Renault Master AdBlue Module Computer Issue - No Message Displayed
jesperbhjensen1989 4176 1
  • #1 21428270
    jesperbhjensen1989
    Renault master ad blue module computer no message @ElektrodaBot
  • Power and CAN faults likely causing AdBlue no-message error
    #2 21428271
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    jesperbhjensen1989 wrote:
    Renault master ad blue modul computer no message @ElektrodaBot
    Initial Assessment of the Available Information
    Multiple sources—some offline and some online—indicate that a “no message” or “missing message” error with the Renault Master AdBlue (SCR) module can be traced to communication faults, module hardware failure, or wiring and power-supply issues. Online responses highlight specific diagnostic trouble codes (e.g., DF049, C59F87), and user experiences show that even after parts replacement, thorough diagnosis is often needed to solve the issue.
    Direct Answer to the Question
    If your Renault Master displays a “no message” or “missing message” indicator for the AdBlue dosing module, the problem typically lies in one of the following areas:
    • Power supply or ground connection to the SCR (AdBlue) module
    • CAN bus communication wiring or connectors
    • Internal failure of the AdBlue module
    • Faulty or incompatible software/firmware in the engine ECU or AdBlue module
    Detailed Problem Analysis
    Below is a systematic approach to diagnosing and resolving the issue:
    1. Check Power Supply and Fuses
    1) Locate the fuse for the AdBlue/SCR system in the vehicle’s fuse panel (consult the Renault Master service manual).
    2) Confirm the fuse is intact and verify continuity with a multimeter.
    3) Measure battery voltage at the AdBlue module connector; ensure it meets typical 12V supply requirements with proper ground.
    2. Inspect Wiring and Connections
    1) Examine connectors for the AdBlue module, NOx sensors, and AdBlue pump. Corrosion, damaged insulation, or loose pins can interrupt communication.
    2) Inspect CAN bus lines (CAN High and CAN Low) carefully from the module connector back to the central electrical system/ECU.
    3. Diagnostic Trouble Codes (DTC) and Live Data
    1) Use a professional diagnostic tool compatible with Renault systems (e.g., JalTest, Renault CLIP) to retrieve fault codes.
    2) Look for DTCs such as DF049 (“AdBlue dosing module computer no message”) or C59F87 (“Missing message from AdBlue dosing module”).
    3) Check live data for AdBlue tank level, pump status, and NOx sensor readings.
    4) If the tool cannot detect the AdBlue module, you may see a “no communication” or similar error, pointing to a module or wiring problem.
    4. Software or Firmware Issues
    1) Verify matching software versions between the engine ECU and the AdBlue module if a recent update or programming session was performed.
    2) If available, attempt a software refresh or reprogramming of the module and ECU following Renault specifications.
    5. Module Failure or Defect
    1) If all wiring checks and power measurements are correct and no communication can be established, the module itself may be defective.
    2) Replacing the module requires correct part matching (via VIN) and reprogramming or coding in alignment with the engine ECU.
    Current Information and Trends
    Based on recent discussions and forum posts (including on Elektroda.com and specialized Renault forums), similar AdBlue communication issues persist in newer model years. The remedy often involves:
    • Ensuring no external damage to sensor wiring (e.g., from salt corrosion or road debris)
    • Updating or calibrating the AdBlue control software
    • Verifying NOx sensors’ functionality, since the system can disable dosing if NOx readings are invalid
    Supporting Explanations and Details
    • The AdBlue module communicates over the vehicle’s CAN bus. If either CAN High or CAN Low lines are shorted, grounded, or open, no communication will occur.
    • The AdBlue system often stores secondary DTCs—like NOx sensor errors—that might appear to be unrelated but can shed light on why the module fails.
    • A low or unrecognized AdBlue fluid level (due to sensor faults) can also cause confusion, though typically it publishes a low-level warning.
    Interdisciplinary Connections
    Troubleshooting automotive SCR systems blends electronics engineering (signal integrity on CAN bus, module firmware) with mechanical and emissions-control knowledge (NOx sensor design, fluid injection). Engaging with both the electrical and mechanical sides helps ensure thorough diagnostics.
    Ethical and Legal Aspects
    In many regions, disabling or bypassing the AdBlue system to avoid repairs is illegal due to emissions regulations. Always ensure compliance with local environmental and regulatory standards.
    Practical Guidelines
    • Always disconnect the battery before probing or repairing wiring on the vehicle’s main harness to prevent unintended shorts or damage to sensitive electronics.
    • If replacing the AdBlue module, follow official Renault guidelines for component matching and software calibration.
    • Maintain correct AdBlue fluid quality and levels for system longevity.
    Possible Disclaimers or Additional Notes
    • Some advanced diagnostic steps (like scoping the CAN bus or reprogramming the module) require specialized tools beyond a basic OBD-II scanner.
    • If your vehicle has warranty coverage, consult authorized service to avoid complications with potential recalls or coverage denials.
    Suggestions for Further Research
    • Investigate official Renault Technical Notes or Service Bulletins regarding AdBlue module issues.
    • Explore advanced scanning capabilities: certain professional-grade tools provide deeper insight into SCR calibrations and forced resets.
    • Stay informed of any relevant safety or emissions-related recalls for your specific model year.
    Brief Summary
    A missing AdBlue module message in a Renault Master generally results from a loss of communication (fuses, wiring, connectors, CAN bus), a software mismatch, or hardware failure in the module. Systematic troubleshooting—power checks, connector inspection, diagnostic scanning, potential software updates, and verifying sensor inputs—is required to accurately pinpoint and correct the fault.
    Questions for the User
    1. Have you connected a Renault-specific diagnostic tool to retrieve any stored fault codes, and if so, which codes were found?
    2. Were there any recent updates, repairs, or part replacements done on the vehicle prior to this communication issue arising?
    3. How many kilometers/miles are on this vehicle, and do you recall any prior AdBlue-related warnings or resets being performed?
    Providing this information will help tailor a more precise troubleshooting approach. If you gather additional details or need further clarifications, feel free to update us here on the forum.
