Renault Clio 2 98 - Electronic Fault Indicator Light Activation at Constant Speed
kratos72 43092 3
  • Suspected fan and speedometer fault causing warning light
    #1 19171521
    kratos72
    Hello, I come with the problem of lighting up Renault Clio 2 98 - Electronic Fault Indicator Light Activation at Constant Speed .the light comes on when I am driving at a constant speed, my foot is on the gas and some 3000 thousand revolutions depend on the gear, but at a higher speed. The light does not make any impression on the car when this light is turned on, but I'm afraid that something serious is just waiting for a moment to spill out. Recently, I replaced the relay because the car went out every now and then and the problem was fixed. I cleaned all the contacts, thinking I had repaired, but not completely. From what I noticed, after reaching the parking temperature, the radiator fan does not turn on and the central one has stopped working. To this set there is a problem with the speedometer because it works once, not what surprised me, the tachometer works. Besides, the car is white when a little bit comes
    Please help, Thank you in advance.
  • #2 19171545
    Tomecek25
    Rate: 25
    Buddy, first connect to the computer, reading errors and dynamic logs. Diagnostics from the control is reading coffee grounds.
  • #3 19174600
    kratos72
    I understand, but there is now a problem with cash and I will not do it quickly and I would not like huge costs
  • #4 19428629
    Mifosz1
    Rate: 18
    I have a similar problem, did you find a solution?
