Xiaomi Mi5 Prime - Issues with Transferring Files to Computer
martinb33 8178 8
  • #1 16673627
    martinb33
    I have a problem with my newly purchased Xiaomi Mi 5 in the Prime 3gb / 64gb version
    when I connect it to the computer with the original cable everything connects correctly, the phone has a message about the connection, I choose the options for transferring files or transferring photos. I can browse all folders in the device memory without problem, but when I select files (eg pictures) for copying and want to paste them into a folder on the computer, the message "device has stopped working" appears.
    I did not install any drivers from xiaomi because I could not find any. At the beginning, with the connection, they wrote that some drivers are installed, but it's probably Windows.
    I tried on other USB sockets.
    Can I count on your help?
  • #3 16673685
    martinb33
    So which link should I use the best?
    Excuse me, it's links to the same program.
    Thank you, he will try.
  • #4 16673692
    Foxtrott
    Help: 253
    Rate: 944
    The last link is the drivers themselves, the first 2 is the Mi PC suite, for the beginning use the drivers themselves. After connecting, use the scan for hardware changes in the device manager.
    See this topic:
    http://en.miui.com/thread-359979-1-1.html
  • #5 16673984
    martinb33
    I installed the second link of the pc suite but I do not want to connect. However, I downloaded the drivers from the third link only I do not know how to install them
  • #6 16674016
    Foxtrott
    Help: 253
    Rate: 944
    After installing pcsuite drivers you should already have on your system. Do you have win7 or 10?
    In general, in the device manager you need to find your phone and choose to update the driver and point to your folder.
  • #7 16674064
    martinb33
    Win 7. When I turn on the pc suite, I am trying to connect for a while and then a message like this appears:
    And when trying to update the drivers in the device manager, there is something like:
  • Enable MTP in MIUI developer options
    #8 16674121
    Foxtrott
    Help: 253
    Rate: 944
    Install:
    https://goo.gl/CPa5jd
    https://www.androidfilehost.com/?fid=24521665358595410
    A message from pcsuite = you probably have a different ROM than the official distribution.
    Start "development options" on your phone -> settings -> About phone-> click MIUI Version several times.
    Go to settings -> programming options -> additional settings -> USB options -> search and select MTP.
    there may be some deviations from naming because I came back to miui7
  • #9 16674244
    martinb33
    The phone is from the official Polish distribution, version: MIUI 9 Global7.8.24 Beta
    MTP is enabled in the USB settings
    What is the second link for?
    (I did not know it would be so complicated)
The discussion revolves around issues faced by a user with their Xiaomi Mi 5 Prime (3GB/64GB) when attempting to transfer files to a computer. The user successfully connects the device but encounters an error message stating "device has stopped working" when trying to copy files. Suggestions include downloading the Mi PC Suite and specific USB drivers to resolve the issue. Users recommend checking the device manager for driver updates and ensuring that the phone's USB settings are configured to MTP (Media Transfer Protocol). The user confirms they are using MIUI 9 Global and has MTP enabled, but still faces connectivity challenges.
