Decoding error codes PO19064 and B151363 in Volvo FH 4 2017 - check engine
cimi81 57717 3
  • #1 19126415
    cimi81
    Hello, can anyone help me decode the error codes? Here they are:
    PO19064
    B151363
    I will add that the check light is on and at first the power was reduced, now the power is back and there are no symptoms, but the check light is still on
    Thank you in advance Decoding error codes PO19064 and B151363 in Volvo FH 4 2017 - check engine
    piotrek303
    Help: 58
    Rate: 296
    P019064 - pressure on the fuel rail bank 1
    B151363 - front cover lock sensor
  • #3 19268191
    janko83
    Rate: 145
    I`m joining the topic regarding Volvo FH4 2014.
    Request for tips on what and where to check for the following errors from the EMS group (in order of the largest number of occurrences):
    P02E013
    P02E09B
    P02E697
    P02E699
    From what I managed to decipher, the first two concern "Airflow control at the diesel engine inlet" and the last two "Diesel Engine Admission Regulator Position Sensor".
  • #4 19280295
    janko83
    Rate: 145
    I`m bumping this because it`s quiet here...
