[Solved] Huawei P20 Lite - How to transfer notes from Android to a new phone?
Piter3040 28533 7
  • #1 19105059
    Piter3040
    Help: 86
    Rate: 267
    My wife has a Huawei P20 Lite phone. The phone is a year and a half old and now she would like to sell it because she bought a new one. But how to transfer notes?
  • #2 19105065
    blahfff
    Help: 1036
    Rate: 1301
    If from Huawei to Huawei, you can create a backup using HiSuite and later restore it on another phone. If you use a phone of another brand, this is not possible - each manufacturer has its own note application, completely incompatible with others. In such a case, sometimes there is an option to export, e.g. to PDF and view it on a new phone.
  • #3 19105070
    Piter3040
    Help: 86
    Rate: 267
    Z huawei na xiaomi redmi note 8 pro
  • #4 19105144
    staś pytalski
    Help: 760
    Rate: 1437
    Try sending it via Bluetooth, or copying it and sending it to your e-mail address, and then copying it to your new phone. You can try to sync certain data with your Google account. And as mentioned above, note-taking programs are rarely interchangeable, so it is difficult to send them one-to-one.
  • #5 19105284
    Piter3040
    Help: 86
    Rate: 267
    But I didn`t find the option to copy data, send or share in the notebook.
  • #6 19105310
    staś pytalski
    Help: 760
    Rate: 1437
    There is the "copy paste" option, e.g. to e-mail.
  • #7 19105730
    blahfff
    Help: 1036
    Rate: 1301
    Install Google Keep on both phones and simply recreate the notes by copying the contents of each note to Google Keep. On the new phone, it simply appears in the same application after turning on synchronization.
  • #8 19106144
    Piter3040
    Help: 86
    Rate: 267
    My wife got tense and copied the most important notes and deleted the rest. The phone has already been restored to factory settings and is waiting for a new owner :)
To transfer notes from a Huawei P20 Lite to a new phone, users can utilize Huawei's HiSuite for backup and restoration if both devices are Huawei. For transferring notes to a different brand, such as Xiaomi, options include exporting notes to PDF, sending via Bluetooth, or emailing them. Google Keep is recommended for syncing notes across devices, allowing users to recreate notes by copying content into the app. If the original notes are no longer needed, users can delete them after transferring the important ones.
