NAS server: Qnap TS-251d and Synology DS220 + / please help me choose.
takpoprostu 9132 12
Which NAS is the better choice for automatic phone photo/video sync, local media sharing, occasional public file sharing, and remote access: QNAP TS-251D or Synology DS220+?
Choose the Synology DS220+ if you want the more polished software ecosystem, because the thread says QNAP tends to be stronger in hardware/technical innovations while Synology is better refined in software and apps, including phone apps and photo-cataloging tools [#19226416] [#19227014] The DS220+ also gives you 2 LAN ports, but you only benefit from 2 Gbit/s link aggregation if your router or switch supports LACP; the Archer C80 mentioned in the thread does not [#19226416] [#19227417] [#19227654] For RAM, it is better to buy the cheaper base model and add compatible SODIMM yourself rather than paying extra for a preloaded version [#19227291] [#19227417] For internet access from outside the house, the replies say a strong upload matters most; a public IP is not strictly required, but a fixed public IP and better upload make things much easier [#19226416] [#19227014]
  • Synology photo sync and media sharing recommendation
    #1 19226201
    takpoprostu
    Rate: 18
    I have no experience with NAS servers. So please help me with my choice.
    I would like removable RAM and these two models are relatively inexpensive and have this option. I would like them to be simple to configure and have a good amount of online support.
    What I need it for:
    - First and foremost, I want to be free of Google Photos. I want photos and videos from my wife's phone as well as mine to automatically sync to the NAS. It matters to me that I can mark a few folders for syncing on my phone.
    - A local media server - so that the photos and videos stored on the NAS, as well as those synced from the phones, I can easily view on the nVidia SHIELD attachment, or another TV in the house. Perhaps as a samba network drive?
    - Cloud, I would also like to exchange files publicly. Not on a regular basis, but when I occasionally upload something for a client so I can make it available for download.
    - As an extra drive on my computer so I can keep some data there that I would need away from home as well as at home.
    Which software and device to bet on: QNAP TS-251d or Synology DS220+?
    Synology favored for software and dual LAN ports
    #2 19226416
    KOCUREK1970
    Help: 3862
    Rate: 5490
    QNAP, always the technical innovations, worse with the software.
    Synology the other way round, not necessarily hardware top of the range, but software much more refined.
    I would choose Synology - it has 2 LAN ports (the lack of USB can be expanded in the server with a HUB, and the LAN port as a backup or second is difficult to implement a simple and cheap solution).
    As for accessing the server from the internet - here you must have a strong upload.
    A public IP is not necessary, although it makes things much easier, especially a fixed public IP with strong upload :wink: .
  • Synology chosen despite limited upload speed
    #3 19226835
    takpoprostu
    Rate: 18
    So bet on Synology in your opinion, thanks for your opinion. I understand that I can also find an app in DSM for cataloguing photos by date etc. I kept beating myself up with the thought of buying another GB package in the google cloud, well I prefer to have everything at home though.
    As for the internet, well, that's where the problem is so far. There is a fixed IP - cable. Although the download is usually about 450-480 Mbps, the upload is unfortunately about 15-18 Mbps, but for my needs so far it is enough I think. They are planning to connect me to the fibre in the near future.
  • Recommend fixed public IP and higher upload for fiber
    #4 19227014
    KOCUREK1970
    Help: 3862
    Rate: 5490
    takpoprostu wrote:
    I understand that also in DSM I can find an application for cataloging photos by date etc
    Of course I do and, in addition, there are also alternative addresses with applications (not all probably work, but around 90% for sure):
    http://packages.synocommunity.com/
    http://packages.pcloadletter.co.uk/
    http://synology.acmenet.ru/
    http://www.cphub.net/
    http://www.hildinger.us/sspks/
    https://synology.emby.media/
    http://spk.unzureichende.info/
    https://packages.page81.net/
    http://spk.synologyitalia.com/
    http://packages.jdel.org/
    http://syno.dierkse.nl
    http://www.brigittehelsen.be/plexconnect/
    http://synology.nimloth.pl/
    https://synology.cambier.org/
    http://synology.nzbusenet.com/
    https://get.filebot.net/syno/
    http://synology.sysco.ch/
    Synology also has apps for your phone in the Google shop.
    takpoprostu wrote:
    What about the internet, well, here a small problem so far. The fixed IP is - cable. Although the download usually about 450-480 Mbps, the upload unfortunately about 15-18 Mbps, but for my needs so far is enough I think. In the near future I plan to get a fibre-optic cable.
    20 Mbps isn't crazy, but it's always something.
    And if going fibre, aim for a fixed public IP and a big upload too.
  • Raid1 drives may have different power-on hours
    #5 19227144
    takpoprostu
    Rate: 18
    KOCUREK1970 wrote:
    Synology also has an app for your phone in the Google shop.
    Now I so glance that Qnap also has something there for photos. I'm counting... counting...
    The Qnap TS251D with 4 GB RAM is PLN300 cheaper than the Synology. I would almost have a 4TB drive for the first one (planning 2x 4TB in raid1).... Well, and they are very similar in terms of computing power. Would I to use the better potential of the Synology DMS you write about.
    And do you have any idea if the drives in Raid1 - will have the same number of working hours? If one drive is working and the other a backup - will the backup have the same number of hours as the first drive?
  • Consumer drives unsuitable for RAID arrays
    #6 19227291
    KOCUREK1970
    Help: 3862
    Rate: 5490
    takpoprostu wrote:
    Qnap TS251D with 4 GB RAM is PLN300 cheaper than Synology.
    This Qnap has 1 network card and the Synology has 2.
    With more RAM it's not worth buying - you're overpaying and quite a lot, buy a cheaper one with less RAM and add it yourself.
    takpoprostu wrote:
    will the drives in Raid1 - have the same number of hours of operation ?
    If new then yes and if used, then each as many as they have been scooped solo.
    takpoprostu wrote:
    will the backup have the same number of hours as the first drive ?
    As the paragraph above.
    The operating hours of a given disk are not cloned.
    Such a small note - the disk should be strictly matched to the server in question, and if you want RAID, practically only PRO/Korpo versions come into play. The drive must have the right mechanisms, software for RAID.
    The most ordinary consumer disks are not suitable for creating arrays, and even if it works, there is no guarantee that not only the backup will fail, but the entire volume will be mechanically damaged.
  • Used WD Red drives with 9000 hours considered lightly used
    #7 19227344
    takpoprostu
    Rate: 18
    KOCUREK1970 wrote:
    Consumer drives such the most ordinary ones, are not suitable for creating an array, and even if it works, there is no guarantee that not only the backup will fail, but the entire volume will be mechanically damaged.
    Yes yes, I know about that. That's why I'm aiming for WD RED by checking the compatibility list on the Synology and Qnap manufacturer's website. I'm also wondering about used drives. I'm thinking that a WD RED like this, which has 9,000 hours of service, is, as one would say in car slang, "barely touched".
  • Used drive health depends on start-stop and reallocated sectors
    #8 19227354
    KOCUREK1970
    Help: 3862
    Rate: 5490
    takpoprostu wrote:
    I think that a WD RED with 9,000 hours on it is, as car slang would say, "barely touched".
    Don't look at the hours worked - it will be laaaaata before it cranks out 2 million hours.
    Look at the number of start/stops the motor mechanism has made, how many times the heads have parked, look if there are any relocated sectors on the drive, look if the mechanism hasn't allocated or excluded some surface cluster, if there's been a drive shock, if any overload sensors have gone off, etc.
    The life of a used drive is the least of your worries.
  • Dual-port NAS would exceed router bandwidth limits
    #9 19227368
    takpoprostu
    Rate: 18
    And do you think I will use the potential of two slots? Because there are only 4 of them in total on my TP-Link Archer C80 router. Because I understand that it would take me two ports, each has 1gig, so I would have a bandwidth of 2 Gb, so I would have a throat of over 200 Mbps yes?
    And as for increasing the RAM, good point - thank you. I'm looking at RAM prices now and indeed another 2GB is PLN49. Whereas the price difference when buying a 4/2GB NAS from e.g. Qnap is almost 100PLN.
    LACP needed for 2 Gb link aggregation
    #10 19227417
    KOCUREK1970
    Help: 3862
    Rate: 5490
    takpoprostu wrote:
    And do you think I would use the potential of two ports? Because in total there are only 4 of them in my TP-Link Archer C80 router. Because I understand that it would take me two ports, each has 1gig, so I would have a bandwidth of 2 Gb, so I would have a throat of more than 200 Mb/s yes?
    To be of 2Gb ports, you would need LACP (Link Aggregation) support, so in your case it would have to be supported by either this TPlink or some switch. The 2 ports also mean that you can distribute resources in such a way that they are unreachable for someone because on another port a different IP.
    takpoprostu wrote:
    As for increasing RAM, good point - thank you. I'm looking at RAM prices now and indeed another 2GB is PLN49. Whereas the price difference when buying a 4/2GB NAS from e.g. Qnap is almost 100PLN.
    This RAM is nothing more than SODIMM dice, i.e. the ones for your laptop. You just need to pay attention to whether the RAM you need is low voltage/regular, whether it's DDR3/DDR4 and how many memory banks it has on the PCB side of the dice.
  • Archer C80 lacks LACP link aggregation support
    #11 19227654
    takpoprostu
    Rate: 18
    KOCUREK1970 wrote:
    For there to be 2 2Gb ports, you need LACP (Link Aggregation) support, which in your case would have to be supported by either this TP-Link or some switch. The 2 ports also mean that you can distribute resources in such a way that they are unreachable for someone else because on another port a different IP.
    And this is my Archer C80 is a very basic router. It certainly doesn't have that. There is no information on the web that it has this option either.
  • ASUSTOR AS5202T and QNAP TS253D alternatives
    #12 19361943
    fuzel
    Rate: 23
    Hi, I've been looking for some info for myself recently as I've also decided to buy a server. I was also considering the Synology220+, but comparable in price and probably a bit better is the ASUSTOR Nimbustor 2 AS5202T.
    And then there's the QNAP TS253D with 2 2.5Gb/s LAN ports. You can also buy a remote control for pennies. RAM is also not expensive if 4GB is not enough for you.
    These are the facts, although I am certainly not a network expert.
  • #13 19419625
    xurc21
    KOCUREK1970 wrote:
    Of course they do, and in addition, there are also alternative addresses with applications (not all probably work, but around 90% for sure):
    Actually, many of these servers work, but an up-to-date list + search engine can be found at https://search.synopackage.com/sources.
The discussion revolves around choosing between the QNAP TS-251D and Synology DS220+ NAS servers for personal use, particularly for photo and video storage, local media serving, and occasional file sharing. Users highlight the importance of removable RAM, ease of configuration, and online support. Synology is favored for its refined software and dual LAN ports, while QNAP is noted for its cost-effectiveness. Concerns about internet upload speeds and RAID configurations are also addressed, with recommendations for using compatible WD RED drives. Alternatives like ASUSTOR Nimbustor 2 AS5202T and QNAP TS253D are mentioned for consideration.
