PHILIPS MCD388: Adding AUX Input to Wireless Subwoofer (Using Jack Cable) - Schematic Guide
tiesto23 2175 1
  • #1 18652740
    tiesto23
    hi
    i have PHILIPS MCD388
    it have wireless subwoofer
    the dvd player i lost it
    i want to add aux in input to subwoofer and use it with jack cable not wireless
    this is schematic of amp board
    any sugg how to do it
    thnx PHILIPS MCD388: Adding AUX Input to Wireless Subwoofer (Using Jack Cable) - Schematic Guide
  • #2 18755813
    elektrodziarze1234
    Pins 2 and 4 on connector CN2 are the audio inputs. FL and FR are probably intended to be the left and right audio inputs, but they are simply connected together, so you only need to use one.
    If you do want to connect both the left and right inputs, you should add a series resistor to avoid causing issues with the rest of your audio system. Using a 1kΩ resistor on each input should be enough.
