Testing Zener Diode with Digital Meter: Step-by-Step Guide & Precautions
gen999 50011 10
How can I test a Zener diode with a digital multimeter, and what precautions should I take?
A digital multimeter in diode mode can only check that a Zener behaves like a normal diode; it cannot verify the Zener breakdown voltage. To test it properly, connect the diode in series with a resistor to a supply voltage higher than the expected Vz, choose the resistor so the specified Zener current Iz flows (for example about 5 mA for 0.5 W diodes), and measure the voltage across the diode; if it is close to the catalog Vz, the diode is good [#1897715] [#1897847] A lab power supply with adjustable voltage and current limiting makes this even easier: set the current limit to minimum and slowly raise the voltage until the voltage stops increasing at the Zener voltage [#1898284] If the diode is soldered into a circuit, desolder one lead first, because nearby parts such as electrolytic capacitors can distort the reading and make the meter show misleading results [#19180220] [#19180226] [#19180261] If the measurement is doubtful, replace the diode, since a meter test can indicate it is OK even when it is actually faulty [#1896095]
  • #1 1896070
    gen999
    Help: 23
    Rate: 32
    as the topic. I want to check such a diode with a digital meter.
    help
    Greetings
    PiotrGr
    Help: 7
    Rate: 21
    Check like a normal diode. In case of doubt, replace it with a new one, sometimes the measurement will show that the diode is ok, but in fact it was dead.
    Regards
    MirkoRTV
    Help: 8
    Rate: 66
    A colleague is right, the zener diode cannot be checked with a meter 100%, because the zener effect is used - it conducts at a certain voltage, but normally, if it is good, it behaves like a normal diode.
    Regards.
    kaputo
    Help: 37
    Rate: 128
    You can check like this. Connect the diode in series with the resistor. Apply a voltage higher than the expected zener voltage. For a given zener and supply voltage, the resistor must be selected so that the current Iz flows (from the catalog). Now it is enough to measure the voltage across the zener diode. If at the current Iz (e.g. 5mA - for 0.5W diodes) we measure more or less the catalog Vz, then the diode is good.
    MacGyver 7
    Help: 37
    Rate: 41
    For this I use a laboratory power supply with adjustable voltage and current limitation. I connect the diode to the flowing current, set the limiter to the minimum and slowly increase the voltage. At some point, the voltage stops rising, it is the zenner breakdown voltage.
    panjarek
    Rate: 12
    Please suggest me too.
    The diode is located in the audio amplifier circuit to which the power supply is NOT connected.
    I set the diode test in the multimeter.
    I put the probe in one direction, it shows me about 0.5V and in the other direction the multimeter indication increases gradually to about 2.2V.
    What does it mean? How do I interpret it?
    mariann
    Help: 551
    Rate: 649
    Desolder the diode on one side and then take the measurement.
    Greetings.
    viayner
    Help: 1563
    Rate: 2052
    the diode is soldered into the circuit so you measure the influence of adjacent elements.
    One tip should be desoldered for a reliable measurement. Maybe show the diagram.
    Regards
    panjarek
    Rate: 12
    Then it shows 0.5v in one direction and nothing in the other, but I wanted to try without desoldering because there are a lot of them.
    viayner
    Help: 1563
    Rate: 2052
    without desoldering, you have the influence of the surrounding elements, you mentioned a slow increase in voltage - you probably have an electrolytic capacitor nearby.
    The measurements show that the element behaves as a diode but does not say anything about the zener effect, this cannot be measured directly with a multimeter.
    Regards
    panjarek
    Rate: 12
    As you wrote, there was a capacitor next to it.
    I pity them all, it turned out that one was damaged.
To test a Zener diode using a digital multimeter, it is recommended to first check it like a normal diode. However, due to the Zener effect, a multimeter may not provide a definitive test. A reliable method involves connecting the Zener diode in series with a resistor and applying a voltage higher than the expected Zener voltage, ensuring the current matches the specifications from the catalog. The voltage across the Zener should then be measured; if it aligns with the catalog value at the specified current, the diode is functioning correctly. For more accurate results, especially when the diode is part of a circuit, it is advisable to desolder one end to avoid interference from adjacent components. Observations of voltage readings can indicate the diode's condition, but the Zener breakdown voltage can only be accurately determined with a controlled power supply setup.
