[Solved] Deleting & Reprogramming TPMS Sensors for Opel Astra J: Tire Pressure Reset Troubleshoot
ziooober88 62187 1
  • Need to reset TPMS sensors before reprogramming
    #1 19058381
    ziooober88
    Rate: 491
    Hello, I have an Opel Astra J. Bought last year in a showroom. In addition, I bought a second set of tires with sensors and tires at the Dealership. Last year I translated and programmed it myself and everything was ok. This year, after replacing the tires, I forgot to delete the TPMS sensors and a message pops up to me to check the tire pressure. After entering the MENU, I have this view:
    Holding down the Set/Reset button does not want to delete anything. Last year, when I held it, a message popped up if I wanted to reset it. I gave yes and the directions of the car showed which wheel to program.
    How to delete it so that these sensors can be programmed?
  • Handbrake required to enable TPMS reset
    #2 19059107
    ziooober88
    Rate: 491
    Added after 7 [hours] 12 [minutes]:
    Hello, the problem has been solved. You had to apply the handbrake and then the SET/RESET function started working.
