Best Conduit Options for YDYp 3x2.5 Cable: Floor Installation & PESZEL SELF-EXHAUSTING FI
pimis 53001 14
What conduit size should I use for a YDYp 3x2.5 cable installed in the floor?
Use a Peszel corrugated conduit fi 22/18 for YDYp 3x2.5 in the floor; the main rule is that the cable should fit without being tight so it can be pulled out and replaced later [#18275979][#18275908][#18276044] The old rule of thumb mentioned was that the conduit’s internal diameter should be at least 1.5 times the cable diameter [#18276044] A 20/14 conduit was implied to be too tight for this use, while 22/18 was the recommended size [#18276023][#18275979] The point of the conduit is easy pulling and future replacement, not squeezing the cable into a minimal space [#18276044] The conduit is described as flame-retardant, not “self-extinguishing” [#18276044]
  • #1 18275889
    pimis
    Rate: 13
    What conduit for the YDYp 3x2.5 cable do you need to let in the floor?
    I mean: PESZEL SELF-EXHAUSTING FI?
    From what I heard that the conduit must be 3 times thicker than the cable?
  • #2 18275908
  • #3 18275943
    pimis
    Rate: 13
    And there is no limitation in terms of heat dissipation of the cable or other things, I am not an electrician, I do not know ...
  • #4 18275947
    kozi966
    Help: 599
    Rate: 1288
    My colleagues and I use this pattern when designing pipes. It is true that the model applies to outdoor cable networks, but I think it will also work here.
    di is the diameter of the wire.
    D is the pipe diameter (internal).
  • #5 18275968
    pimis
    Rate: 13
    And by the peasants' mind (for a fool) what kind of conduit for YDYp 3x2.5?
    kozi966
    Help: 599
    Rate: 1288
    Peszel fi 22/18.
  • #7 18276023
    pimis
    Rate: 13
    kozi966 wrote:
    Peszel fi 22/18.
    Thank you very much
    And so, out of curiosity, the FI: 20/14 barrier will be too tight?
    What is the problem?
    Can you apply one or not?
  • #8 18276044
    kkas12
    Help: 1076
    Rate: 4312
    Dude, the diameter is important when you lay the pipes first and then pull the wire into them. It is also important when replacing the cable. So use one that you can easily stretch on the cable, because that is how you do it more than certain and which does not matter anyway, because you will not bring the pipes to the box one hundred percent, and besides, if it is not covered with mortar on all sides / plaster / concrete, forget about a possible replacement anyway.
    Commercial power engineering used to require that the minimum diameter of the pipe should not be less than 1.5 times the diameter of the cable.
    And it doesn't have a self-extinguishing conduit, but it is flame retardant.
  • #9 18276050
    pimis
    Rate: 13
    You helped me a lot, but I'm just wondering what the phrase: "Commercial power engineering used to be required", has it changed?
  • #10 18276064
    kkas12
    Help: 1076
    Rate: 4312
    What has changed is that there are materials for this specific purpose. However, today I do not carry out orders that are transferred to their property. But they certainly do not save on the cross-sections of the pipes.
    There are both rigid and flexible pipes with specific diameters and you have finished combining and making culverts from what was handy and relatively cheap.
  • #11 18276132
    pimis
    Rate: 13
    Last question, sorry to be bored.
    You recommend a 22/18 conduit for YDYp 3x2.5, and what conduit for YDYp 5x2.5?
    kkas12
    Help: 1076
    Rate: 4312
    Why separate this for you?
    Buy one and noticing the difference when you pull in different sections, you will perfectly understand what I am writing about.
    Just attach it to the ground. You can use the handles used by plumbers Link
    Floor hook. There are also doubles.
    Although personally for me, laying cables on the floor is a last resort and I avoid it like fire.
  • #13 18276388
    Shadowix
    Help: 191
    Rate: 268
    Take 5x2.5 but a round one, it will be possible to use a smaller conduit than for a flat one ...
  • #14 18276535
  • #15 18276553
    kkas12
    Help: 1076
    Rate: 4312
    Why does he need this YDY5x for socket and lighting circuits?
    This is no longer YDA 3x ???
    And no twisting or wedging (if the flat cable) is a problem if the diameter of the pipe is appropriate, and besides, it will first pull the cable into the pipe and only then lay the whole thing on the floor. There is no other option.
    What about here brush I have no idea :)
    Moderated By Mirek Z.:
    I've already corrected the weird spelling of post # 13. ;)
The discussion centers on selecting the appropriate conduit for YDYp 3x2.5 cable for floor installation, specifically considering the PESZEL SELF-EXHAUSTING FI. Participants emphasize the importance of conduit diameter, recommending a PESZEL conduit with dimensions of 22/18 mm for optimal fit and ease of cable replacement. It is noted that the conduit should ideally be at least 1.5 times the diameter of the cable to facilitate heat dissipation and future maintenance. The conversation also touches on the use of round conduits for larger cables (YDYp 5x2.5) to reduce the risk of twisting and wedging during installation. Overall, the consensus is to prioritize flexibility and adequate sizing in conduit selection.
TL;DR: Use at least 1.5× conduit-to-cable internal diameter; "minimum diameter ... not be less than 1.5 times." Choose clearance for pulling and future replacement; peszel is flame-retardant, not "self-extinguishing." [Elektroda, kkas12, post #18276044]
Why it matters: This helps DIYers and electricians pick peszel sizes for YDYp floor runs that stay serviceable and safe.
What conduit size should I use for YDYp 3x2.5 laid in the floor?
Use peszel fi 22/18. This size was recommended in the thread for YDYp 3x2.5. It gives working clearance for pulling and later replacement. [Elektroda, kozi966, post #18275979]
Is the “conduit must be 3× thicker than the cable” rule real?
No. “It is designed to fit, but not tight.” Prioritize clearance so you can replace the cable in the future. Avoid arbitrary multipliers without context. [Elektroda, Anonymous, post #18275908]
Is a 20/14 peszel too tight for YDYp 3x2.5?
Avoid tight fits. If a test pull binds, step up a size. “Use one that you can easily stretch on the cable.” Tight fits block pulls and replacement. [Elektroda, kkas12, post #18276044]
How do I size conduit if I only know the cable diameter?
Apply the 1.5× rule. Let D (internal conduit) be at least 1.5 times di (cable diameter). This ensures clearance for pulling and replacement. [Elektroda, kkas12, post #18276044]
Should I use rigid or flexible conduit for floor runs?
Both rigid and flexible conduits exist for this purpose. Use purpose-made materials with defined diameters. Do not skimp on conduit cross-sections. [Elektroda, kkas12, post #18276064]
Can I run YDYp 5x2.5 in a smaller conduit if the cable is round?
Yes. Choose a round 5x2.5 cable when possible. A round cable lets you use a smaller conduit than a flat one, easing pulls. [Elektroda, Shadowix, post #18276388]
How do I fix peszel to the floor before the screed?
Use plumber-style clamps or floor hooks to secure the runs. Double clamps help keep pairs aligned. This stabilizes routes before pouring the screed. [Elektroda, kkas12, post #18276171]
Is laying conduits on the floor a good practice?
It’s a last resort. “Laying cables on the floor is a last resort and I avoid it like fire.” Prefer walls or ceilings when possible. [Elektroda, kkas12, post #18276171]
How do I avoid twisting and wedging when pulling cable?
Size the conduit correctly and pre-pull the cable through the peszel. “There is no other option.” Proper diameter prevents twisting and wedging. [Elektroda, kkas12, post #18276553]
What does “self‑extinguishing” peszel really mean?
Expect flame retardancy, not true self‑extinguishing behavior. The conduit slows flame spread but does not extinguish itself. Choose flame‑retardant peszel. [Elektroda, kkas12, post #18276044]
Will I be able to replace the cable later?
Only if the conduit reaches the box and is fully embedded on all sides. Otherwise, “forget about a possible replacement.” Plan continuity end-to-end. [Elektroda, kkas12, post #18276044]
How should I sequence the installation for a smooth pull?
  1. Pull the cable into the conduit first.
  2. Check the route for snags and tight bends.
  3. Lay the assembly on the floor and fix it with clamps. This order minimizes jams and kinks. [Elektroda, kkas12, post #18276553]
Does conduit size impact heat dissipation here?
The guidance focuses on mechanical clearance and replaceability. Size using the 1.5× internal diameter rule. Avoid tight fits that hinder movement and replacement. [Elektroda, kkas12, post #18276044]
