  • #1 18633361
    junior19014
    What is this program, I am afraid if I have something for a long time, if not new. I know there are "answers" to google but I can't deduce much there. Also, a short answer is enough, remove / block or leave.
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    You mean this entry / process? -> [ProductAuthenticationService] => C: \ Users \ your_username \ AppData \ Roaming \ ProductAuthenticationService \ pas.exe [1004072 5/17/2019] (ResolveDevOps Limited -> ResolveDevOps Limited)
    You can disable it in msconfig / task manager.
  • #3 18717644
    kuchar.84
    I also started to be interested in the subject, because, as above, I was wondering where it comes from.
    At the beginning I checked the file on VirusTotal, there I got the information that there is no fear - (0/72) detection.
    It is really hard to find on the Internet what it is and what it is for, but somewhere I finally managed to find a similar program from another manufacturer and they gave me information via e-mail what it is. Basically it's some DRM or something, different manufacturers or application developers add it to their programs. This version above, from what I found out, installs with some cs: go plug / changer. I asked and got information that the plug / changer needs it to work, because the license is checked using this program.
    As a colleague wrote above - it can be removed or turned off when we no longer use the program with which it came, but to use it again - it must be turned on, otherwise an error checking the license will appear. In the end, I found that you can actually leave it, because the program is only awake and does not do anything important until you need it.
    To sum up - background service for checking licenses for other programs.
