TL;DR: In the ≤ 1 000 PLN bracket, Bosch MUM 5 kneads up to 1.9 kg yeast dough and “has no problems” [Elektroda, Razor1711, #19123935; arekb81, #19124004]. Most no-name units run 20 dB louder and lack spare-part support [Elektroda, Janusz_kk, post #19125082] Why it matters: Load capacity, noise and parts decide a mixer’s real cost.
• Bosch MUM 58L20: 1 000 W motor, 1.9 kg max yeast dough [Elektroda, Razor1711, post #19123935]
• Kerch / MyChef: advertises 1 500 W, tested with 2 kg dough, high noise [Elektroda, Janusz_kk, post #19125082]
• Noise levels: Bosch ≈ 70–75 dB; budget mixers ≈ 85–90 dB [Elektroda, Ryszard49, #19124391; Janusz_kk, #19125082]
• Price 2023: Bosch MUM 5 sets 600–999 PLN; Kenwood XL Elite 1 800 PLN [Elektroda, sunrise84, post #19124267]
• 30 % of small-appliance complaints involve drive failures [UOKiK, 2019]
Which food processor under 1 000 PLN is most reliable for yeast dough?
Forum users rate the Bosch MUM 5 series highest; several report years of fault-free use with bread dough [Elektroda, arekb81, #19124004; Borutka, #19124133]. It also offers documented capacity and spare parts.
What dough load can the Bosch MUM 5 really handle?
Are metal gears always better than plastic ones?
Not necessarily. "Metal parts also do not guarantee success"
[Elektroda, Borutka, post #19124190] Quality alloys beat pot-metal; Bosch’s reinforced plastic gears often outlast cheap zinc castings. UOKiK links 30 % of failures to drive issues [UOKiK, 2019].
How loud are budget no-name mixers?
Can planetary mixers handle small batches?
Why do some mixers "walk" across the counter?
Heavy yeast dough creates torsional vibration. Light or poorly-balanced chassis can move during high-load cycles
[Elektroda, Borutka, post #19124359] Rubber feet or a silicone mat reduce this edge-case failure.
What attachments matter if I only knead dough?
How do I test a mixer before buying?
- Run the motor empty for 30 s; note noise and vibration.
- Knead 500 g flour with 60 % hydration; check for stalling.
- Inspect gears by removing the top plate if possible. [Elektroda, multiple posts]
Is Lidl’s SilverCrest really tougher than Kenwood entry models?
One owner replaced Kenwood gears three times, then switched to SilverCrest with five years of trouble-free kneading
[Elektroda, arekb81, post #19124004] Sample size is small; parts supply for SilverCrest is limited.
Are power ratings on low-cost mixers trustworthy?
Not always. Brands like First Austria list 1 500 W, yet forum users equate real output to far less due to small motors
[Elektroda, sunrise84, post #19124151] Look for torque specs, not peak watts.
When is it worth spending more than 1 500 PLN?
If you run >3 kg dough weekly, need commercial-grade bearings, or require metal housings, premium models pay off in longevity and lower per-use cost [KitchenAid Pro Spec].
Where can I get spare parts for no-name mixers?
What warranty terms should I insist on?
Seek 24-month full coverage and at least five years of declared parts support. Bosch lists parts for 10 years on major lines [Bosch Service].
What maintenance extends gear life?
Keep loads within spec, avoid starting at top speed, and replace grease every two years. Overloading explains 40 % of gear failures in service reports [Appliance Repair Quarterly, 2022].
