Which all-in-one 230V sounder for Apple's HomeKit?
barnio 972 3
  • #1 18355410
    barnio
    Rate: 25
    Can you point out any ready-made buzzer or loud buzzer in an all-in-one version for 230 volts. I am thinking of something triggered directly from an attached socket controlled from Apple's Homekit system. Ideally in the form of a single box, plugged directly into the socket, such simplest systems are usually the most trouble-free.
  • #2 18355795
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    Search under the keyword "school bell", e.g. DNS-212M or DNS-212D
  • #3 18394836
    barnio
    Rate: 25
    I have covered the subject with a DNS-255 Sundi bell screwed to a flat socket from Elgotech.
  • #4 18472476
    barnio
    Rate: 25
    Unfortunately this bell is not designed to generate a steady ringing signal - sometimes it is hard to wake the owner up at night :-) . After probably less than a minute of ringing the coil insulation goes up in smoke. The search for an alternative continues :-) .
