Bosch WLG24261PL/05 - How to Remove Powder Drawer Front for Access?
michalejo 38310 8
  • #1 18535225
    michalejo
    Rate: 19
    Greetings Forum Members,
    Series4 VarioPerfect washing machine, after washing the drawer my wife put the liquid compartment in reverse and slid the drawer closed. As you can guess, I am unable to slide it back out. I would like to detach the drawer front, get to the screws and remove the whole drawer from the inside. The question is, can it be done this way, is the drawer front glued on or is it on snaps?
  • #2 18535370
    Kenworth 18
    Help: 2442
    Rate: 3749
    You need to remove the top cover and disconnect all the hoses and remove the detergent dispenser.
    Fortunately, it is made up of 2 parts and after separating the 2 halves you will slide out the drawer and by the way you can clean the rain shower or top cover of the dispenser: https://north.pl/karta/komora-pojemnika-na-pr...alki-bosch-wlg24261pl-05,3EZ-J5-C2MM-Y0G.html
    https://north.pl/karta/pokrywa-komory-na-pros...alki-bosch-wlg24261pl-05,LCZ-JZ-C2MM-Y0G.html
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    michalejo wrote:
    I would like to unhook the drawer front, get to the screws and remove the entire drawer from the inside.
    You will sooner break something than take it apart.
    I would try by removing the top of the tray compartment, without removing it from the washing machine.
  • #4 18535415
    michalejo
    Rate: 19
    Thanks for your reply,
    Unfortunately I can't dismantle the detergent dispenser if there is a drawer in it that I can't remove. If I could detach the drawer front then the whole dispenser together with the locked drawer will be removed from the top and I can disassemble it on the hooks. In the meantime I have managed with a torx bit to unscrew the 3 screws hidden by the drawer, but the drawer front still holds me....
  • #5 18535766
    Kenworth 18
    Help: 2442
    Rate: 3749
    You are right, Mr Administrator. I have never been a saint and even less do I pretend to be one.
    I apologise to the author of the topic and thank my colleague @mrice for guiding the author to the correct action.
  • #6 18767993
    justiix
    Rate: 16
    How did you manage to remove the drawer? I have the same problem....
    mrice
    Help: 2213
    Rate: 6951
    I have already stated how to break into it. The author must have grasped the problem a long time ago, but he didn't have the grace to mention it anymore, because why should he....
  • #8 19391093
    monia1661989
    Rate: 10
    Anyone can help? Unfortunately but I have the same problem :( .
    Moderated By mrhari:
    Please read with understanding the topic from the beginning.
    The advice has already been given.
    madstorm
    Rate: 66
    The suggestion with removing the drawer front is very helpful, but it is not obvious enough to some that I leave a very helpful instructional video on how to go about it and unlock the door:
The discussion revolves around the difficulty of removing the powder drawer front of a Bosch WLG24261PL/05 washing machine after it was incorrectly reinserted. Users suggest that the drawer front can be detached to access the screws and remove the entire drawer. One user advises removing the top cover and disconnecting hoses to separate the two parts of the detergent dispenser, allowing for cleaning and access. Others express similar frustrations with the stuck drawer and seek solutions. A video tutorial is mentioned as a helpful resource for unlocking the drawer front.
