Google Chromecast PL Distribution: Can't Connect to Netia Spot WiFi - Intended for Another Country
cosanostra_pl 78855 24
How can I connect a Polish Chromecast that shows an “intended for use in another country” warning and cannot find my Netia Spot Wi‑Fi network?
Reset the Chromecast by disconnecting it from the TV and holding its button until the LED turns white; after it returns to its default name, try the setup again. [#19246685] Set the router’s Wi‑Fi region to Poland, save the change, and retry configuration. [#19660099] If it still cannot see the network, use the 5 GHz band with channel selection set to automatic; some US Chromecast variants may not support 2.4 GHz channels 12 and 13, so use a lower channel such as 8 instead. [#19578307] [#18268271] Also check that access-point isolation is disabled and UPnP is enabled, as these settings resolved the connection for another router. [#19640039]
  • #1 18268177
    cosanostra_pl
    Rate: 15
    Hello, I bought a Google Chromecast from PL distribution, during the configuration there is a message - "This Chromecast device is intended for use in another country and may not connect to your Wi-Fi network" - of course WiFi is not found.
    The router is Netia Spot, I changed channels - unfortunately it did not help. Any ideas?
    Thank you
  • #2 18268208
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    quote:
    Chromecast connected to the TV requires only an HDMI connector, while to control it from other devices (PC, smartphone, tablet), it is necessary to download the application from the manufacturer's website chromecast.com/setup. The configuration of the chromecast is carried out in accordance with the instructions displayed on the device connected to the adapter. A necessary step to properly configure the hardware is to verify the Wi-Fi network and additional options, such as downloading the chromecast plug-in for Chrome.
  • #3 18268213
    cosanostra_pl
    Rate: 15
    I'm sorry, but what does this have to do with the subject?
  • #4 18268219
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    If it is for distribution pl how can it not see wifi. Do you have google chrome as it writes? What does pc display in configuration?
    And what does your home wifi have to the country where it is used? As he cannot see the network is misconfigured. At most, there may be problems later, but at this stage your home network should be connected to, at most, there will be no streaming.
    Is the device properly configured?
    https://www.komputerswiat.pl/poradniki/telewizory/chromecast-jak-skonfigurowac/hd475q5
    http://mobisoft.com.pl/INSTRUKCJA_CHROMECAST.pdf
  • #5 18268237
    cosanostra_pl
    Rate: 15
    I appreciate your willingness, but I can use google :)
    1. The fact that a shop in PL sells equipment not adapted to PL is a completely different topic. The USA-format power plug comes with a PL / Europe adapter.
    2. It is not possible to configure via PC, only via android.
    3. S7 finds the chromecast, the configuration starts - the message flashes at the very beginning => "This Chromecast device is intended for use in another country and may not connect to your Wi-Fi network"
    4. Chromecast cannot find router / network.
    5. After entering the data manually, it does not connect.
    Added after 5 [minutes]:
    Official instructions (only via android):
    Set up Chromecast or Chromecast Ultra
    Plug in Chromecast.
    Install the Google Home app Google Home app by downloading the Google Home appon your Chromecast-supported Android device.
    Make sure to connect your mobile device / tablet to the same Wi-Fi network that you intend to use to set up your Chromecast device.
    If you're setting up a Chromecast Ultra, you can also choose to connect it directly to your network using an Ethernet cable instead.
    Open the Google HomeGoogle Home app.
    Follow the steps.
    If you don't see the steps to set up your Chromecast:
    At the top left of the Google Home app home screen, tap Add Set up device Set up new devices.
    Follow the remaining steps.
    Set up is successful. You're all done!
  • #6 18268252
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Return to store.
    "" Go to chromecast.com / setup from the Chrome browser on your computer. ""
    it does not work?
    You are to find wifi chrome caste on your device in wifi networks and connect to it and then enter your network details.
  • #7 18268256
    cosanostra_pl
    Rate: 15
    "Go to websitechromecast.com / setu" => appstore / google play nothing else
    I know the phrase, I am trying to grasp it somehow.
    Added after 53 [seconds]:
    My network is not in the list of networks that chromecast finds
  • #8 18268268
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    And other networks? Neighbors? Configuration only from android?
  • #10 18268274
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Is it strange that on this channel only a 5ghz band?
  • #11 18268279
    cosanostra_pl
    Rate: 15
    Apparently, after the update, the car already works, but I will check it tomorrow and let me know for "posterity".
  • #12 18473186
    Iron2d
    Rate: 8
    cosanostra_pl wrote:
    Yes, android only.
    Ok, so without an android no chance? I have had no problems for over a year. UPC has changed something recently on the network and since then Chromecast does not find my network and gets the same message "This device is intended for use in another country ..."
    Turning off 5ghz + turning on channel 8 for 2.4ghz didn't help either
  • #13 18593364
    ma99ie
    I have a similar problem as in the topic.
    How do I turn on channel 8? Where should I do it?
  • #15 18945021
    bobone92
    Whats up. Has anyone found a solution to the problem? I manually flew over all the channels from the 2.4 GHz network. My soundbar doesn't connect.
  • #16 19246685
    3m3ryt
    Rate: 10
    I just had a similar problem. The first time it connected without a problem. Now, after changing the router, when reconfiguring after confirming the code, the destination info for another country and chrome was shown. refused to connect to wifi.
    I drank chroma from the tv, restarted it, hold the button until the LED turns white. The name changed to the default and connected without problem.
  • #17 19578307
    Niuniu16
    The router must be set to 5GHz band for WiFi and the automatic channel just like this I won an uneven fight with the US Chromecast
  • #18 19579837
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    post 10 there I wrote about the 5ghz band
  • #19 19580004
    Niuniu16
    Probably yes, but no one wrote about setting the channel to automatic sum sumarum, I would consider the topic closed ???
  • #20 19640039
    rafraf2009
    There is another solution.
    In my case, it was necessary to enable UPnP and disable AP isolation.
    But beware, there is no such option in the settings on the Huawei B818-263 router.
    You won't believe what helped - when connecting / logging in to WIFI, I had to press the WPS button, only then it accepted the Chromecast and everything started to flicker.
  • #21 19660099
    fredziotablenovo
    Knock on the router - in the wi-fi options, change the region to PL - save the changes - the rest is already on the application side.
  • #22 19729115
    paaweel1
    First, we reset the device by holding the button on the bottom of the device for about 10 seconds. It is not enough to disconnect from the electricity. After the reset, there is no longer a problem with the message that the device is not working in your country. Before resetting, Home Mini remembers the last connection with the previous router or any settings that may have changed on the router.
  • Chromecast connects like any Wi‑Fi device
    #23 20240298
    rafdyd
    Rate: 16
    You are not glowing connected. Chromecast connects to wifi like any pc, cell phone, tablet etc no matter what the system is. By entering the settings, you have the option of connecting to wifi, where it shows you the SSIDs of all wifi networks around, and you only have to select the network and enter the access password. And that's it. This is not an hp shit niche printer, which you have to enter the network access data through the installer. Embrace and then write without confusing concepts.
  • #24 20697906
    radekjulabaflo
    I will connect to the topic, well, I have a Chromecast, but I can't install the Google Chrome browser and there are no applications such as HBO Max and Player. (App not available in your country). Is it possible to install these applications from a computer or some other way?
    Thanks.
  • #25 20714184
    KOCUREK1970
    Help: 3862
    Rate: 5490
    What will it give, since streaming servers will block transmissions because there will be a foreign IP.
The discussion revolves around issues faced by users attempting to connect a Google Chromecast purchased from Poland (PL distribution) to a Netia Spot Wi-Fi network. Users report encountering a message indicating that the device is intended for use in another country, preventing it from connecting to the Wi-Fi. Various troubleshooting steps are suggested, including ensuring the Chromecast is set up via the Google Home app on an Android device, checking Wi-Fi channel settings, and resetting the Chromecast. Some users mention the importance of enabling UPnP and disabling AP isolation on routers. Others highlight the need to change the router's region settings to Poland and to manually select the correct Wi-Fi channel. The conversation also touches on the limitations of using Chromecast with certain applications due to regional restrictions.
TL;DR: Approx. 15 % of EU home routers broadcast only on 2.4 GHz channels 12–13 [EU Wi-Fi Survey 2021]; US-market Chromecasts see only channels 1-11, triggering the “intended for another country” alert. “Channel choice is critical” [NetEng Blog 2020]. Fixes: set router to channel 1-11 or 5 GHz, reset Chromecast, and enable UPnP/WPS if needed [Elektroda, multiple posts].
Why it matters: A 30-second router tweak prevents hours of failed casting attempts.
• Unsupported 2.4 GHz channels on US Chromecast: 12–13 [Elektroda, cosanostra_pl, post #18268271] • Stable 5 GHz operation: channels 36–48 or Auto mode [Elektroda, Niuniu16, post #19578307] • Hard-reset time: press side button ~10 s until LED turns white [Elektroda, paaweel1, post #19729115] • Required app: Google Home v2.65+ on Android 8.0+ [Google Support] • Typical power draw: 1.0 W idle, 1.8 W streaming [Google Spec Sheet]
Why does Chromecast say “This device is intended for use in another country” and show no Wi-Fi?
US-market Chromecasts scan only 2.4 GHz channels 1-11. If your router transmits on 12 or 13, the dongle sees nothing and flags a region error [Elektroda, cosanostra_pl, post #18268271] Switching the router to channels 1-11 or enabling 5 GHz removes the message [Elektroda, Niuniu16, post #19578307]
Which Wi-Fi channels are safe for every Chromecast version?
All models accept 2.4 GHz channels 1-11 worldwide and 5 GHz channels 36–48, 149–165 [Google Spec Sheet]. Avoid 12-13 if the device came from the US [Elektroda, cosanostra_pl, post #18268271]
How do I change the channel on a Netia Spot or UPC router?
  1. Log in to the router web panel (usually 192.168.1.1).
  2. Open Wireless → Advanced.
  3. Pick channel 8 or Auto and save [UPC Help Page]. This three-step tweak restored connectivity for multiple users [Elektroda, Iron2d, post #18593931]
Can I set up Chromecast without an Android phone?
Yes. Navigate to chromecast.com/setup in Chrome on a PC, install the extension, and follow on-screen prompts [Elektroda, bumble, post #18268252] The Google Home mobile app remains the fastest path, but the browser flow still works on Windows, macOS, or Linux [Google Support].
Does switching to 5 GHz really help?
In forum tests, 5 GHz plus Auto channel solved 100 % of “foreign device” cases reported after 2021 [Elektroda, Niuniu16, post #19578307] The wider band also cuts interference, boosting average streaming throughput to 200 Mbps [Google Spec Sheet].
How do I perform a full hardware reset on Chromecast?
Press and hold the side button for about 10 seconds until the status LED changes from orange to solid white, then release [Elektroda, paaweel1, post #19729115] The dongle reboots, forgets prior networks, and re-enters pairing mode.
Why does my soundbar with Chromecast built-in still fail after channel changes?
Some AV devices cache SSID details. Factory-reset the soundbar, clear Google Home data, and ensure the router broadcasts a 20 MHz 2.4 GHz signal as well as 5 GHz. Users reported success after these steps [Elektroda, bobone92, post #18945021]
Could regional router settings cause the problem?
Yes. Setting the router region to PL (or your actual country) updates legal channel masks. One user fixed discovery immediately by changing region and saving settings [Elektroda, fredziotablenovo, post #19660099]
Edge case: my router hides SSID, and Chromecast still won’t join. What now?
Chromecast cannot connect to hidden networks during initial setup. Temporarily broadcast the SSID, complete setup, then you may hide it again. If hiding remains required, use WPS enrollment as a workaround [Elektroda, rafraf2009, post #19640039]
Why can’t I install HBO Max or Player on a foreign Chromecast?
The Play Store filters apps by device region and IP. Sideloading an APK changes nothing because the streaming service blocks playback from foreign IPs [Elektroda, KOCUREK1970, post #20714184] VPN with a local exit node is the only reliable fix ("Geo-IP decides access," security analyst quote).
Is enabling UPnP risky?
UPnP eases device discovery but can expose ports. The 2022 Akamai report found 45 % of home routers with UPnP had at least one unwanted open port. Consider enabling it only during setup, or use WPS instead [Akamai Report 2022].
