Strange Humming Noise from Fuse Box in Old Building: B10 & B16 Fuses, Oven & Heater Issues
Phate25 56721 15
Why does my fuse box hum when the oven, dishwasher, or washing machine heater is running, and can I fix it by replacing the main fuse myself?
The humming is most likely coming from the overloaded or poorly mounted main C16 breaker/isolator, and you should have an electrician inspect the installation rather than just replacing the fuse [#18573668][#18575433] When the oven and dishwasher run together, the load can exceed 5 kW, which is about 22 A, so a 16 A main protection device can vibrate or hum under load [#18573668] The fact that the box is mounted “upside down” can also increase the chance of buzzing when heavily loaded [#18575492] As a temporary precaution, you can tighten all terminal clamps with an insulated screwdriver and look for burn marks or melted insulation, but do not rely on this as a full repair [#18575477][#18573682] Replacing the main protection with another device is not the real fix; the installation needs a proper condition check and likely a redesign of the main protection arrangement [#18575433][#18575748]
  • #1 18573627
    Phate25
    Rate: 12
    Recently, I have noticed a strange noise coming from the fuse box. I would like to add that nothing has been changed for a long time and nothing like this has happened before.
    We live in an old building, so for sure the electrical installation is very poorly done and I know it. We did not do this installation ourselves.
    In the current situation (state of the epidemic), I do not want to call an electrician without a serious problem, so maybe I will be able to do something myself (e.g. just replace one of the fuses)
    The case is as follows:
    I have seven separate fuses (circuits)
    1 - Fuse B10 - Lights and bell
    2 - Fuse B10 - Sockets
    3 - Fuse B10 - Sockets
    4 - Fuse B16 - Oven, hood, dishwasher
    5 - Fuse B10 - Refrigerator
    6 - Fuse B10 - Sockets in the bathroom (including the connected Washing machine)
    7 - Fuse B10 - bathroom lights
    G - Main fuse that cuts off the current in all of the above - C16
    When I turn on the oven, while the heater is on, you can hear such a strange "buzzing / humming" from the box, when I turn on the dishwasher at the same time, the humming noise becomes louder. At first I thought that the problem was in the fuse on circuit No. 4, but yesterday I noticed that when the washing machine itself is working, I also hear a soft humming noise as long as the heater is working (the washing machine is on circuit No. 6).
    I think the problem is somewhere in this main fuse (wrongly selected, burns out?)
    I will be able to solve it myself or is an electrician's visit necessary?
    Thanks in advance for your help
  • #2 18573668
    Grendel
    Help: 35
    Rate: 244
    If this phenomenon occurs when loading different circuits, it would indicate G or C16.
    The circuit breaker has 2 types of tripping - overload (thermal) and short-circuit (electromagnetic).
    Under heavy loads, the anchor may vibrate in the instantaneous trip circuit.
    Turning on the oven and dishwasher is a load of more than 5 kW, so
    the consumed current is 22 A, which already overloads the main protection circuit.
  • #3 18573682
    zbich70
    Help: 1171
    Rate: 6666
    I suggest an electrician. Alternatively, you can remove the grille and look for burns, melted insulation. Upload a photo.
  • #4 18573728
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    From time to time, miniature circuit breakers hum under load. This is not something to worry about, everything is fine.
    The only thing you can attach to is:
    It is not something that poses any threat to life (except for a lump in the dark) or property, but why limit yourself. Overcurrent switches have this to themselves that if there is a short circuit in the installation, they all turn off in turn, i.e. one of the lighting and the C16 one. Then there is darkness throughout the apartment.
    Perhaps the meter cable is thin and that's why someone used something like that.
    What is the pre-meter protection and what is the diameter of the cable from the meter. Perhaps this apparatus can be replaced with a switch disconnector.
  • #5 18573768
    Grendel
    Help: 35
    Rate: 244
    Ktoś_tam wrote:
    The overcurrent switches have this feature that when there is a short circuit in the installation, they all turn off in turn, i.e. one of the lighting and the C16 one. Then there is darkness throughout the apartment.
    That's it - with this arrangement there is no selection. If the fault loop impedance is 1 ? (and usually it is less), the fault current will be 230 A.
    On the other hand, the instantaneous tripping currents of individual WSs are as follows:
    B10 -> 30-50 A.
    B16 -> 48-80 A.
    C16 -> 80-160 A.
    So there will always be 1-7 and the main one.
  • #6 18573788
    Phate25
    Rate: 12
    The installation is so combined from what I know. I still have an old aluminum installation in front of the "G" fuse. The fuse in the corridor in front of the apartment, where the meter still has a 25A fuse
    Just when I open the fuse box, I don't see any sparking or a melted cable. Unless I have to open and download something even deeper.
    PS
    And yes, I know that it is installed upside down - apparently it was too much of a complication (due to the old aluminum installation) with connecting it normally.
  • #7 18574906
    retrofood
    Help: 1140
    Rate: 4797
    And why tell electricians such fairy tales? :D "Too much complication" ... No! It was an ordinary bungling and laziness of the performer (because he cannot be called an electrician). No complications.
    And a total lack of knowledge, even the basic one.
  • #8 18575379
    Phate25
    Rate: 12
    Of course, I completely agree with you. I am not an electrician and at first glance I can see that this box is not very professional.
    At the moment, when there is a general problem with access to services and service providers, I would like to simply solve the problem so that it does not get worse.
    So you bet on the problem with the main fuse "G"? Replace it with a new one? The same, i.e. C16 or another?
  • #9 18575433
    retrofood
    Help: 1140
    Rate: 4797
    I visit an electrician and inspect the installation to simply inventory its condition and identify problems to be solved. Because humming and various sounds are only one symptom of the problem, not the problem itself. You will definitely not solve it by replacing the main security. It's time to get used to this thought.
    If you entered the region where you are from, maybe even one of the writers could undertake such an assessment.
  • #10 18575446
    Phate25
    Rate: 12
    We live in Poznań
  • #11 18575477
    retrofood
    Help: 1140
    Rate: 4797
    For now, it remains to tighten all the clamps, because you won't do any more yourself. For safety, this should be done with an insulated screwdriver. And wait for better times.
  • #12 18575492
    Grendel
    Help: 35
    Rate: 244
    The design of the circuit breaker looks like this:
    where:
    1 Drive lever
    2 Castle
    3 Fixed contact and moving contact
    4 Connection terminals
    5 Thermobimetallic release (overload)
    6 Adjustment screw
    7 Release, electromagnetic (short-circuit)
    8 Extinguishing chamber (to extinguish an electric arc)
    When placed "upside down", you increase the chance of buzzing when heavily loaded due to the opposite effect of gravity on the moving part of the electromagnetic trigger.
    Besides, as I wrote before, this switch can be significantly overloaded in your case.
    Compare the effect with this: https://www.youtube.com/watch?time_continue=3&v=K9aMlBzZ0VM&feature=emb_logo " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://www.youtube.com/watch?time_continue=3&v=K9aMlBzZ0VM&feature=emb_logo
    The best solution would be to replace C16 with an isolating switch, which was written by a colleague Someone_tam
  • #13 18575566
    Phate25
    Rate: 12
    The sound from this movie is similar (although it is known that it is not the same because in my case it is a bit more muffled)
    I am a bit puzzled by what you write about the overload of the switch - I can also hear this sound (although quieter than when the stove itself works) how the washing machine itself works. Is the washing machine itself overloading my system?
    I'm gonna try to tighten the screws tonight with these insulated screwdrivers.
    Could you give me a specific model of the switch disconnector that should be installed for my installation?
  • #14 18575634
    retrofood
    Help: 1140
    Rate: 4797
    When everything is normal, it doesn't overload. But if something is falling apart ...
    I once met with an accident that inserting a plug from an ordinary radio receiver into the socket caused the overcurrent protection B 16A to be activated. It does not mean that the radio took more, the fuse was just blown so that it reacted to a gust of wind.
  • #15 18575748
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    We could, but for what? It has to be replaced by an electrician, not you. For this you need to either unseal the pre-meter protection or make it live. So as you can see, this job is probably not for you. The electrician will know what to do and what to buy. These property cameras do not cost themselves, so even if they add a double as much margin, you will not get poor, or at least the electricity will not kill you.
    What you need to buy exactly and do it is best to see it live, I will not do it remotely.
  • #16 18575779
    Grendel
    Help: 35
    Rate: 244
    As for the type of disconnector, there is plenty of it: Link
    I removed the redundant. / zbich70 /
    It would be good with a fuse: Link
    but it is 1.5 modules wide so it may be running out of space.
A user reported a strange humming noise from their fuse box in an old building, particularly when using high-load appliances like the oven and heater. The installation includes multiple B10 and B16 fuses, with a main C16 fuse. Responses indicated that the noise could be due to overload or issues with the main fuse. Suggestions included inspecting for burns or melted insulation, tightening connections, and considering the replacement of the main fuse with an isolating switch. It was emphasized that the humming is often a symptom of underlying issues, and professional assessment is recommended for safety.
TL;DR: Oven+dishwasher load ≈22 A (>5 kW); "Under heavy loads, the anchor may vibrate"—so MCBs can hum. For occupants of older flats hearing fuse‑box buzz, tighten terminals, stagger heaters, and plan to replace the main C16 with an isolator. [Elektroda, Grendel, post #18573668]
Why is my fuse box humming when the oven or dishwasher runs?
MCB humming often comes from the magnetic trip vibrating under heavy load. "Under heavy loads, the anchor may vibrate in the instantaneous trip circuit." Running an oven and dishwasher together adds about 22 A (>5 kW). That can overload a C16 main and accentuate the buzz. [Elektroda, Grendel, post #18573668]
Is a humming breaker dangerous, or normal?
Some miniature circuit breakers hum under load, and that alone is not hazardous. But treat new noises as a diagnostic clue. "Humming and various sounds are only one symptom of the problem, not the problem itself." Replacing the main alone will not solve it. Arrange an electrician’s inspection. [Elektroda, retrofood, post #18575433]
Can running oven and dishwasher together trip my main breaker?
Yes. Together they draw over 5 kW, about 22 A at 230 V. That exceeds a 16 A main breaker and can cause buzzing or tripping. Avoid simultaneous heating cycles until the main device is changed. [Elektroda, Grendel, post #18573668]
Why do multiple breakers trip at once during a fault?
Lack of selectivity means downstream B‑curve breakers and an upstream C16 can both trip during a fault. With 1 Ω loop impedance, fault current can hit about 230 A. Instantaneous thresholds: B10 30–50 A, B16 48–80 A, C16 80–160 A. Expect a branch breaker and the main to open together. [Elektroda, Grendel, post #18573768]
Does mounting a breaker upside down increase humming?
Yes. An upside‑down MCB increases the chance of buzzing under load. Gravity acts opposite to the magnetic trip's moving part, making vibration more likely. Correct orientation and proper loading reduce noise. Consider replacing the main breaker with an isolating switch. [Elektroda, Grendel, post #18575492]
What can I safely do myself today?
Limit DIY to tightening terminal clamps using an insulated screwdriver. Do not replace breakers yourself.
  1. Switch off the main C16 and unplug high‑load appliances.
  2. Remove the cover and tighten each accessible terminal clamp.
  3. Replace the cover, restore power, and test loads one by one. [Elektroda, retrofood, post #18575477]
How do I visually check for damage inside the panel?
Remove the grille or cover and look for burn marks or melted insulation. Take clear photos before touching anything, then share for assessment. If you see damage, stop and arrange a visit. [Elektroda, zbich70, post #18573682]
My washing machine alone causes a quiet hum. Is that an overload?
Usually not. "When everything is normal, it doesn't overload." A failing breaker can misbehave and trip from tiny loads. One expert saw a B16 trip just inserting a radio’s plug. Have an electrician test and replace any faulty device. [Elektroda, retrofood, post #18575634]
Should I replace the main C16 breaker with an isolator?
Yes, as a planned upgrade. "The best solution would be to replace C16 with an isolating switch." This removes overcurrent tripping from the main device. Your electrician will specify and install the correct isolator. [Elektroda, Grendel, post #18575492]
Which isolator or fuse‑disconnector fits tight space?
An ETI STV‑D02 1p 63 A fuse‑disconnector is a compact option. It is about 1.5 DIN modules wide, so space may be limited. Confirm fit with your electrician and panel dimensions. [Elektroda, Grendel, post #18575779]
Do I need an electrician to replace the main device?
Yes. The work requires unsealing pre‑meter protection or working live. That is not a DIY task. Hire an electrician to choose and fit the isolator safely. [Elektroda, Ktoś_tam, post #18575748]
What is the pre‑meter protection in this setup?
A 25 A fuse is installed before the apartment’s meter in the corridor. Keep this in mind when planning loads and upgrades. [Elektroda, Phate25, post #18573788]
How can I estimate my total load and avoid trips?
Check each appliance’s nameplate power, then stagger heating loads. Oven plus dishwasher exceeds 5 kW, about 22 A at 230 V. That can exceed a 16 A main. Avoid simultaneous heating cycles, especially in older installations. [Elektroda, Grendel, post #18573668]
Where exactly is the hum coming from?
From the breaker’s electromagnetic trip and arc chamber components vibrating under load. A shared video demonstrates typical MCB buzzing under heavy load. Inverted orientation increases the effect. An isolator avoids making that noise at the main device. [Elektroda, Grendel, post #18575492]
