FUNAI LED32-H9223M: Standby Issue, Logo Appears, Possible Software Problem - Thoughts?
FlorinALB 1752 5
  • #1 18820841
    FlorinALB
    It starts from standby, the FUNAI logo appears and then goes into standby again. The source is verified and it is good. I think it is a software problem. What do you think?
  • #3 18821705
    yokoono51
    Help: 159
    Rate: 293
    FlorinALB wrote:
    It starts with the standby mode, the FUNAI logo appears, and then goes back to the standby mode. The software is verified and it is good. I think it's a software problem. What do you think?
    Scrie ce placa de baza are si ce cod are panelul.
  • #4 18826732
    zdzich42
    Help: 586
    Rate: 865
    Try this.
    • upgrade.pkg (6.48 MB) You must be logged in to download this attachment.
  • #5 18829884
    FlorinALB
    I tried with the software and it does the same, meaning it immediately goes into standby. I noticed that when you start on a third of the display on the right side it is darker.
    Is there a problem with the LEDs?
  • #6 18831081
    zdzich42
    Help: 586
    Rate: 865
    Well, you already know that it's not soft. You just have a fault ...
