Connecting Aux Cable to MB Audio CD Becker BE6021 10 in Mercedes C220: User Experiences
mbw203 12066 9
Can I connect an AUX input to the Mercedes MB Audio CD Becker BE6021 10 radio, and where should it be wired?
A working AUX mod for this BECKER BE6021 10 was not confirmed in the thread. The red CD connector pin 10 is marked S/PDIF, so the CD link is digital rather than analog audio, which means you cannot simply splice an AUX signal in there [#18373817] The analog side would have to be injected after the digital stage, around the audio processor IC2000 SACHARA35; one suggestion was to look at the AM/MPX area and possibly replace the AM input with AUX, but no exact solder point was proven [#18373817][#18381835] Another reply also noted that the CD-drive signal likely goes to the processor as S/PDIF, not analog [#18373817] In the end, the thread ends without a completed solution or confirmed wiring location [#19140068]
  • #1 16044910
    mbw203
    Hello, subject quite old, I have a question about the radio in my Mercedes C220
    radio is MB audio CD Becker BE6021 10
    Did anyone manage to connect the aux cable to this radio? I saw a lot of threads but not with this model.
  • #2 18372213
    szychan1
    Hello, I also need help connecting the aux to be6021. Where to connect the aux instead of the signal from the cd, which will not be because the drive will float with silence 650mb at which the player does not mutate.
    Manual and photo radio attached
    Moderated By damiancz:
    3.1.19. Do not send messages on archival subjects if this is another question, in particular other than the questioner. For the sake of respect to the questioner, create your own topic. You can only add a solution to the problem.
    3.1.14. Do not send messages not related to the topic or in the wrong forum section.
    • Connecting Aux Cable to MB Audio CD Becker BE6021 10 in Mercedes C220: User Experiences IMG_20171003_011824.jpg (591.33 KB) You must be logged in to download this attachment.
    • be6021.pdf (5.81 MB) You must be logged in to download this attachment.
  • #3 18372308
    marcel31
    hello be ----- this becker topic is about alpine
    in becker aux I can't do it yet there is no tea 6880h otherwise the audio processor is solved
  • #4 18373778
    szychan1
    Well. Do you know if you couldn't use the red plug from the cd reader to give the aux signal in parallel with the cd reader?
  • #5 18373817
    marcel31
    from what I remember the signal goes there as spidif and not analog audio
    to the processor from the cd drive but check it ---- the radio goes mpx am fm because the processor is with a piece of the radio tuner audioprocessor just oasis somehow I did not find the catalog note and without that it's difficult to say anything more
    I promise myself that one day I will squat because a lot of people want aux to w203 so far I have mastered to perfection but audio 10 alpine
  • #6 18375159
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1412
    The topic has been divided.
  • #7 18381835
    szychan1
    The output from the red plug of this radio on pin No. 10 is signed '' S / P-DIF ''
    The audio processor in the manual is described IC2000 SACHARA35.
    On the seventh page of the instruction sent above, in the upper right corner of the processor under position 48 there is '' mpx '', right below it is '' AM ''.
    Maybe it will be easier to replace AM on the radio with AUX.
    Is it possible by connecting to NFAM?
  • #8 18772844
    szychan1
    I don't know much about it. Did someone suggest what to solder under?
  • #9 19116790
    kotsios
    szychan1 Do you find out the way?
  • #10 19140068
    szychan1
    Unfortunately not
The discussion revolves around connecting an AUX cable to the MB Audio CD Becker BE6021 10 radio in a Mercedes C220. Users express challenges in finding a suitable method for this connection, with some suggesting the possibility of using the red plug from the CD reader to provide an AUX signal. However, it is noted that the signal from the CD drive is likely S/PDIF rather than analog audio. There are mentions of the audio processor IC2000 SACHARA35 and the potential to replace the AM function with AUX. Despite various inquiries and suggestions, no definitive solution has been reached, and users continue to seek guidance on soldering points and connection methods.
