Numerous Svchost Processes in Windows 10 Pro: ESET Smart Security, Dr. Web, Malwarebytes
Magic_moon 8844 10
Why are there so many svchost processes in Windows 10 Pro, and is it normal?
Those svchost processes are normal Windows system services, so leave them as they are [#16564002] If you want to verify what each one is hosting, use Process Explorer, open the process properties, and check the Services tab to see which services it started [#16563928][#16563952] The listed examples were Cryptographic Services, Windows Management Instrumentation, State Repository Service, Audiosrv, DPS, WpnService, stisvc, netman, BITS, and WpnUserService, and they were identified as system services [#16563999] It was also noted that they do not use much memory, so their number alone is not a problem [#16563928]
  • #1 16563734
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    Hello. For some time I have been observing Svchost processes in Windows 10 and they are getting more and more. I have the original Windows 10 pro 64 bit operating system and the original ESET Smart Security antivirus. I did a scan with Dr, web and malwarebytes and found nothing. Maybe colleagues will know what's going on.
    Numerous Svchost Processes in Windows 10 Pro: ESET Smart Security, Dr. Web, Malwarebytes Numerous Svchost Processes in Windows 10 Pro: ESET Smart Security, Dr. Web, Malwarebytes
  • #3 16563904
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    Here is the attachment.
    • Addition.txt (32.25 KB) You must be logged in to download this attachment.
    • FRST.txt (111.27 KB) You must be logged in to download this attachment.
  • #4 16563912
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Read again what I wrote and do EVERYTHING.
  • #5 16563922
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    I've already added.
  • #6 16563928
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Use Process Explorer and check what services run these svchosts. Fortunately, they do not use much of the frame, so even such a quantity does not bother you at all, the more that:
    Percent of memory in use: 25%
    Total physical memory: 16265.05 MB
    Available physical memory: 12036.93 MB
  • #7 16563940
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
  • #8 16563952
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Why are you posting this screen? I wrote what you have to do:
    In process explorer you select the process properties, service tab and check what it started.
    Check out of 10 random, preferably those with the largest PIDs and specify what services they have started.
  • #9 16563999
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    1.Cryptographic services
    2.Windows management instrument
    3. State repository service
    4. Audiosrv Windows audio
    5. DPS diagnostic policy service
    6. Wpn service WNS notification status service
    7. stisvc Windows image acquisition
    8. netman network connection
    9. bits background intelligent transfer service
    10.wpn user servive user notification service
    What do you think ?
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Leave it as it is, it's all system services.
  • #11 16564193
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    I understand and thank you colleague kolobos for your help.
The discussion revolves around the increasing number of Svchost processes observed in Windows 10 Pro, specifically with ESET Smart Security antivirus installed. The user conducted scans with Dr. Web and Malwarebytes, finding no malware. Participants suggested using Process Explorer to identify the services associated with the Svchost processes. The user reported several services running under these processes, including Cryptographic Services, Windows Management Instrumentation, and Background Intelligent Transfer Service. Ultimately, it was concluded that these processes are standard system services and do not indicate a problem.
