JBL T450BT Left Side Not Working: Troubleshooting PCB & Current Issues (Pics Included)
frant12 23856 4
  • #1 18408678
    frant12
    Recently, the left side of my JBL T450BT over-ear headphones stopped working. I would like to point out right away that I am not a specialist - I just want to repair my equipment. I opened the headphones and it turned out that all the control (controller) is in the right earphone (good enough). I switched the loudspeaker from the left to the right earphone to make sure everything was ok with it - it was working. So I started looking for a fault on the PCB in the left earphone. After the measurement with the meter, it turned out that one of the pins has no current (marked with a red circle in the picture).
    I checked the analogous pin (Signed with the same code - SKLP) on the right handset (marked with a blue circle) and the current flows through it.
    From this working pin, the cable goes through the headband to the non-working one. I figured maybe something was wrong with the solder (although it looked okay), so I unsoldered the cable and re-soldered (not very neatly, as you can see from the rest). Unfortunately it didn't help. Logic shows that this wire is broken somewhere (maybe inside the headband). What should I do? There is still a chance for these headphones?
    Tumiwisizm
    Help: 125
    Rate: 196
    You have a properly diagnosed problem, so replacing the cable is just a formality. Desolder the damaged wire on one side and solder a good wire to it and slowly pull the good wire through the headband, pulling the damaged one. Unscrew the rotating speaker brackets from the headband.
    Here's a screw like something.
  • #3 18409353
    frant12
    Thanks a lot, I certainly wouldn't have come up with the dragging idea myself. I knew about the screw, but couldn't remove it. Fortunately, WD-40 helped. I will be combining ;)
  • #4 19143451
    thekaczor
    I have the same problem, but I don't know where to buy such a cable.
    Four-core cable with an outer diameter of about 1mm.
    Can anybody help? It would be nice to have a name, symbol, anything that would allow you to find such a cable in the network.
  • #5 21465149
    chakrabartisambuddha
    Any idea on the type of switch at SPKKP2 main PCB board?
