Best Home NAS File Server for Backup: WD My Cloud EX2 Ultra vs Others, Self-Disk Replacement
Pawel1812 14427 33
What home NAS should I buy for automatic backups and selective media sharing, and can the disks in a WD My Cloud EX2 Ultra be replaced or recovered safely?
Buy a Synology or QNAP NAS, preferably a 2-bay model with RAID1, because it is small, quiet, power-efficient, and lets you share only what you choose [#18434326][#18434393] If one disk fails in RAID1, the NAS keeps running on the remaining disk and you replace the bad drive and let it resync; you can also start with one disk and add the second later, but RAID1 capacity stays equivalent to one disk [#18440524] For backups, use software that does incremental backup or folder synchronization so only changed files are copied after the first run, which makes weekly or background backups practical [#18436852] Do not rely on RAID or snapshots alone against ransomware; keep at least two copies, use a separate NAS account with a strong password and write access only to the backup folder, and do not expose the backup NAS to the internet [#18434505][#18438871][#18437207] Snapshots can help reduce risk, but they are not a 100% guarantee [#18437094] If you only want simple backup and not a full file server, an external drive can work, but the NAS is the more convenient long-term solution [#18434326]
  • #1 18433293
    Pawel1812
    Help: 44
    Rate: 267
    I would like to purchase a NAS for home.
    I have the Internet with Orange Funbox, VDSL, so it's hard to change the router.
    I would like to have a backup of the most important data and photos, install and configure a program on my computer that would back up the NAS server in the background from time to time. I would not like us to share everything with everyone.
    It would be nice if you could share movies to TV.
    I was thinking about WD My Cloud EX2 Ultra, but I wonder if it is possible to replace the disk yourself (the manual says yes, a bit further that no, on the forum that no), moreover, apparently the data is encrypted on the disk, so in case of failure disk or electronics of such a NAS, the data will be difficult to recover - even a sectoral copy will not do much.
    What would you recommend?
    Or maybe buy a regular 2.5 "external drive, install the backup program and simply connect it once a week?
    I am after a HDD failure, a lot of data has gone, I am considering returning the disk to the lab, so I am thinking how to prevent a misfortune in the future - probably the best moment.
  • #2 18434326
    Walery K
    Help: 32
    Rate: 100
    I suggest Synology. Small, quiet, low energy consumption and the number of functions very large. A huge number of models to choose from. You can choose depending on your needs and the content of the wallet.
    When it comes to sharing, you share what you want and with whomever you want.
    If you are only interested in backup, it is actually enough to connect only an external drive, but I cannot imagine working without this server today.
  • #3 18434393
    m.jastrzebski
    Help: 679
    Rate: 865
    Synology, Qnap.
    If it is going to be a backup against falling disks, then definitely a 2-bay version and a RAID-1 configuration, the data is kept in duplicate on two disks. This happens automatically. I personally threw large disks from my computers, put very large ones into a network disk. The transfer to such a disk via the cable (and this is what serious work is done for me), hits the 1Gbit / s, so only working with really large files can be negatively felt. There is no time-consuming backups.
  • #4 18434505
    jprzedworski
    Help: 758
    Rate: 828
    The problem is that if we have everything on one network drive (NAS), in the event of a failure, especially ransomware, we lose everything. Nawer RAID (mirror) may not help. You must have at least two copies of the data.
    By the way:
    https://www.qnap.com/solution/ransomware/pl-pl/
    https://www.synology.com/pl-pl/solution/ransomware
    The question is what budget?
  • #5 18434617
    m.jastrzebski
    Help: 679
    Rate: 865
    Complete consent. The question of what we want to protect ourselves against and how much money should be spent on it. Because even two physical copies on different media do not protect against a fire in a building or even a more probable theft. Can protect a large backup safe from theft. Carry a backup to a bank locker every day before a fire or replicate data with another NAS in a different physical location. It is extremely difficult to protect yourself from ransomware - you will learn about the problem how the data on the computer and on the NAS will be encrypted, and on the disk in the pocket connected only for the time of the backap, they can also be encrypted. The hacker pulls the plug (deletes the encryption key on the computer) and the data starts to multiply on any medium, even on the one that is currently not connected to anything.
    It all depends on the expectations and possibilities.
  • #6 18434656
    jprzedworski
    Help: 758
    Rate: 828
    That's why Synology and Qnap give recommendations on how to minimize risk, but never 100% sure.
  • #7 18435337
    Pawel1812
    Help: 44
    Rate: 267
    Thank you for the hints - I have not read about Synology servers.
    I survived a ransomware attack a few years ago. Fortunately, it did not do much damage then, because it only encrypted my documents and main folder on the disk, and I do not keep any data there.
    This time it was worse, the shoddy ST2000LM007 Rosewood drive fell, which are extremely fail-safe drives, it is also difficult to find a specialist who has experience in their repair, and if it is already for about PLN 3, there is no point in approaching it.
    I prefer to invest in backup than from time to time to support hackers or data recovery companies, although of course I respect and admire the work of the latter.
    From what I have seen - small NAS servers cost about a thousand zlotys without disks and this is an acceptable price for me, unless someone proposes something better.
    I read about the QNAP TS-231P
    If we have, say, 0.5 TB of multimedia to protect, they may not be of great value, but hypothetically to protect them, what capacity must the NAS have to make multiple copies? How long will it take to make it?
  • #9 18435629
    Pawel1812
    Help: 44
    Rate: 267
    Thank you for the hint, for the same server I thought for an affordable price. Only how long will it take to make one copy outside the file system if we are talking about 0.5 TB of multimedia protection? And what disk capacity should I purchase for this purpose?
    It is known that you will need some disks for this amount of data, I just want to know what size disks to buy at the beginning.
  • #10 18436852
    m.jastrzebski
    Help: 679
    Rate: 865
    A bit of a silly question. To back up 0.5TB of data, you need a 0.5TB disk or larger. You don't want to back up the same media every day, which most likely hasn't changed since the last time. It's a waste of space and it's a waste of disks.
    In most cases, you can make an incremental backup, i.e. save only the files that have changed from the previous time on a given day.
    The second option is folder synchronization. Synology for sure, I assume that qnap also offers what they call home cloud software there. You designate a folder on your computer and the software synchronizes the files of the remote folder between the computer and the disk. So there is an almost instantaneous copy. The first synchronization takes a while, but then when you add or change a file, only it will be sent to the disk almost immediately. Moreover, the NAS does not need to be turned on, turning it on after a week will catch it and synchronize any changes. And, if someone else changes the file on the disk from another computer, you will also see the changed version here.
  • #12 18437067
    Pawel1812
    Help: 44
    Rate: 267
    Thanks for the hints.
    The question as to the space needed is not stupid, as QNAP periodically performs so-called snapshots - state snapshots of protected folders outside the file system to avoid encryption.
    On the one hand, multimedia of course does not change, but on the other hand, if they were encrypted, keeping them outside the NAS file system seems to be wise.
    Disconnecting the NAS outside of the backup time seems to be a good solution, but why the NAS then, then a simple USB drive connected to the computer every week is enough. Losing my files for a week would not have led me to leave thousands with data recovery or pay a hacker a ransom.
    I have to make a decision from this topic, because once again I do not intend to pay, I prefer to spend this money on a good backup mechanism working in the background, I will add that I am one of those who postpone "for later", so it is better to make a copy it was doing itself. The cost of the equipment is of secondary importance here.
  • #13 18437094
    jprzedworski
    Help: 758
    Rate: 828
    Qnap generally reserves up to 20% of its resources for snapshots, it should be enough for 256 snapshots, and you can always delete the oldest ones. It is not a lot. Simply put, a snapshot consists of "freezing" (read-only) the current data and creating a smaller "file" in which the changes from that point on (new data or metadata) will be saved. So it's not duplicating everything, just saving changes. More details here:
    https://www.backupacademy.pl/poradnik-jak-dzialaja-migawki-snapshot-na-qnap-nas/
  • #14 18437151
    m.jastrzebski
    Help: 679
    Rate: 865
    100% of the hackers are already working on a safe workaround for snapshots. Or they already have them.
    I'm not a hacker, but I can imagine it could take weeks to encrypt your files, just in a minute, so as not to attract attention. If the operating system itself is modified, you can still use, read, or modify files that are in fact encrypted. You open the file, it is decrypted on the fly. You save, it is encrypted on the fly.
    Only when hackers decide that they are revealing themselves, when they have sufficiently exploited the security hole they discovered, have encrypted enough devices, can they simultaneously erase the encryption key on these devices, and tadaaa, all data is no longer usable everywhere. In this case, even a snapshot outside the filesystem could be encrypted because it could have been taken from the data that was just encrypted.
    As far as I remember an action with synology, that's what happened. One day, a bunch of people found out that their data had been encrypted. The encryption process itself, which took quite a long time, they did not notice. The encryption takes a while, you can't encrypt a TB of data in 5 minutes.
    So in my case: the data network drive is NOT exposed to any port. And it's not popular synology or qnap, just linux with Samba.
  • #15 18437207
    jprzedworski
    Help: 758
    Rate: 828
    m.jastrzebski wrote:
    the network data drive is NOT exposed to any port
    YES!!!! And certainly the one with backups.
  • #16 18437477
    Pawel1812
    Help: 44
    Rate: 267
    So how to do it in practice? Have a backup disk unmounted from the system? Will backup be able to be done then?
    Will such ransomware also encrypt files on google drive?
    Microsoft One Drive allows you to restore deleted files for a month. Is it encrypted as well?
    Which server to buy? Price is of secondary importance, I want to buy something that I will be happy with and won't go through a data loss disaster.
    What's the difference between TS231 and TS231P2-4G. Is it worth the extra money?
    Is it worth adding to the TS-251? What can video transcoding be useful for?
  • #17 18438871
    Borygo123
    Help: 122
    Rate: 196
    In order to protect against encryption, I recommend that you use a separate NAS account with a strong password for backup. Only this account can have write access to the backup directory. All other users have read-only access or not at all (including the admin account). You make the backup with a backup program (any) and in it you enter data to the account that can be saved by the backup. With this configuration, encryption programs do not have write access, because they use a local account (or administrator if they raise their permissions) and cannot encrypt anything.
  • #18 18438916
    Pawel1812
    Help: 44
    Rate: 267
    Thanks for the suggestion, this is some idea, but is it possible if you want to make a backup with the program, automatically?
    I was browsing my OneDrive recently and it turns out that this cloud allows you to restore the file not only as it is today, but much earlier, OneDrive takes file dumps which actually protects against encryption.
    Currently, it is enough to purchase a legal Office with an annual license for PLN 160, to which Microsoft adds 1 TB of such protected space on OneDrive for free.
    Even if the worm gained access to files on OneDrive and deleted them, it would be a month to recover them after logging into a Microsoft account.
    The disadvantage is the low upload of my connection, but the data can be uploaded at night.
    It is also difficult to watch movies from OneDrive via the VDSL DL 40Mbit / 6Mbit link.
  • #19 18438937
    Borygo123
    Help: 122
    Rate: 196
    Well, this kind of backup must be entrusted to the program, so that you do not have the system access rights to the backup directory.
    The cloud is always sending your data to other entities. I would not have sent anything there without prior encryption, especially of sensitive data. Many companies offer large and free space for user data, but if you want to buy a disk, it turns out that it is not for free. So you should consider why they do it for free (or for little money). For Office with an annual license, you will have to pay again after one year. Isn't it better to buy a normal license?
  • #20 18438971
    Pawel1812
    Help: 44
    Rate: 267
    PLN 160 for 1TB is probably the best offer on the market, and I have to pay for the cloud every year.
    As for sending data - Google Drive does not accept encrypted data. I would love to hear my colleague's opinion about what Microsoft can do with my accounting or my photos or videos - even naked. They will sooner fall into the wrong hands when they stand at home.
    Are there any known and described cases of data loss in clouds such as Microsoft or Google or making it available to third parties / entities?
  • #21 18439088
    Borygo123
    Help: 122
    Rate: 196
    It seems that I have nothing interesting to show or hide, but they want to collect it for something. Currently, one can only guess and theorize why they do it. However, they have a purpose in this.
    With a cloud (but I don't remember which one) I remember such an interesting event. Some users suddenly appeared files that they had deleted several years earlier. The company explained that it indexed its resources and found something there and restored the files to the owners. But in my opinion, they did not delete these files, they only marked that the owner could not see them. And when it comes to what, for example, Microsoft can do with our photos, I am already answering. You can hang a billboard with your photo in front of your house, which you sent to, for example, FB and not only that you will have nothing to say, they will do it all in accordance with the regulations you agreed to. I'm not paranoid with an aluminum cap on my head. I also use the cloud (because it is a convenience), but I encrypt sensitive data before sending it.
  • #23 18439324
    Pawel1812
    Help: 44
    Rate: 267
    I don't want to guess what they might, just what known cases of what they actually did.
    If they had ever done something wrong with the data - I think it would have spread very quickly.
    For me, not using the cloud (I considered and did not use the above-mentioned reasons) costs at least 1.6 thousand. PLN for data recovery, if not more - depends on the condition of the tacky ST2000LM007 plates. I would have a 1TB cloud and a legal Office paid for at least 10 years but wise after the damage ...
    Another thing is that the photos to send to the cloud or even upload to some flash drive could be cataloged, etc. It is easy to rip from the camera anywhere and put it "for later" if you have a 2TB disk. This is one of the reasons why I didn't make a copy.
    It is known that I will buy US and I will be smarter, the accounting will be in the cloud and the photos will be additionally on an external disk in the closet. The only question is, what is safer to keep data in a closet - FLASH or HDD memory?
    Recovery specialists say that HDD - data recovery is easier and if necessary it is cheaper. On the other hand, the collapse of the modern HDD is a certain failure - in the case of FLASH it is not.
    Datacenter still use disk drives as cheaper.
    Let me return to the question - which US to buy? TS231P, TS231P2-4G or maybe TS-251?
  • #24 18440056
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Buy one where you can easily add RAM at any time:
    https://youtu.be/4uAIIKVQuZo
    Damage to the controller, memory module and also the disk and data in the trash.
    Get HDD - cheaper, more data will come in.
    only for HDD - buy a drive intended for the server, not any one: WD RED, WD RED PRO, WD Gold, Seagate IronWolf. Seagate IronWolf Pro.
  • #25 18440472
    Pawel1812
    Help: 44
    Rate: 267
    Thank you for the hints about the drives, what are the differences between WD Red and WD Red Pro drives? Is there really a significant difference in their durability?
    With NAS and RAID1, is disk durability so important that it is worth investing in?
    I wanted to ask what happens if one of the drives fails in a RAID1 configuration, will the server continue to run normally and back up to only one drive?
    What will happen when I mount only one disk to the server, or will it be possible to add a second disk without any problems in terms of data security?
    I am asking because I have never had such a server.
  • #26 18440524
    Borygo123
    Help: 122
    Rate: 196
    These disks are designed for use in devices such as NAS (continuous operation) and differ in endurance from ordinary disks. If you have RAID1 (the same on two disks), you can have a regular one, but it will probably crash faster and you will have to replace it. Or you can only use one disk at the beginning, but when creating a volume on the NAS, choose to create RAID1 immediately, as later you won't be able to change it without losing your data and re-creating it from scratch. When you get a second disk, add it and the NAS will synchronize it and lose the data.
    In the event of failure of one of the disks, you dismount the damaged disk, insert the other one and wait for the contents to be equalized. You have completed the entire operation.
  • #27 18440702
    Pawel1812
    Help: 44
    Rate: 267
    Thanks for the clarification.
    And can a second disk be added to such a server over time?
  • #28 18440715
    Borygo123
    Help: 122
    Rate: 196
    You can, but you won't use more capacity.
  • #29 18440865
    Pawel1812
    Help: 44
    Rate: 267
    I read the manual in which it says that the server encrypts data on disks. Is it mandatory, or can this function be turned off, because in my opinion it may make it difficult to recover data from the disk using a cross-sector backup in the event of a server and disk failure at the same time. Or maybe I am thinking wrong?
  • #30 18440952
    Borygo123
    Help: 122
    Rate: 196
    You don't need to turn on encryption.
The discussion revolves around selecting a suitable NAS (Network Attached Storage) for home backup, with a focus on the WD My Cloud EX2 Ultra and alternatives like Synology and QNAP. Users express concerns about data encryption, disk replacement, and the risks of data loss due to hardware failure or ransomware attacks. Recommendations include opting for a NAS with RAID-1 configuration for redundancy, using external drives for backups, and ensuring proper security measures against unauthorized access. The importance of incremental backups and snapshots for data protection is emphasized, along with considerations for disk durability and the potential for future upgrades. Users also discuss the implications of using cloud services versus local storage for sensitive data.
TL;DR: For a 0.5 TB home archive, a 2-bay NAS with RAID-1 and snapshots (20 % reserve, 256 versions) [Elektroda, jprzedworski, post #18437094] keeps two live copies at gigabit speed; “I suggest Synology” [Elektroda, Walery K, post #18434326]
Why it matters: One small box can slash single-disk or ransomware downtime without monthly cloud fees.
• Entry-level 2-bay NAS: ~PLN 1000 without drives [Elektroda, Pawel1812, post #18435337] • Snapshot reserve: up to 20 % capacity = 256 versions [Elektroda, jprzedworski, post #18437094] • Gigabit LAN real-world copy: ≈110 MB/s (Gigabit Ethernet Max Throughput) • NAS-grade HDD workload rating: 180–300 TB/yr [WD, 2023] • Microsoft 365 gives 1 TB cloud for PLN 160/yr [Elektroda, Pawel1812, post #18438916]
Which NAS brands are most recommended for a small home backup server?
Forum users point to Synology and QNAP for their quiet operation, low power use, and rich apps [Elektroda, Walery K, #18434326; m.jastrzebski, #18434393].
How many bays and what RAID level should I pick?
Choose at least a 2-bay chassis and set RAID-1. The array mirrors data, so a single-disk crash leaves everything online [Elektroda, m.jastrzebski, post #18434393]
What drive size do I need to safeguard 0.5 TB of media with snapshots?
Two 1 TB disks leave ≈0.8 TB usable after RAID-1 and 20 % snapshot reserve—plenty for 0.5 TB plus growth [Elektroda, jprzedworski, post #18437094]
How long will the first 0.5 TB backup take over Gigabit Ethernet?
At ~110 MB/s, copying 0.5 TB finishes in about 1 hour 20 minutes (512 GB ÷ 110 MB/s) ("Gigabit Ethernet Max Throughput").
What happens if one drive in RAID-1 fails?
The NAS stays online in degraded mode. Replace the bad disk, and it rebuilds automatically while data remains accessible [Elektroda, Borygo123, post #18440524]
Can I start with one disk now and add the second later?
Yes, create a RAID-1 volume at setup, add the second drive later, and the NAS syncs it; capacity stays the same [Elektroda, Borygo123, post #18440715]
Do snapshots fully stop ransomware?
They help but are not bullet-proof. Malware can encrypt slowly, then delete keys, corrupting even snapshots [Elektroda, m.jastrzebski, post #18437151] “100 % of the hackers are already working on a safe workaround” [same post].
Should I still keep an off-site or cloud copy?
Yes. Two separate media and one off-site copy follow the 3-2-1 rule, covering fire or theft risks [“3-2-1 Backup Rule”].
What’s the key difference between QNAP TS-231P, TS-231P2-4G, and TS-251?
TS-231P2 adds a faster CPU and 4 GB RAM; TS-251 moves to an Intel processor with HDMI and real-time video transcoding—useful for streaming to TVs without native codec support (QNAP Product Pages).
How can I copy data quickly without relying on slow Wi-Fi?
1 GBit direct-cable connect works after assigning matching IPs, or plug a USB-3 external drive into the NAS’s front port for one-touch import [Elektroda, KOCUREK1970, post #18444902]
Simple 3-step setup for automatic PC-to-NAS backup?
  1. Install QNAP NetBak Replicator or Synology Drive Client on the PC. 2. Select folders and a schedule (incremental or real-time). 3. Enter NAS credentials for a write-only backup account [Elektroda, Borygo123, #18438871; #18436895].
Edge case: will Google Drive or OneDrive also get encrypted by ransomware?
If the PC sync client sees encrypted files, it may sync them. OneDrive keeps 30-day version history, so you can roll back [Elektroda, Pawel1812, post #18438916]
What disks are best for 24/7 NAS duty?
Pick NAS-rated models like WD Red or Seagate IronWolf, built for ≤8-bay arrays and 180-300 TB/year workloads [WD, 2023].
