Loss of power in Renault Trafic 2.0 dCi - Error p 2263, boost value exceeded
Markoma70 54114 0
  • #1 19126257
    Markoma70
    Rate: 13
    For some time I had a problem with loss of power in Renault Trafic 2.0 dCi, the computer showed error p 2263 boost value exceeded. I searched until I finally found a broken wire under the boost pressure sensor. Replacing the cable solved the problem. Loss of power in Renault Trafic 2.0 dCi - Error p 2263, boost value exceeded
