits are not stuck very well and gives because of the heat given off by lamps.
    So good luck with your tv......
  • #4 16151231
    cosmin-daniel
    I resolve the problem with a little piece of sponge.......hahahaha, easy and fancy...
  • #5 16151281
