Mercedes 221 S-Class 2006 Radio Issue: Loss of Range & Stations After Engine Start - HELP!
biniomerc 4950 3
  • #1 18735448
    biniomerc
    Hello, I have a 221 s class 2006. I have a problem with the radio. When the engine is off, everything is ok. After starting the engine after approx. 2 minutes, the radio stops working, loses range and radio stations, rustles for long picks 1. After the engine is off, everything works immediately. HELP
    Added after 5 [minutes]:
    Hello all. There is no driving without a star.
    Separated from the topic: Welcome topic for new users - introduce yourself
    by ArturAVS on 03 Jun 2020 07:15
  • #2 18742057
    Mari@@@n
    Level 19  
    Help: 35
    Rate: 25
    Some interference probably won't help much but I will write in my W211 I have the same symptom after switching on the rear window heating, you would have to observe what turns on in the car at this time.
  • #3 18742099
    damian1115
    Level 37  
    Help: 393
    Rate: 904
    Mari@@@n wrote:
    Some interference after switching on the rear window heater,
    I have the same in Vectra C. I wonder what it can be.
  • #4 18742395
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    It is very possible that there is a problem with the amplifier or the antenna in the rear window. If you want, instead of the antenna on the radio, put a piece of wire and compare if it is better. It's a bit of trouble, but you have to start somewhere. If you want different advice, connect SD and do tests for radio and antenna. There are several of them there.
