OPEL Astra H 2005 1.7 CDTI: ABS Light & Falling Brake Pedal Issue after Changing Front Pads
kilus4829 7815 10
Why does the ABS light come on and the brake pedal sink to the floor after replacing the front pads on an Opel Astra H, and what should I check first?
Read the ABS error codes first, because the light may be caused by an ABS fault and one reply specifically suggests checking whether the front sensor cable was damaged during pad replacement [#16848403] If the pedal slowly falls only with the engine running, inspect the brake hydraulics and how the pistons were pushed back: one reply warns that if excess fluid was forced back through the pump instead of vented normally, the pump seals may be damaged [#16848669] Another reply notes that if the discs are worn, the new pads may need their edges lightly ground so they contact the disc properly from the start [#16850387][#16853235] After bleeding, the poster reported the brakes became firm again, so the issue appears to have been resolved by the bleeding/refill procedure [#16852486]
  • #1 16848370
    kilus4829
    Hello again, I have a problem with my channel, which is the astra h 1.7 cdti from 2005.I replaced the front pads, put everything together and zonk, the abs burns and the brake pedal slowly falls into the floor when pressed, the system checked without air in the fluid full like the car is off The pedal holds the pedal in one position and does not fall when I fire it. Nothing leaks, pleats, help .. Regards
  • #2 16848403
    Doktorr
    Help: 287
    Rate: 1098
    Read ABS error codes. You probably damaged the sensor cable when replacing the pads.
  • #3 16848626
    kilus4829
    for 100% the cables are ok because I checked, the liquid does not drip anywhere, I had a similar problem with zafira a, from 2001, but I drove about 2 km and the abs light went out (I was turning the wheels on the lift, apparently the abs got lost or something like that)
  • #4 16848669
    sanfran
    Help: 963
    Rate: 3004
    This pedal goes all the way down when you hold it?
    When retracting the pistons under the new pads, the excess fluid was vented through the vent or forced in by the pump? If the latter, I bet that the pump seals are damaged.
    We will not deduce anything from ABS until the error is read.
    And decide whether you are "he" or "she" because you write yes and yes.
  • #5 16848688
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    Did you only change the pads or the fluid too? Or did you do anything else with the brakes?
  • #6 16848705
    milejow
    Help: 1563
    Rate: 5149
    Who told you such nonsense?
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #7 16849307
    kilus4829
    Ok, when pressed, the pedal does not hold and it drops gently down to the floor, the brake is braking poorly, I am there ,,, I only replaced the fluid blocks, I did not move, on the turned off engine, the pedal after pressing the brake stays in one place does not fall
  • #8 16850387
    milejow
    Help: 1563
    Rate: 5149
    kilus4829 wrote:
    I checked the system without air
    How did you sand the edges of the blocks before installing them?
    Działalność własna
  • #9 16852486
    kilus4829
    Did you sand the edges of the bricks before installing them? [/ Quote]
    So what, what edges. I vented the system on the principle, I had a little dot4 fluid, when I refilled (help from the car owner), the venting was LP, PP, LT, PT, on the off engine. km (I turned the wheels at a standstill, the mechanic said that the abs got lost) now the brakes are razor, the car is standing on end
  • #10 16853235
    milejow
    Help: 1563
    Rate: 5149
    kilus4829 wrote:
    What, what, what edges
    As the discs already have wounds, the new blocks need to be slightly grinded on the edges of the linings so that they adhere to the disc on the entire plane and brake with full effectiveness from the very beginning.
    kilus4829 wrote:
    the mechanic said that the abs is lost)
    No comment.
    Działalność własna
  • ABS light cleared after a short drive with new pads
    #11 16853318
    kilus4829
    A colleague replaced the discs a month ago, also in perfect condition without rims, now he has just bought pads (cash is known), as for the abs, I also do not know the term that the abs is lost, but okay, let me have zafira and I had the same thing that after replacing the abs pads it was on for 2km and the light went out. I am closing the topic, thanks for your interest and for help, I am giving my solution.
The discussion revolves around a 2005 OPEL Astra H 1.7 CDTI experiencing an ABS light activation and a falling brake pedal issue after replacing the front brake pads. The user reports that the brake pedal drops slowly to the floor when pressed, although it holds when the engine is off, and there are no visible leaks. Responses suggest checking ABS error codes, inspecting sensor cables, and considering potential damage to the brake pump seals. The user confirms that the brake fluid was replaced and the system was bled properly. There are mentions of similar experiences with a Zafira model, where the ABS light turned off after driving a short distance. The discussion concludes with the user indicating that the brakes are now functioning effectively after addressing the issues.
