[Solved] [Request] AYA A39CD3902 Firmware: TP.SIS231.P83 Chassis, C39OF13-E4-C Panel, G920A3XC2BV411332
jayunprobleme 3831 2
  • #1 18699672
    jayunprobleme
    Hello! I need your help.
    Brand: AYA
    Model: A39CD3902
    Chassis (motherboard or main components): TP.SIS231.P83
    Matrix / Panel (if present): C39OF13-E4-C(G1)
    Other (comments): G920A3XC2BV411332
    I need the firmware please
    billobirillo
    Help: 338
    Rate: 801
    usb recovery
    copy the file SISEU23X8M.bin on an empty usb stick fat32 formatted
    unplug the power cord
    insert the usb stick and reconnect the power cord
    look at the standby led, at the beginning it flashes slowly, after about 1 minute it doubles the speed, update completed
    unplug the power cord and the usb stick
    reconnect the power cord and turn on the tv: it starts in first installation mode
    if it doesn't work with usb recovery, then replace the spiflash and program it with the file SISEU23X8M.bin
    • AYA_A39CD3902_TP.SIS231.P83_C390F13-E4-C(G1).zip (5.58 MB) You must be logged in to download this attachment.
  • #3 18701821
    jayunprobleme
    Thank you very much, it worked!
