[Solved] Is it Safe to Use Alcohol for Removing Old Paste from CPU Processor?
BloodTrail 7254 2
  • #1 18138328
    BloodTrail
    Hello, I recently heard that you can use alcohol to clean the processor from the old paste. Is this true or does it not jeopardize the hardware?
    Robert B
    Help: 2027
    Rate: 1412
    You can, but IPA is better. If it is very dry, you can use acetone
  • #3 18138353
    BloodTrail
    Thanks for the answer
