Opel Astra J 2010, power steering - Replacement of the power steering module
london2004 14808 14
How can I fix the VIN mismatch after replacing the power steering module in an Opel Astra J 2010, and which diagnostic tool can do it?
To fix the VIN mismatch after replacing the Astra J power steering module, the module usually has to be handled as a component-protected unit: log the old component out first, then code the new EPS with SPS [#20938716][#20938814] If SPS cannot change the VIN by command, Ioterminal is the most specific option mentioned because it works directly with the EEPROM; the EPS does not use a PIN code [#20992198] Opcom and other universal testers were reported as unable to program this module or access useful measuring blocks [#16733740][#17741175] Repeated VIN-entry attempts without proper logout may block the device, so avoid trying random coding methods [#20938716]
  • #1 16728635
    london2004
    Level 19  
    Rate: 392
    After replacing the power steering module, an error entered - VIN mismatch. What steps to take and what device to deal with the problem? Rather, it is not an easy topic, I called some long boots.
  • #2 16728897
    Jamrug
    Help: 18
    Rate: 177
    Have you tried opcom?
    You will probably need a PIN.
  • #3 16729103
    3piroman666
    Help: 25
    Rate: 57
    In most modules in this car there is wine stored when you enter the module, you should have the option of changing it, adding it, from what I remember there is also an option where it gets the wine from another driver, yes the matching option, the opcom do not know if it will work, unfortunately, probably only mdi or you can try or any of the universal devices have the option to change wines in the module, e.g. autocom
  • #4 16733740
    london2004
    Level 19  
    Rate: 392
    Opcom has no programming options in this module, what's more, no measuring blocks! Universal testers also can't.
  • #5 16734355
    kisiol
    Help: 36
    Rate: 469
    From what I can see in autocom there is an option to add support and more.
  • #6 16734378
  • #7 16734672
    piotrekwoj1
    Help: 947
    Rate: 3433
    And which opcom version did you check?
  • #8 16738684
    Jamrug
    Help: 18
    Rate: 177
    If there are such problems, it can rip soft from the old one on the table and upload it to the new one. ?
  • #9 17738054
    cardiag
    Level 30  
    Help: 104
    Rate: 565
    Hello guys
    problem solved?
  • #10 17741175
    damdam
    Help: 274
    Rate: 949
    None of the devices I know do this, and no PINs give anything here.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #11 20447411
    piotr26041980
    Hello, I have this problem with VIN coding how did you do it
  • #12 20938716
    mirek-s11
    Rate: 8
    Opel has a component protection option.
    To enter a new VIN, the component should be logged out. Don`t move without it. From what I remember, entering a new VIN several times without logging out causes the device to be blocked.
  • #13 20938814
    piotrekwoj1
    Help: 947
    Rate: 3433
    I`m 99% sure that SPS will sort this out. The same principle as when replacing the blind spot sensors in the Insignia.
  • #14 20992198
    kirtreig
    Possible to try using SPS but not programming - configuration for EPS.
    But sometimes it is not possible to change VIN by command.
    EPS not uses pin code.
    So the best thing is Ioterminal cause it works direct with eeprom. But be informed VIN is written twice and every one has independent CS.
  • Trailer module output stuck on reverse and fog lights
    #15 21712225
    Pati
    Help: 35
    Rate: 409
    Hi, I have a problem after replacing the Astra J hitch module (the module also engulfs the rear lights I think). The reverse and fog lights in the trailer are on all the time. There is diagnostics for it but no errors. It does not respond to the output test. Same on the two 2nd hand modules. Anyone know if this could be a CS and what could be used to fix it. Inside the burnt module I did not see any eeprom bone because I thought maybe I would flip the contents. But unfortunately.
Discussion about replacing the Opel Astra J 2010 electric power steering module and encountering a VIN mismatch / component protection issue. Participants suggest using OP-COM, PIN access, Autocom, MDI, or SPS to reprogram or adapt the module, possibly by transferring software from the old unit or writing the VIN through EEPROM. Later replies indicate that standard diagnostic tools and PIN codes usually do not solve this problem, and that the EPS module may require SPS configuration or direct EEPROM-level work because the VIN is stored twice with separate checksums/component security.
TL;DR: Two VIN entries exist in the Astra J EPS, and “VIN is written twice and every one has independent CS.” Use SPS configuration or write both EEPROM VIN fields directly to clear “VIN mismatch.” [Elektroda, kirtreig, post #20992198]
Why it matters: This FAQ helps DIYers and workshops fix Opel Astra J (2010) EPS VIN errors after module replacement, fast and safely.
How do I fix “VIN mismatch” after replacing the Astra J EPS module?
Try this: 1) Run SPS and perform EPS configuration (not programming). 2) If VIN change by command fails, use IOterminal on-bench. 3) Write the VIN in both EEPROM locations to match the car. “VIN is written twice and every one has independent CS.” [Elektroda, kirtreig, post #20992198]
Do I need to log out component protection before coding a new VIN?
Yes. Opel’s component protection must be logged out first. Attempting to enter a new VIN without logout can block the device. Avoid repeated blind attempts. Complete the logout, then proceed with VIN entry or configuration. [Elektroda, mirek-s11, post #20938716]
Will SPS alone sort out the EPS VIN error?
Often, yes. “SPS will sort this out.” Use SPS with a compatible interface to configure the EPS after replacement. If SPS reports that VIN change is not allowed, fall back to EEPROM-level editing with a dedicated tool. [Elektroda, piotrekwoj1, post #20938814]
Does the Astra J EPS require a PIN code for coding?
No. The EPS does not use a PIN code for VIN coding. Focus on component protection, proper SPS configuration, or EEPROM editing instead of PIN retrieval. [Elektroda, kirtreig, post #20992198]
Why does VIN writing fail even when I try via diagnostics?
Because the EPS holds the VIN twice, each with its own checksum. Changing only one field leaves a mismatch. Write both VIN copies and ensure both checksums validate, or SPS configuration will still flag an error. [Elektroda, kirtreig, post #20992198]
Can OP-COM program the Astra J EPS module?
User reports show OP-COM exposes neither programming nor measuring blocks for this EPS. Do not rely on it for VIN coding. Use SPS or an EEPROM tool instead. [Elektroda, london2004, post #16733740]
Can Autocom handle EPS VIN coding or configuration?
One user notes Autocom shows an option to add EPS support. However, menu presence does not guarantee VIN write success on this platform. Validate on your hardware before committing time. [Elektroda, kisiol, post #16734355]
What happens if I enter the new VIN multiple times without logout?
The EPS can lock after several unauthorized VIN attempts. This edge case forces bench work or replacement. Always perform the official logout first to avoid blocking the device. [Elektroda, mirek-s11, post #20938716]
Is cloning the old EPS software to the replacement a valid workaround?
Yes, as a last resort. You can read the old unit on the bench and write its software or EEPROM contents into the replacement to preserve VIN and config. [Elektroda, Jamrug, post #16738684]
Do PINs or common universal testers solve this EPS VIN issue?
No. Reports indicate no device in that set completes this job via PIN, and PINs do not help here. Use SPS configuration or EEPROM access instead. [Elektroda, damdam, post #17741175]
Which tool writes the VIN directly in the EPS EEPROM?
IOterminal works directly with the EPS EEPROM. Remember to write the VIN in both locations because each has an independent checksum. [Elektroda, kirtreig, post #20992198]
Trailer hitch module: reverse and fog lights stay on—what should I check?
Verify trailer module configuration and output control, then inspect the harness for short-to-battery on reverse and fog circuits. If the original module burned, compare coding between modules and test outputs on-bench. Replace or reconfigure as needed. [Elektroda, Pati, post #21712225]
