Grandin LD39C25 Endless On/Off Cycle: Software Issue? Get Software Solutions Here!
FlorinALB 4608 4
  • #1 18435202
    FlorinALB
    Hi, I have a problem with a Grandin LD39C25. It turns on and off endlessly. Do you think it's a software problem? Where can I get the software?
  • #2 18435898
    billobirillo
    Help: 338
    Rate: 803
    report the complete serial number
    it should start with G9...
  • #3 18437481
    FlorinALB
    G920B3BF1VP384075
    billobirillo
    Help: 338
    Rate: 803
    - unplug the power cord
    - copy the file SISEU23X8M.bin on an empty usb stick fat32 formatted
    - insert the usb stick in the tv and reconnect the power cord
    - look at the standby led... at the beginning it flashes slowly, after about 1 minute it doubles the speed: update completed
    - unplug the power cord and the usb stick and wait until the standby led turns off
    - reconnect the power cord and turn on the tv: it will restart in first installation mode
    if it doesn't work with the usb recovery, rewrite the spiflash U5 using the file SISEU23X8M.bin
    here is the software (V20.0167) for GRANDIN LD39C25 LED39TC1700E
    • SISEU23X8M.bin (6.87 MB) You must be logged in to download this attachment.
  • #5 19620048
    yasine
    THANK YOU FOR A DUMP
