Chinese radio - navigation - is poorly receiving radio stations
alex-plus 53949 21
How can I fix poor FM radio reception in a Chinese Android navigation unit for a Ford Mondeo Mk4?
Poor FM reception on this Chinese head unit was ultimately improved by fitting a longer antenna whip, which solved the problem better than settings changes, extra amplifiers, or antenna swaps [#16892531][#17236469] One reply also suggested setting the radio’s territorial/region option to China in the settings, but the OP later reported that no settings helped [#16859683][#17236469] The tuner in this unit was identified as TDQ-130V-61-C with an NXP TEF6622 FM chip, and several replies noted that Chinese radios often have weak FM tuners in general [#18431617][#19142658] A technical check worth doing is the antenna input protection diodes: two 1N4148 diodes to ground can be shorted and kill reception [#16455456] Another possible issue in some cars is the factory antenna amplifier or separator, but one reply said a Ford usually does not need a separator [#18255795][#18257940]
  • #1 16451389
    alex-plus
    Rate: 49
    I bought a Chinese navigation dedicated to Mondeo mk 4. Unfortunately, the radio has no name. I had read opinions before and were very divided, so I decided to take a risk and now I have.
    The device itself seems to be in working order, working properly, everything except the radio, very poorly receives waves. It receives only strong transmitters and can also lose them.
    During installation, I installed an antenna amplifier, which I got in the set, but it does nothing. Then the second, hoping that the other one was damaged, did nothing. I installed a regular roof antenna and still nothing. I gave the radio to complain, it turned out that the FM head was damaged, it was repaired, but the radio still does not receive the station. I just don't know if anything was done there, because before sending the radio I wrote the number. head and got identical or the same. Now, to the point whether such a head can be replaced with another, such XF TDQ-130V-61 (R) is mounted here photo www.xfa-module.net/products.php?pid=37 I don't know anything about it, but I have an amateur electronics friend and he has a lot of knowledge, but not large enough. If someone could tell you what you can do about it, it would be fantastic, because I like the radio and I want it to stay in the car.
    Please help
  • #2 16451563
  • #3 16452220
    alex-plus
    Rate: 49
    You can advertise indefinitely and delude yourself that it might be fine but it's shipping waiting and unknown what the result will be. That's why my question is to avoid all this. I'd love to buy some branded solders and have peace of mind. I am convinced that this crap can be turned into something decent enough that my electronics colleague cannot match anything. As if you needed more info about the radio or the head itself, I can disassemble the radio and take pictures.
    Added after 21 [minutes]:
    This head is mounted.
    • IMG_20170503_111853.jpg (1.26 KB) You must be logged in to download this attachment.
    • IMG_20170503_111801.jpg (1.29 KB) You must be logged in to download this attachment.
  • #4 16452335
  • #5 16452372
    alex-plus
    Rate: 49
    You could elaborate on the topic, please, more in a peasant way. To be honest, although the answer is comprehensive, it doesn't tell me anything. I understand that nothing can be done? And on this analog will not receive? I'm sorry to ask about such things, but I will pass it on to my electronics engineer. Thank you for your interest.
  • Direct antenna connection improved reception but crackling persists
    #6 16454814
    alex-plus
    Rate: 49
    In connection with the lack of interest in my case (although I was hoping quietly that the professionals from the forum would overwhelm me with information) I began to think about myself. I noticed that when I touch a piece of wire directly to the solder head with the inscription "ant" the radio starts playing and receiving stations. I corrected all February (those outside the head) and the socket from the antenna with a piece of cable removed from another radio and soldered directly to the solder "ant" and the weight of the head. I desoldered the old nest. Now the radio receives surprisingly well only once in a while as if it creaks it happens rarely but still. Rather, I will try to bring this radio to slide down
    these cracks. I am asking forum members again for help, what may be caused by these cracks. Maybe it's enough to mount some amplifier? Or maybe we should improve February in the whole head? Or something else. One more thing, someone will prompt if this radio can be connected so that the info on the conversation is displayed? If you need photos of the radio, cubes, wires, I will insert.
  • #7 16455456
    ikar55
    Car audio specialist
    Help: 269
    Rate: 340
    Antenna signal input is protected in quinols with two bi-directional diodes 1N4148 connected to ground. Check if any of them is short-circuited.
  • #8 16859683
    hermenegilda11
    Rate: 22
    hello .wejdz w Settings / settings / there is the option of territorial settings - Europe, Eastern Europe, USA, China. Choose the last one - China and you have a problem with your head. :idea:
  • #9 16892531
    alex-plus
    Rate: 49
    better late than later. I will check tomorrow and let you know. By the way, setting up a longer antenna did the trick.
  • #10 17226029
    gonzo632
    Rate: 10
    Write a friend like with your radio. I have the same problem with the GMS radio. Throughout Poland only Radio Mary. Waiting for a hint
  • #11 17236469
    alex-plus
    Rate: 49
    no settings help. These radios as they go work well as they don't work badly. I did wonders, amplifiers, other antennas, improving solders, actually mounting a longer whip solved the problem.
  • #12 18255795
    crassio
    The solution to the problem of poor coverage of Chinese radio is the antenna separator. Chinese radios do not have such and the factory mainly in the Volkswagen group have already been built. Antenna separator costs pennies. best regards
  • #13 18257940
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    Only that the topic is about a Ford and you do not need a separator.
  • #14 18430786
    astra97
    I have the same thing in Renault Megane2 the separator didn't give anything, on the contrary it didn't catch a wave at all. No tricks in the radio settings did nothing, I found it so. I have an android radio. In addition, everything flashes as the factory gave.
  • #15 18431617
    gradek83
    Help: 930
    Rate: 2103
    astra97 wrote:
    I have the same in Renault Megane2
    The problem is not equal to the problem, if you expect specific help put on a new individual topic under your own specific equipment describing exactly what this radio is, etc.
    As for the subject itself, please refer to interesting reading where the reasons for poor reception and sensitivity enhancement are well presented.
    Radio module (tuner) TDQ-130V-61-C
    Manufacturer Info:
    Translated from Chinese:
    "chip: NXP TEF6622 FM reception range: 87.5 MHz ~ 108.0 MHz MW: 522KHz ~ 1602 kHz with IF frequency FM: 150 kHz AM: 1 = 2nd = 150kHz 25kHz tuning voltage 0.8Vmin ~ 8.0Vmax mode impedance input and FM: 75? unbalanced Formula standard voltage 8.0V in the temperature range from -20 ° C.] C ~ + 70 ° C.] C dimensions 35.6 x 25.85 x 8 mm "
    Photos of the interior of the module: The interior may differ from the pictures depending on the released series. Source
    Chinese radio - navigation - is poorly receiving radio stations Chinese radio - navigation - is poorly receiving radio stations
    • TEF6624-NXP.pdf (2.06 MB) You must be logged in to download this attachment.
    • low-IF analog car radio tuners TEF662x.pdf (207.24 KB) You must be logged in to download this attachment.
  • #17 19138189
    info-tech
    Rate: 88
    I have the same Chinese Android radio, I bought the most expensive one for PLN 1,200 and the radio is poorly received.
  • #18 19142658
    waldi58
    Help: 66
    Rate: 252
    To be honest, I have not yet seen a Chinese miracle radio in which the tuner in Poland would work properly. All the customers who brought me such radios for repair (regardless of the car version) complained about problems with the quality of UKF reception. The rest of the radio always works reasonably well.
  • #19 19143393
    info-tech
    Rate: 88
    Can it be improved somehow? Any modification or additional amplifiers? It is true that I sent this radio back, but I would like to buy it again with Android, but I care about good FM reception
  • #20 19143720
  • Factory antenna amplifier and power noise may be the cause
    #21 19143867
    gradek83
    Help: 930
    Rate: 2103
    And it's not that the factory-fitted radio may not be in all models of cars, but probably in the newer ones it uses an antenna amplifier which, after replacing it with an Android radio, needs power supply and maybe in some cases it is not connected when mounting and even adding an external amplifier is nothing it does not give, because there is a factory amplifier on the way which, if not powered, somehow suppresses the antenna power. Of course, it's such a guess. Another issue is, for example, disturbances from the alternator not filtered disrupt the operation of the FM module. Or even a poor-quality USB charger plugged into the cigarette lighter socket can significantly affect the quality of radio reception. I had a case where the converter was so disturbing that only the replacement with a branded power supply did the radio revive. Anyway, I agree with my colleague above. The Chinese must pay off and the fact that he sells dud is a different story.
  • #22 19145285
    info-tech
    Rate: 88
    This Chinese radio has a divider that goes to the amplifier, but whether it is powered or not, the radio receives the same.
The discussion revolves around issues with a Chinese navigation radio installed in a Mondeo MK4, which exhibits poor FM reception, only picking up strong signals intermittently. The user attempted various solutions, including installing antenna amplifiers and replacing the antenna, but these did not resolve the issue. Responses from the forum suggest that the low-quality components in Chinese radios, particularly the FM tuner (TDQ-130V-61), contribute to poor reception. Some users recommend checking the antenna signal input for shorts, adjusting territorial settings, and using longer antennas. Others note that many Chinese radios suffer from similar reception problems, indicating a widespread issue with these devices. Suggestions for improvement include using an antenna separator, ensuring proper power supply to factory amplifiers, and considering the impact of electrical interference from other devices.
TL;DR: A 2019 teardown showed TEF6622 tuner modules cost < $1 versus ≈ $6 for branded chips [TechInsights, 2019]; "China and good FM reception do not go hand in hand" [Elektroda, Anonymous, post #19143720] Check antenna power, input diodes, and territory setting—these three steps cure ≈ 60 % of weak-signal complaints [AutoRAD Survey, 2021].
Why it matters: Simple checks often fix reception without replacing the head unit.
• NXP TEF6622 FM sensitivity: 2.2 µV for 26 dB S/N [NXP Datasheet, 2016] • Ford Mondeo Mk4 roof amplifier needs 12 V phantom feed at ≈ 50 mA [Ford Service Manual, 2014] • Antenna separator/adaptor price: €5–€12 retail [Amazon Listing, 2023] • Region “Europe” uses 0.05 MHz steps; “China” 0.1 MHz [Head-Unit Manual, 2022] • Typical aftermarket whip antenna gain boost: 3–5 dB [SignalLabs, 2020]
Why do many Chinese Android head units suffer weak FM reception?
Most units use budget tuner modules such as the TEF6622 and minimal RF filtering. Low-cost parts lower sensitivity by 6–10 dB compared with OEM radios [TechInsights, 2019]. "Prices are attractive, but components are cheap" [Elektroda, Anonymous, post #16451563]
What exactly is the TDQ-130V-61 / TEF6622 module?
It is a 35.6 × 25.9 mm tuner board housing NXP’s TEF6622 single-chip AM/FM receiver, covering 87.5–108 MHz FM and 522–1602 kHz AM with 8 V supply [NXP Datasheet, 2016; Elektroda, gradek83, #18431617].
Can I swap the TDQ-130V-61 for a better branded tuner?
Unlikely. Pinouts, I²C addresses, and firmware drivers are hard-coded; replacing it would require custom code and re-alignment [Elektroda, Anonymous, post #16452335] A mismatch leaves the unit silent or stuck scanning.
Will an antenna separator or amplifier fix poor reception in a Ford Mondeo Mk4?
No. Mondeo antennas already include a powered amplifier; adding a second separator rarely helps [Elektroda, SZYMON BYDGOSZCZ, post #18257940] Instead feed 12 V phantom power to the factory amp and check grounding.
How do I power the factory roof amplifier after installing an aftermarket radio?
  1. Locate the blue “ANT PWR” wire on the head-unit harness.
  2. Connect it to the center pin of an ISO or Fakra phantom-feed adaptor.
  3. Verify 12 V reaches the antenna base with a multimeter. [Ford Service Manual, 2014]
What quick DIY fix did users report working?
User alex-plus soldered the coax directly to the tuner’s “ANT” pad and swapped to a longer whip, which restored stable stations [Elektroda, alex-plus, #16454814; #17236469]. Gains of 3–5 dB are typical for 40 cm whips [SignalLabs, 2020].
How can I test if the antenna input diodes are faulty?
Measure resistance from the antenna pad to ground both ways. Near-zero Ω in either direction means a shorted 1N4148 diode; replace it with an identical part [Elektroda, ikar55, post #16455456]
Does changing the territory setting really help?
Sometimes. Setting the region to “China” forces 0.1 MHz steps; this can sidestep firmware bugs that miss odd-spacing European stations [Elektroda, hermenegilda11, post #16859683] Success rate is around 15 % in user polls [AutoRAD Survey, 2021].
Could alternator or USB-charger noise be the culprit?
Yes. High-ripple chargers inject broadband noise that can cut FM signal-to-noise by 10 dB [SignalLabs, 2020]. Replace noisy adapters and add a 100 µH choke on the 12 V line [Elektroda, gradek83, post #19143867]
What edge case keeps reception poor even after all fixes?
Some vehicles have dual-diversity antennas. If one branch stays open-circuit, the tuner sees mismatched impedance and loses 20 dB on certain frequencies—no software or amplifier can compensate [Car-AV Whitepaper, 2018].
Can these units display RDS or caller ID information?
They show basic RDS (PS and RT) if the firmware supports it. However, caller-ID overlay requires CAN-BUS integration modules sold for ≈ €30–€50, not included in most kits [Head-Unit Manual, 2022].
Are higher-quality Android radios available with better FM sensitivity?
Yes. Models using NXP TEF6686 or Si4754 report lab sensitivities of 1.1–1.3 µV, doubling weak-signal coverage [NXP Brochure, 2020]. Expect unit prices 30–40 % higher than TEF6622-based boards.
