Bosch SD 13J1b dishwasher: How to remove and replace the front furniture panel?
bul01 42608 1
  • #1 8273203
    bul01
    Rate: 19
    I have a built-in dishwasher Bosch SD 13J1b and I do not know how to pull off the housing wall on the front of the dishwasher ? The furniture knob for opening has almost broken off so I wanted to replace it with a new one, but I do not know from which side to do it.
    I searched on the forum but found nothing on this topic. Thank you in advance for your help
    Andrzej G
    Home appliances specialist
    Help: 110
    Rate: 290
    If the furniture front has been fixed as the manufacturer intended, then when you open the dishwasher door you will see two holes in it at the top on the sides, where screws are placed in a recess. When you loosen them counterclockwise, the tabs attached to the front plate will unlock. Then tilt the plate starting from the top, because at the bottom it is hooked on special hooks. Then by lifting it slightly upwards you unhook the hooks and the plate is removed.
