Sharp LC-40LE343E LED Flashing Issue: FW Installation, USB, Main Board 17MB70-5P V1 050511
amennone 4371 3
  • #1 17314487
    amennone
    As for the ignition, the red to green LED flashes at infinity.
    The feeds are regular.
    I have planned
    U103 = 24C64
    U107 = M25P40
    Unsuccessful .
    I'm trying to load the following FW: LC-40LE340E_Software_Version_V-0-12-3.
    I performed the installation procedure fw, when I turn on the tv
    from the mechanical switch it is positioned in stand by. (red LED on). turning on by button
    power the LED flashes from green to red and does not read anything from the usb.
    I changed multiple usb sticks, formatted in fat 32 and copied the files to the usb root, but nothing changed.
    Procedure made several times with usb from 1 gig, fat 32, ignition plus OK button, switching on with button from remote control P +.
    The pen is not read.
    The voltage on the usb port is present, 5 volts.
    These data:
    Main board: 17MB70-5P V1 050511
    Power: 17PW07-2
    Samsung Invert: SSL400 0E2B rev0.1
    Panel: Samsung LTA400HM13
    Tuner: LG TDTC-G605D
    Thanks and good job .
  • #2 17332916
    amennone
    nessun aiuto ?
  • #3 17369811
    STELY
    Rate: 13
    Resolder both transformers on inverter board.
    Update software!!
    Replace u39(mp2012), can be replaced with AMS1086CM18.
  • #4 17541479
    shabnam9
    This is good discussion about the LED Flash.
