Best Ratchet Combination Wrench Set for 1-Person Company: 6-27 Sizes, Unusual Sizes Included
12852 14
What ratcheting combination wrench set should I buy in sizes 6 to 27 mm, including the unusual sizes, without ending up with poor quality tools?
A decent choice from the thread is Proxxon or S&R, with Berner or Würth as higher-end alternatives; the KRAFT & DELE/Geko-type sets are treated as ordinary Chinese tools rather than trusted quality brands [#16670250][#16670542][#16670955] Honiton is mentioned as “not bad” and as a tested company with generally good reviews, but it is also described as Chinese-made [#16670250][#16670955] One user specifically recommends S&R because the quality is good and the price is not too high, and notes that a switch is useful in tight spaces [#16670542] Another user says Proxxon is worth considering for a higher shelf, based on positive experience with their socket set [#16670250] The thread does not identify a perfect full 6–27 mm set with all unusual sizes, but it consistently warns against buying purely by “German” marketing names and suggests buying online so the set can be returned if the quality feels poor [#16669332][#16670955]
  • Requesting quality feedback on ratcheting wrench set
    #1 16669268
  • #2 16669332
    czareqpl
    Help: 196
    Rate: 580
    Lechu1777 wrote:
    But I'm afraid that quality may be poor.
    After all, in the table the seller wrote that the quality is high :D
    "KRAFT & DELE germania" is 100% Chinese dressed in German. Just like the Swiss Witchen handbags ;)
  • #3 16670150
  • #5 16670280
  • #6 16670331
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    misiek1111 wrote:
    Without rotation switch
    With these / this type of keys it is practically unnecessary to switch the rotation to turn the other way it is enough to rotate the key 180 degrees (not in the way that the other end, just like the one mounted on the screw, i.e. what is on the top down) continue to turn only the other way around.
  • #7 16670335
  • #8 16670353
    misiek1111
    Level 37  
    Help: 325
    Rate: 1098
    wojtek1234321 wrote:
    turn the key 180 degrees
    The head is angled. In hard-to-reach places, the key can be placed only one way - what will you do then?
  • #9 16670363
  • #10 16670405
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    misiek1111 wrote:
    The head is angled.
    Well, here you are right, but in the keys of this type, the vast majority of the heads are swinging so that it makes no difference.
    And the ones you showed in the link probably have this "rotation switch". The photo is a bit weak, but something can be seen:
  • #11 16670502
    misiek1111
    Level 37  
    Help: 325
    Rate: 1098
    Yes, it's a rotation switch. I write about him because he often pokes around the nooks with such a key and in my cases it is necessary to me.
    So what key is needed? 1, 2 or 3?
    Best Ratchet Combination Wrench Set for 1-Person Company: 6-27 Sizes, Unusual Sizes Included Best Ratchet Combination Wrench Set for 1-Person Company: 6-27 Sizes, Unusual Sizes Included Best Ratchet Combination Wrench Set for 1-Person Company: 6-27 Sizes, Unusual Sizes Included
  • #12 16670542
    beta5
    Help: 12
    Rate: 38
    Hello Colleague, I propose S&R keys good quality and not too expensive keys and most importantly with a switch and this is sometimes really important because there are places that a straight-headed wrench cannot always be turned over / screws on flat surfaces in slots, while those with a swinging one they are not suitable for loosening highly sealed screws. Best regards.
  • #13 16670955
    ^ToM^
    Help: 495
    Rate: 2939
    Lechu1777 wrote:
    But I'm afraid that quality may be poor. Anyone know this company and can comment? Alternatively, a request for what to buy at a similar price?
    If something is in the name Germania, Germany, etc. it is immediately known that it is ordinary Chinese. No self-respecting German manufacturer, rather does not describe the product.
    Is the quality good? Hard to say. Chinese products should be guided by price and organoleptic evaluation. The higher the price, the better the product quality is usually.
    However, I recommend buying online, because you will be able to return the goods after viewing and trying for at least 14 days.
    Lechu1777 wrote:
    Okay, but what to buy? Here, e.g. GEKO keys, anyone know?
    Here I found a much more expensive, but larger set, but it's about the Honiton company ..
    Geko and Honiton are also Chinese. Except that Honiton is at least already a tested company and in total has good reviews. So you could buy it and have a good tool in total.
    However, with a clear conscience I can recommend you BERNER keys. I don't know how much they sell, but if you write an email, you'll find out.
    link
    We have various tools from this company and I will tell you that I can't say a bad word really well at the moment.
    Similarly, WURTH has solid tools on offer. Unfortunately, whose production it is I do not know. It is very possible that they are also Chinese, but at least higher or the highest shelf.
    Best regards!
  • #14 16670970
    abart64
    Help: 271
    Rate: 633
    beta5 wrote:
    while those with a pendulum tip are not suitable for loosening highly seized screws. Best regards.
    I wouldn't risk unscrewing the bolts at all. At first loose some solid and those with a rattle to shoot after loosening.
  • #15 16670980
    strucel
    Level 36  
    Help: 271
    Rate: 623
    Honiton had good reviews, now you can find identical branded honiton tools that can be bought as a jobi - unfortunately the quality is also the same, I bought myself so on other purchases I bought a 1/4 "honiton rattle for about PLN 30, it looked identical to the crap for PLN 10 and so it worked - from the news it had some looseness, as if poorly folded and fell after unscrewing 2 screws. I bought a castorama macalistera for PLN 20 and it works until today.
The discussion revolves around finding a high-quality ratchet combination wrench set for a small company, specifically one that includes sizes from 6 to 27, including unusual sizes. Concerns were raised about the quality of the "KRAFT & DELE" brand, which is perceived as low due to its Chinese manufacturing. Alternatives suggested include GEKO and Honiton, with Honiton receiving mixed reviews regarding quality. Proxxon was recommended for its reliability, although it may not meet the size requirements. Users emphasized the importance of having a rotation switch for ease of use and suggested brands like S&R, BERNER, and WURTH for better quality tools. The conversation highlighted the need for a complete set of flat wrenches, as many available options do not include all necessary sizes.
TL;DR: Need a full 6–27 mm ratcheting combo set for a 1‑person shop? Use a 14‑day online return as a safety net, and remember: "I can recommend BERNER keys." [Elektroda, ^ToM^, post #16670955] Why it matters: Small shops must balance price, durability, and complete sizing without costly trial-and-error.
What is a ratcheting combination wrench?
It’s a box end with a ratchet mechanism plus an open end. You can drive a fastener without lifting off. If there’s no reverse switch, you can sometimes reverse by flipping the wrench 180°, depending on access. [Elektroda, wojtek1234321, post #16670331]
Do I really need a reverse (direction) switch?
Yes, when space is tight or the head angle prevents flipping. A switch lets you change direction instantly and keeps progress in cramped spots. One user stresses comfort and necessity when probing into nooks. [Elektroda, misiek1111, post #16670250]
What if I can’t flip the wrench 180° to reverse?
Head offsets and obstructions can block flipping. In those cases, a reverse switch is essential to avoid removing and reseating the wrench repeatedly. This is a common limitation of flip‑to‑reverse use. [Elektroda, misiek1111, post #16670353]
Should I pick flex‑head or fixed‑head ratcheting wrenches?
Choose flex‑head for hard‑to‑reach areas; the hinge lets you keep engagement while clearing obstacles. Flex heads trade a bit of rigidity for access. Fixed heads feel sturdier on open runs. [Elektroda, 1726783, post #16670363]
Which sizes does a 1‑person company actually need?
Plan for a complete metric run. Users called out 11, 14, and 15 mm as everyday sizes. Aim for 6–20 mm minimum, then add up to 27 mm if your work demands it. [Elektroda, 1726783, post #16670280]
Are Honiton, Geko, or “Germania” brands worth considering?
Geko and Honiton are Chinese; Honiton is described as tested with good reviews. Beware marketing like “Germania/Germany” on budget tools. Berner and Würth are recommended as solid picks. [Elektroda, ^ToM^, post #16670955]
Is Honiton actually good?
Feedback is mixed but includes positive notes. One contributor said, “Honiton is not bad.” Treat it as competent mid‑tier and verify set contents and finish before buying. [Elektroda, misiek1111, post #16670250]
Can I use a ratcheting box end to break seized bolts?
Avoid that. First crack the fastener with a solid wrench or breaker bar, then switch to the ratchet for speed. This prevents tooth damage and slippage injuries. [Elektroda, abart64, post #16670970]
Any cautionary tales on ultra‑budget ratchets?
Yes. One user’s 1/4" ratchet that cost about PLN 30 arrived loose and failed after two screws. He replaced it with a cheaper store brand that still works. [Elektroda, strucel, post #16670980]
Quick 3‑step: how do I deal with a stuck bolt safely?
  1. Use a solid wrench or breaker bar to crack the fastener.
  2. Once it moves, switch to the ratcheting wrench for speed.
  3. Re‑check torque during reassembly with a solid tool. [Elektroda, abart64, post #16670970]
Does buying online help if the set disappoints?
Yes. One poster reminds you can return online purchases for at least 14 days. Use this window to inspect fit, play, and finish across sizes. [Elektroda, ^ToM^, post #16670955]
How does Proxxon stack up here?
A user praised a Proxxon socket set’s longevity, noting only an old handle issue. They still needed a larger spread of wrench sizes than a small Proxxon set offered. [Elektroda, 1726783, post #16670280]
What is a rotation (reverse) switch on these wrenches?
It’s a small lever on the ratcheting head that changes drive direction. It solves access issues where you cannot flip the tool due to angles or obstacles. [Elektroda, misiek1111, post #16670502]
Should I buy sets that include sockets too?
If you only need flat/combination ratcheting wrenches, skip socket bundles. One buyer deliberately avoided socket inclusions to stay focused and save budget. [Elektroda, 1726783, post #16670280]
