[Solved] Thermally Conductive Paste - Can I Use 4-Year-Old Paste After Degreasing & Vacuuming CPU?
serwil 25143 13
Can I use a 4-year-old thermal paste if it was stored sealed and I clean the CPU and cooler first?
Yes — if the paste has been stored sealed, away from sunlight, and its consistency has not changed, you can still use it even after several years [#18367464] [#18367471] [#18367578] The cooling unit should be cleaned well before remounting the cooler [#18367471] [#18367578] For cleaning the CPU/IHS, isopropanol is preferred, and denatured alcohol was also mentioned as usable [#18370759] [#18379521] [#18380323] Avoid using nail polish remover, since additives and solvents in it can be unsuitable for computer parts [#18370759] [#18380323] The original poster later applied a 4-year-old silver-based Revoltec paste and reported that it was still thick and usable [#18379362]
  • #1 18367448
    serwil
    Rate: 9
    I have a paste that is 4 years old (it was opened once until the first lubrication) and it is stored tightly.
    After degreasing the processor and vacuuming the fan, can I use this paste after a few years?
    Greetings!
    lukasis6
    Help: 25
    Rate: 71
    If it has been stored in a sealed package, it has not been exposed to sunlight, you can use it.
  • #3 18367471
    Pedros050
    Help: 2471
    Rate: 3927
    @serwil As long as the paste does not begin to change consistency, you can use. And not a fan, but a fan, and don't forget to clean the cooling unit well. All new pastes are silicone-free and have quite a long service life, those based on silicone begin to lose their properties after about a year.
  • Old paste still performs at 34–36 °C
    #4 18367554
    serwil
    Rate: 9
    Yes, it was, it is kept in a sealed package in a slightly cool place (it is in the process of searching - hence the question).
    Regarding the consistency, I understand that before smearing the tiles, I should have squeezed some paste out of the tube as a sample as a sample, so?
    The fan is quite dusty and I only use a box cooler.
    So my paste theoretically does not add silicone, because when I checked the temperature measurement in the processor recently, it remained at the same level as 4 years ago (34-36 degrees C), although the paste remained a thin stick after removing the cooler.
    Pedros050
    Help: 2471
    Rate: 3927
    It still works if you've checked and blow out the cooling properly and can put on this paste.
  • #7 18370759
  • #8 18379362
    serwil
    Rate: 9
    Thanks for your response!
    I spread the old Revoltec paste (silver based) - after 4 years the consistency is still thick. There was a bit of fastening when reinstalling the cooler (these tapered latches are sometimes crap). If it were an independent, separate cooler with full contact surface, the temperature would probably be lower.
    Apropo's of temperatures ... Which Bios values are correct? The ones on the main page or those in the "Current Status" tab? Because the difference is 8/9 degrees .... 25 to 34 degrees for example. The first value corresponds to what is shown in the Windows CPUID HW Monitor.
    Is it typical that the CPU temperature slowly rises when using Bios?
  • #9 18379489
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    The temperature in the BIOS may slowly rise to some degree.
    You have not provided the board model, CPU model, it is impossible to judge if any of these temperatures are correct. The description of the data presented in the BIOS should be found in the motherboard manual - the BIOS elements should be described.
    miroslaw wielki
    Conditionally unlocked
    Help: 148
    Rate: 362
    I sometimes use denatured alcohol for washing.
  • #11 18380298
    serwil
    Rate: 9
    Thanks DT1. (something is relevant to what you write about the remover because apart from the fact that in the air and eyes you can feel that it is more "corrosive" than, for example, spirit, it evaporates differently from the IHS and when looking against the light, there were some "stains" at the edge and it was a cleaner with no additives and no acetone).
    Gigabyte H81M-S2PV (LGA 1150) motherboard,
    Pentium G 3240 processor 2-core (over 4 years) - paste evenly spread over the entire surface,
    Box cooler,
    WD Blue 1 TB standard drive,
    Integrated graphics.
    Apropo's graphics ... I should be able to create a separate thread, but since the equipment is freshly vacuumed and changed the paste, I will ask here about the graphics:
    Despite the properly connected plug of the DVI cable, sometimes there is no signal - only when the plug is slightly maneuvered at the motherboard port, the signal appears.
    After booting the BIOS and the system boot ... The DVI cable is fresh - even younger than the motherboard. I will check how the signal behaves after switching to D-Sub, but I have a question for you: can this be due to some mechanical adjustment on the contacts at the DVI port in the disc?
    dt1
    Help: 7315
    Rate: 8292
    Ethyl acetate or butyl acetate are irritating and toxic (paradoxically more than acetone, which irritates the skin, but is said to be less toxic). If you made slush with a nail polish remover, it would be good to clean it with isopropanol, pure spirit or denatured alcohol, because it is not known what was still floating in this remover, often these are moisturizing ingredients that are supposed to take care of the skin (i.e. something that you tried to get rid of with this remover when it was not yet).
    As for the temperature of the processor, the BIOS can read the temperature around the base of the processor and it may be (or actually certainly is) different than the temperature of the cores. It is best to check these temperatures with HWInfo, take into account the temperature of the warmest core, and of course the temperatures under load count.
    As for the cable, try to replace it, even if it is new, it may have some damage. It is not worth bending the sockets on the board too much so as not to tear the solders.
  • #13 18382492
    serwil
    Rate: 9
    Perhaps on the main BIOS page it shows the temperature measured in the substation (lower) and in the "current status" it gives the real temperature of the processor itself (higher) broken down into cores, although the temperature values of each of the two cores are the same. . . and from the Win level already different: / I will check HWinfo.
    I loosened the screws securing the board so that the DVI port had more slack, but it didn't help. I will check this cable on another computer.
    Thanks for the posts.
  • #14 18400094
    serwil
    Rate: 9
    I am closing the thread.
The discussion revolves around the usability of a 4-year-old thermally conductive paste after proper degreasing and vacuuming of a CPU. Users confirm that if the paste has been stored in a sealed package and shows no change in consistency, it can still be used. The paste in question is identified as Revoltec Thermal Grease, which reportedly does not contain silicone. Recommendations for cleaning the CPU include using isopropanol or denatured alcohol, avoiding acetone-based products. The author also inquires about CPU temperature readings in BIOS and experiences issues with a DVI cable connection.
TL;DR: Silicone‑based pastes can degrade in about 1 year; "use it unless the consistency has changed." Clean the cooler well, then reuse. [Elektroda, Pedros050, post #18367471]
Why it matters: This FAQ helps PC builders and upgraders decide if old paste is safe and how to clean and apply it right.
Can I use 4‑year‑old thermal paste after cleaning the CPU?
Yes, if the paste’s consistency hasn’t changed. Clean the heatsink and fan thoroughly before reinstalling. The advisor notes modern non‑silicone pastes have long service life, but silicone‑based types age faster. If it spreads smoothly, you’re fine to reuse it. [Elektroda, Pedros050, post #18367471]
How do I check if old thermal paste is still good?
Dispense a small bead and inspect. It should be uniform, not chalky, crusted, or separated into oil and clumps. Try spreading a thin film; it should be thick yet workable. If it strings, crumbles, or feels dry, discard it. The key criterion is unchanged, usable consistency. [Elektroda, Pedros050, post #18367471]
What should I use to degrease the IHS and heatsink?
Use isopropanol on a lint‑free wipe and avoid nail polish removers with additives. "Isopropanol if anything." Dry‑wipe first, then finish with alcohol until residue is gone. Let both surfaces dry fully before applying paste. This minimizes contaminants that can hinder heat transfer or leave films. [Elektroda, Anonymous, post #18370759]
Is cosmetic salicylic spirit safe for cleaning CPUs?
Prefer isopropanol, pure spirit, or denatured alcohol. Cosmetic spirits can include skin additives that leave residue. The advisor recommends isopropanol and notes to avoid residues from cosmetic cleaners. Clean until the metal flashes uniformly, then let it dry. [Elektroda, dt1, post #18380323]
Is non‑acetone nail polish remover okay for cleaning thermal paste?
No. Non‑acetone removers often contain "care" chemicals that can leave films. The moderator advises skipping them and using proper alcohol instead. If you already used remover, follow up with isopropanol or pure spirit to strip residues. [Elektroda, Anonymous, post #18370759]
Why do temperatures rise while I’m sitting in BIOS?
BIOS often runs the CPU without full power saving and fan curves, so temperatures creep up. "The temperature in the BIOS may slowly rise to some degree." This behavior is expected and not a fault by itself. Confirm temps within the OS under load for a fair check. [Elektroda, dt1, post #18379489]
Which value should I trust when BIOS pages show different temperatures?
Different BIOS pages may show socket/board readings versus CPU core sensors. Trust per‑core readings and confirm in Windows with HWInfo. Focus on the hottest core and test under load to validate cooling. This gives a realistic picture compared to idle BIOS conditions. [Elektroda, dt1, post #18380323]
What idle temps were reported after reusing the old paste?
One user reported 34–36°C idle after reusing a years‑old paste, matching temps from four years prior. That suggests the paste still performed adequately in that setup. Use this as a case reference, not a universal rule. [Elektroda, serwil, post #18367554]
Is Revoltec Thermal Grease 0.5 g still OK after years?
The user applied silver‑based Revoltec Thermal Grease after 4 years; it remained thick and usable. They noted mounting latch fiddliness affected temps more than the paste. If your tube shows stable consistency, it’s reasonable to reuse. [Elektroda, serwil, post #18379362]
How do I apply thermal paste correctly on LGA1150 (Pentium G3240, stock cooler)?
  • 3‑step How‑To:
    1. Clean both surfaces with isopropanol and let them dry.
    2. Apply a small pea‑sized dot in the center of the IHS.
    3. Mount the cooler with even pressure; do not twist excessively. This method ensures even spread without air pockets. [Noctua, 2021]
How should I dust the cooler and fan safely?
Blow out the heatsink fins and fan thoroughly before reassembly. Ensure the cooler seats flat with firm, even pressure. Replace paste after cleaning. Properly restored airflow and contact can lower temperatures significantly. [Elektroda, Pedros050, post #18367578]
My DVI shows no signal unless I wiggle the plug—how do I fix it?
Test with another DVI cable first. If the socket feels loose, avoid bending its contacts; that can tear solder joints. Inspect the port and mount, then reseat the board if needed. If issues persist, consider professional rework. [Elektroda, dt1, post #18380323]
