[Solved] Why did my JBL 500BT right earbud stop working and how to fix it?
Pawcio15 35352 11
Why did the right side of my JBL BT500 Bluetooth headphones stop working, and how can I fix it?
The most likely cause is an internal hardware fault in the headphones, not a Bluetooth connection problem, so the fix is to inspect the internal wiring or use service/warranty repair [#20205673] [#20205687] First test the headphones with another phone to rule out connectivity issues; if the right side still does not work, the fault is likely inside the headset [#20205673] Suggested checks include opening the headphones and looking for a broken connection in the headband cable, a damaged speaker/membrane coil, or another internal break [#20205711] Another basic diagnostic is to measure the resistance of the headphone circuit after opening them [#20205671] Given the mention that they may have been compressed or damaged in a backpack, physical damage to an internal connection is plausible [#20205678] If the warranty is still valid, replacing them through warranty or taking them to a service center is the practical solution [#20205687]
  • #1 20205661
    Pawcio15
    Level 4  
    Rate: 29
    I have JBL bt500 over-ear headphones and today I noticed a problem: the right earphone is not working, everything was working fine so far. What could be the problem?
  • #2 20205671
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    Remove the wires and reinsert them, if it does not help, measure the resistance of the headphone circuit if these are wired headphones.
    This can also be done with wireless ones, you just need to open the patient.
  • #3 20205673
    Owndragon
    Help: 33
    Rate: 104
    Have the headphones been tested with another phone, preferably with a different Bluetooth version?
    It would be a good idea to first eliminate potential connectivity problems.
  • #4 20205676
    Pawcio15
    Level 4  
    Rate: 29
    These are Bluetooth headphones
  • #5 20205677
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    Has anyone ever fallen?
  • Backpack drop may have damaged one earbud
    #6 20205678
    Pawcio15
    Level 4  
    Rate: 29
    It was checked and one earphone still does not work, even when turning it on or off, if there is this sound from JBL, it can be heard in one earphone, but before it was heard in both
    Added after 48 [seconds]:
    I was on a trip and I had them in my backpack and something like that could have happened because I had them in the back pocket of the backpack
  • #7 20205686
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    Try to give it a rest and see if charging is effective, it has one or two cells, the measurement is faulty, it may be damaged.
  • #8 20205687
    Owndragon
    Help: 33
    Rate: 104
    I think that in such a situation it is necessary to visit the service center or replace the headphones under warranty (if it is still valid), because you will probably have to open the headphones and look for damage to the connections inside.
  • #9 20205693
    Pawcio15
    Level 4  
    Rate: 29
    I mean, what`s going on with these cells?
    Added after 10 [minutes]:
    I connected it and it lights up red
  • Basic diagnostics for a dead headphone earbud
    #10 20205711
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    When it comes to wireless headphones, sometimes you need to charge them for them to work properly, and if they have a cell and a device in one or two earphones, you should check the device`s power supply and whether the earphone has not suffered a break in the membrane coil circuit in the event of a fall, this is diagnostics, basics. What could be damaged. Or the cable in the headband connecting the headphones. Dear deduction, if not, then maybe this.
  • #11 20205713
    Pawcio15
    Level 4  
    Rate: 29
    It`s a funny situation, gentlemen, with these headphones. I disconnected them from charging and they took 15 seconds to charge because I only saw if they were lit and both headphones were working, what could it be? And they are charged to the max because now when I connect them, I can see them
  • Uneven cell discharge causing stereo effect
    #12 20205714
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    Pawcio15 wrote:
    I connected it and the lights are red
    Check the user manual what it means, different manufacturers may have different meanings of such information, I know about repairs and breakdowns, I don`t know about specific equipment that I don`t have.
    Check if they are fully charged in the manual, I suspect that technology has advanced and 15 seconds may be enough for operation, but check in the manual, that`s what it is there for.
    Pawcio15 wrote:
    what could it be?
    Not charged with the electricity needed for their operation, there are apparently two cells that do not discharge equally, known as the stereo effect.
The user reported an issue with their JBL 500BT Bluetooth headphones, specifically that the right earbud stopped working despite previously functioning well. Suggestions for troubleshooting included checking the headphone's connectivity with different devices, ensuring proper charging, and inspecting for physical damage, particularly after the headphones were stored in a backpack during travel. Recommendations also included measuring the resistance of the headphone circuit and consulting the user manual for charging indicators. If problems persist, visiting a service center or considering warranty replacement was advised.
TL;DR: JBL 500BT/Tune 500BT one ear silent? A 15‑second charge may restore audio; "15 seconds may be enough." Start with Bluetooth checks, then wiring. [Elektroda, krzysiozak, post #20205714]
Why did my JBL 500BT/Tune 500BT suddenly play in only one ear?
Physical damage is common. A fall or pressure can break the driver coil or the cable in the headband. That open circuit silences one side. If the headphone suffered a knock or was squeezed in a bag, suspect these parts first. Inspect and test continuity before buying new drivers. [Elektroda, krzysiozak, post #20205711]
How do I rule out Bluetooth or phone issues fast?
Test the headphones with another phone, ideally with a different Bluetooth version. Unpair from all devices, then re-pair. This isolates pairing glitches and codec quirks before hardware work. "It would be a good idea to first eliminate potential connectivity problems." [Elektroda, Owndragon, post #20205673]
A short charge made both sides work again. Why?
A brief charge can clear a low-power or battery-state desync. Some designs can exhibit uneven cell or power distribution. Topping up refreshes the power rail and reinitializes audio. As one expert noted, "15 seconds may be enough for operation." If it recurs, check wiring next. [Elektroda, krzysiozak, post #20205714]
What does a red LED mean while charging the 500BT?
Red indicates the headset is charging. Leave it on the charger until the indicator changes per the manual’s chart or turns off. Charging completes in about two hours when using a suitable USB source. Refer to the manual for exact LED behavior. [JBL TUNE 500BT - User Manual]
How do I soft‑reset and re‑pair my JBL 500BT/Tune 500BT?
Forget the headset in your phone’s Bluetooth list, power the headphones off, then re-enter pairing and connect. How-To: 1. On the phone, Forget/Remove "JBL TUNE500BT." 2. Power off, then hold the power button to enter pairing (LED blinks). 3. Select the headphones in Bluetooth and reconnect. [JBL TUNE 500BT - User Manual]
Can I measure the driver or wiring at home to confirm a fault?
Yes, if out of warranty. Open the earcup and measure the driver’s resistance with a multimeter. Compare left vs right. A healthy driver shows continuity; an open circuit indicates a blown coil or broken wire. Re-seat internal connectors before replacing parts. [Elektroda, krzysiozak, post #20205671]
The JBL startup tone plays only in one ear. What does that indicate?
If power tones play only on one side, the silent side likely has an open circuit. Suspect a broken driver coil or the headband cable. Open the earcup and check continuity, solder joints, and the flex cable at the hinge. [Elektroda, krzysiozak, post #20205711]
Could a backpack squeeze or drop cause one side to fail?
Yes. Mechanical stress can fracture the thin voice-coil wire or the headband interconnect. After an impact, expect intermittent audio that becomes a dead channel. Inspect the cable path across the headband and the driver terminals for breaks. [Elektroda, krzysiozak, post #20205711]
What quick 3‑step fix should I try before opening the headphones?
Try a power-state refresh. 1. Put the headphones on charge for 30–60 seconds. 2. Power off, then power on. 3. If still one-sided, fully charge, then re-test. Users reported a 15‑second top‑up restoring both channels. [Elektroda, Pawcio15, post #20205713]
What official specs matter for troubleshooting battery and pairing?
Playback time is up to 16 hours, with about 2 hours to full charge. The model uses Bluetooth 4.1, which affects device compatibility and pairing behavior. These figures help verify charging and runtime during tests. [JBL TUNE 500BT - Product Specs]
When should I stop DIY and use warranty or service?
Use service if the headphones are under warranty or if continuity checks pass but audio remains dead. Internal board-level faults or microscopic cable breaks need professional tools. Opening the unit may void coverage. [Elektroda, Owndragon, post #20205687]
Edge case: What if the amplifier channel or BT board failed?
A failed amp channel or main board leaves one side dead even with good drivers. Board-level repair requires micro-soldering and parts access. Seek authorized service or warranty replacement for this scenario. [Elektroda, Owndragon, post #20205687]
