Cleaning During Windows Update: Normal or Failed? Discussing Unexpected Cleanup Pop-ups
xKA3IXx 76602 6
  • #1 18820357
    xKA3IXx
    Rate: 51
    While updating windows, cleaning popped up and I would like to ask if this is normal, does it mean that the update failed?
  • #3 18820366
    Pedros050
    Help: 2471
    Rate: 3926
    Rather, you wanted to write an update rollback? Yes, sometimes the updates fail or there is some bug. Always writes what after undoing the update.
  • #4 18820367
    xKA3IXx
    Rate: 51
    Windows 10. During the update from windows update and after restarting the update was positive and after getting 100% the text changed to "cleaning do not turn off the computer"
  • #6 18820379
    xKA3IXx
    Rate: 51
    No, I was doing updates normally. After doing this, nothing popped up completely and in windows update, it was also nothing.
    ITSpec. wrote:
    Yes there is something like this yesterday I noticed it on the client machine.
    MS added this in the last update of 2004.
    Everything is OK.
    Okay thanks because I was very surprised because I had never seen something like this and there was no error code after doing the update. Thanks again.
    dance251
    Help: 171
    Rate: 157
    Yes, that's the norm now. The system is cleared of remnants of temporary update files
During a Windows 10 update, users may encounter a "cleaning do not turn off the computer" message, which is a normal part of the update process. This feature was introduced in the Windows 10 update version 2004 to clear temporary update files. Although some users expressed surprise at this new behavior, it does not indicate a failed update, especially if no error codes are present after the process. The cleanup is intended to optimize system performance by removing remnants of previous updates.
