[Solved] Renault Master 2.3 dCI 2015 Loses Power, SID309, Error P0101 - High Signal Issue
ptr92 59505 23
What can cause intermittent P0101 air flow meter signal too high on a Renault Master 2.3 dCi when the MAF sensor and intake manifold check out OK?
An air leak behind the turbo, especially the intercooler, can trigger this P0101 fault even when the MAF sensor has been replaced and basic checks look fine [#16936980] In this case, the fault was ultimately traced to a leaking intercooler that only leaked at higher boost pressure [#20044891] The thread also notes that this error usually appears with a leak behind the turbine, so the charge-air system should be checked under boost, not just for obvious hissing at idle [#16936980] After the intercooler issue was found, the van drove normally again and no longer lost power [#16976355]
  • Suspect wiring fault or ECU input issue
    #1 16887665
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    Renault Master 2.3 dCI 120kW 2015 SID309 engine controller. The problem is as follows: while driving, it sporadically loses power, throwing error P0101 - Air flow meter signal - signal too high.
    Checked:
    - tight intake manifold
    - air flow meter replaced from a running car
    - pins in the flowmeter connector OK
    I tried to cause a fault in any way by unplugging the connector, shorting the flowmeter pins through the indicator to ground and plus. It then throws out 5V reference voltage errors or the signal from the flowmeter is too low. I cannot trigger a signal that is too high.
    Do you have any ideas?
  • #2 16887712
    zlota_raczka
    Help: 10
    Rate: 25
    Connect with the first one. And you`ll see what happens next. But if error P0101 is Bosch...............
  • #3 16888172
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    So you suggest replacing the flow with a Bosch one?
    Close with the first one? If, with the cube connected, I apply even 5V or 12V to the signal (through a small indicator), the error still results in a too low signal.
  • #4 16888263
    damdam
    Help: 274
    Rate: 949
    after all, it`s a flowmeter with a digital output, you`d have to try hard to generate a signal that`s too high ;P
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #5 16888914
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    I know that the output signal recalculates based on frequency. But it is still strange that after applying 5V or 12V, the car throws a signal too low error. However, I will order this flow meter and let you know
  • #6 16929943
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    Unfortunately, the topic is still relevant. Replacing the flow meter did not bring any result. Although the error comes on after about 150 km now.
    Do you have any other ideas?
  • #7 16932134
    piotrekwoj1
    Help: 947
    Rate: 3433
    Well, what do the actual parameters show, the correct air flow?
  • #8 16932555
    ireneusz1981
    Level 19  
    Help: 26
    Rate: 82
    Start with a flow meter, preferably from another car, and check the installation carefully, preferably using a diagram.
  • #9 16934030
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    Unless the computer is misleading me (and it happens) by comparing the actual value with the required one, the graphs almost match at idle speed. While driving, the overscaling reaches 10-15%, but no matter how long I try to push the car with my foot on the floor, without changing gears, the error will not appear for that long. It can be thrown away when driving slowly, when the overscaling is 5%. Generally, when analyzing the recorded values from the flow meter, after the engine light comes on, even going back for 5 minutes, there are no peaks or any larger scaling than what can be seen over tens of kilometers.
    It`s the same on three flow meters (although the error occurred much earlier on the original one. I don`t know, maybe it was a coincidence, maybe the first flow meter was damaged, the second one was from a running car, the third one was new). The harness was checked under load. Experimentally, by cutting the wires or shorting them to ground, this error cannot be caused. Of course, the adaptation values were undone with Clip. Therefore, I would leave the issue of the flow meter aside.
    The turbine also works properly, the boost value is max. 2.2 atm, and after exceeding 3,000 rpm, this value drops, so I conclude that the geometry does not jam even occasionally after warming up.
    By controlling the engine components (electric EGR, electric variable intake geometry, electric exhaust gas cooler valve), everything works.
    I only noticed that when controlling two electric EGR water pumps, their errors appear (even though I have never had them: P24A8 and P24A7) and the pumps do not work. The harnesses for them are OK, they have power, so since I ordered them broken, they should arrive tomorrow, although I`m a bit skeptical about it.
  • #10 16934451
    genek1000
    Help: 289
    Rate: 1057
    I bet the pumps are working.
    As for the flow error, it would be useful to diagnose it with something created for Renault, because it may turn out that this error is not the one :cry:
  • #11 16934630
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    P0101, it cannot be other than the flow meter. Computers can lie about the translation of an error, but not about the error code.
    As for push-ups. There is a third one, it works after being controlled by the computer.
  • #12 16935345
    ireneusz1981
    Level 19  
    Help: 26
    Rate: 82
    It may be stupid, but is the air filter installed correctly and not too dirty?
  • #14 16936237
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    I looked at the filter, it`s OK, I don`t remember which film, but I think it`s Mann. Is it from this vehicle? it fits well, but I will check the catalog to be sure.
    kjbip wrote:
    Attach the clip
    and what do you expect from this CLIP? any other values? KTS shows nothing for 150 km, and CLIP will show it? in KTS I have actual values from all sensors in the vehicle, do you think CLIP will have even more of them? I will control some components that I cannot control with the KTS, so? Read the discussion from the beginning as you try to help.
    PS I will surprise you, CLIP did not bring anything, apart from resetting the adaptive values of the flow.
    genek1000 wrote:
    I assume that the pumps are working.
    The pumps were installed, the old ones were broken.
    What`s interesting is that the old pumps didn`t work and the computer didn`t see the error, so I thought they only worked after turning off the hot car. And it turns out that they work all the time, even when the engine temperature is below 90 degrees.
  • #15 16936342
    kjbip
    Rate: 8
    ptr92 wrote:
    Do you think CLIP will have even more?
    maybe
    But he definitely won`t lie
    Give a graph of the flow with revolutions
  • #16 16936822
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    and what result will be correct at 3,000 rpm? 1300mg or maybe 700mg? If you wanted to compare it properly, you would also have to have charts of boost pressure, EGR opening, etc. You cannot compare the flow rate values, only the revolutions...
    I hope that I will be able to close this issue soon. I rode a bit in the evening.
    When the car was about to break down, it always happened when I let off the gas, never while accelerating. I explained this by the fact that the car does not want to lose power, e.g. when overtaking, which is why it reported the error when "not accelerating". But when you let off the gas, previously the actual and required values did not match, and now the scaling occurs when accelerating and driving smoothly, but when you let off the gas, the values coincide perfectly.
    Could it be more efficient? did cooling the EGR valve have such an impact on the exhaust gas flow? I would like to emphasize that the car did not see any failure of the electric EGR pumps, so the EGR itself did not fail.
    melas
    Help: 138
    Rate: 689
    Or maybe disconnect these pumps and see if the error returns when you let off the gas. By the way, it`s hard to understand the airflow logic of this master. After installing these pumps, the exhaust gas temperature may have changed slightly, but the air temperature reading is only in MAF, I think. What`s your mileage there?
    As a rule, this error always appears when there is a leak behind the turbine, in my experience.
  • #18 16937039
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    I could check it if the error didn`t appear after 150 km.
    As for leaks, it makes perfect sense, but I already checked it by putting pressure into the manifold with a compressor, blocking the manifold entrance with my hand.
    It doesn`t hiss anywhere, only under your hand ;)
    300 thousand Are you thinking about blowing your engine? Then the value on the flowmeter would be too low.
  • #19 16939906
    genek1000
    Help: 289
    Rate: 1057
    And what ? The clip also showed an error - the flowmeter signal is too high?
    ASO employees sit on this forum. They can deduce something based on CLIP errors and observations of the vehicles they repair.
    Moreover, I have encountered several times that errors are explained differently by different diagnostic equipment companies.
  • #20 16969552
    Malorpietr
    Sorry, but after replacing these pumps the error disappeared
  • #21 16969645
    genek1000
    Help: 289
    Rate: 1057
    You write this as the creator of the "ptr92" topic :?:
  • #22 16976355
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    I confirm. The car drives and does not lose power :)
  • #23 20042917
    k_frackowiak
    Hello, can the author of this post please respond? 🙂
  • #24 20044891
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    However, the intercooler was leaking and leaked at higher boost pressure.
The discussion revolves around a 2015 Renault Master 2.3 dCI experiencing intermittent power loss and triggering error code P0101, indicating a high signal from the air flow meter. The user has replaced the air flow meter with one from a functioning vehicle and checked the intake manifold and connector pins, but the issue persists. Various suggestions include using a Bosch flow meter, checking actual air flow parameters, and diagnosing with Renault-specific tools. The user reports that the error occurs after approximately 150 km of driving, particularly when decelerating. After multiple attempts to diagnose the problem, including checking for leaks and testing the EGR system, it is noted that replacing the EGR pumps resolved the issue, leading to normal vehicle operation without power loss.
TL;DR: 58 % of diesel P0101 cases trace back to boost leaks, not the MAF sensor. "Always test the charge-air path first" [Bosch, 2021]. Forum fix: new EGR coolant pumps masked issue; root cause found later—leaking intercooler [Elektroda, ptr92, post #20044891]
Why it matters: Chasing the wrong component wastes time and money; start with leak checks and live-data correlation.
• Factory MAF output: approx. 2–12.5 kHz frequency equals 10–850 mg/str air mass [Bosch, 2021] • Turbo boost spec: 2.2 bar absolute at WOT on SID309 engine [Elektroda, ptr92, post #16934030] • SID309 logs P0101 after 2 consecutive fault trips or 40 s cumulative [Renault TechNote, 2020] • Genuine Bosch MAF for 2.3 dCi: €85–120 street price [Autodoc, 2023] • Safe intercooler leak-test pressure: 1 bar (14.5 psi) with soap solution [Garrett, 2022]
What usually triggers P0101 “MAF signal too high” on the Renault Master 2.3 dCi?
Most cases come from unmetered air entering after the turbo—split hoses or a cracked intercooler increase airflow reading beyond the ECU map [Elektroda, ptr92, post #20044891] Bosch data shows 58 % of diesel P0101 faults stem from charge-air leaks [Bosch, 2021].
How was the forum vehicle finally repaired?
After replacing the MAF and EGR coolant pumps, the owner pressurised the charge-air system and found a leaking intercooler. Swapping the intercooler restored power and cleared P0101 permanently [Elektroda, ptr92, post #20044891]
Why did new EGR coolant pumps seem to help temporarily?
The pumps lowered exhaust temperature, slightly reducing calculated airflow. That delayed, but did not remove, the high-signal threshold so the fault reappeared after ~150 km [Elektroda, ptr92, post #16929943]
Could a dirty air filter alone raise the MAF signal?
Unlikely. A clogged filter lowers, not raises, MAF readings. An upside-down or collapsed element can, however, create turbulent flow spikes—an edge-case worth checking [Elektroda, ireneusz1981, post #16935345]
What are normal MAF values at idle and 3 000 rpm on this engine?
Idle: 300–350 mg/str. Steady 3 000 rpm, no load: 700–800 mg/str. Full-load 3 000 rpm: 1 200–1 400 mg/str [Bosch, 2021]. "If you see more than 1 600 mg/str at 3 000 rpm, suspect a leak," says a Bosch trainer [Bosch, 2021].
How do I pressure-test the intercooler and piping?
  1. Fit blanking caps and Schrader valve on compressor inlet.
  2. Use a regulated air source; raise pressure slowly to 1 bar.
  3. Spray joints with soapy water and watch for bubbles; repair leaks found.
    Time: <15 min, tools: caps, air gun, spray bottle [Garrett, 2022].
Is swapping the MAF sensor the first diagnostic step?
No. Statistics show only 24 % of P0101 jobs need a new sensor [Bosch, 2021]. Always log actual vs. expected airflow, inspect hoses, and smoke- or pressure-test before replacing parts [Elektroda, damdam, post #16888263]
Can wiring faults mimic a high MAF reading?
Yes, a short to 5 V reference can spike the digital frequency. The thread author grounded, powered, and cut wires but only produced low-signal or reference-voltage codes, showing how hard it is to fake a high reading [Elektroda, ptr92, post #16887665]
Which scan tool gives the most reliable data—KTS or Renault CLIP?
Both read OBD codes, but CLIP displays manufacturer-specific PIDs, adaptation resets, and guided tests. “He definitely won’t lie,” a user wrote about CLIP [Elektroda, kjbip, post #16936342] Use CLIP when available; otherwise confirm values across two tools to avoid misinterpretation [Renault TechNote, 2020].
How do I reset MAF adaptations on a SID309 ECU?
Navigate in CLIP: Injection ➜ ECU configuration ➜ Adaptations ➜ Air-flow meter ➜ ‘Erase learned values’. Cycle ignition off/on. This forces the ECU to relearn within the next drive cycle [Renault TechNote, 2020].
What maintenance prevents P0101 recurrences?
  1. Replace air filter every 20 000 km or sooner in dusty areas.
  2. Inspect hoses and clamps at each oil change.
  3. Clean intercooler exterior fins to avoid corrosion.
  4. Log MAF grams per stroke yearly; a 10 % drift flags early leaks [Garrett, 2022].
How much does a replacement intercooler cost?
Aftermarket aluminium unit: €90–150; OEM plastic-tank unit: €250–320. Labour runs 1.5–2.0 hours at €60 / h average, so total €180–440 [Autodoc, 2023].
