  • Suspected servo fault beyond capacitor aging
    #1 19317144
    enryfox
    I have been given a Technics SL-P1 which does not work properly. The disc motor keeps wobbling back and forth and when I press the open/close button, the disc motor starts rotating at full speed. The display always shows 0000. If I manually open the disc tray, it detects it is open and closes it correctly. If I manually move the pick-up, it detects it is not in the centre and moves it back to the inner position.
    I'm testing the player without a disc so I would expect the following:
    1) lens starts moving up and down in search of focus (2 or 3 times)
    2) no focus found, then stop and wait.
    Some older players do start disc rotation during focus search, this might be one of those so I would expect just a couple of spin attempts and then nothing.
    What I get is instead (no disc inserted):
    1) lens just moves up & down one time.
    2) lens is moved all toward one side (tracking coil receives roughly 7 volts)
    3) spindle motor starts rotating quickly in both directions (one turn CW and one turn CCW)
    If I press eject, the spindle motor starts rotating at full speed, and it can only be stopped by removing power. It behaves the same also if the optical pick-up is completely disconnected (no photo-diodes, no laser, no coils) or if the RF pin is disconnected from main board (the RF DC voltage level is indeed correct at 1.8V). Acting on the focus offset potentiometer moves the lens up & down, but acting on the tracking offset does nothing (I have marked all potentiometers so I can go back to factory settings)
    Surely there are tired capacitors but unless one is completely short I do not think they are causing those problems.
  • #2 19357839
    michald
    Help: 210
    Rate: 437
    Is the plate positioned at the correct height in relation to the laser head?
    Have all belts in the drive been replaced with new ones?
    I would like photos of the transport, please.
    Please check and, if necessary, replace electrolytic capacitors in the servo block.
    https://www.elektroda.pl/rtvforum/topic3551619.html
  • #3 19358039
    398216 Usunięty
    Help: 3925
    Rate: 9448
    enryfox wrote:
    2) the lens is shifted completely to one side (the tracking coil receives about 7 volts)
    The driver that controls the coils to be replaced.
  • #4 19359057
    enryfox
    It was indeed dead capacitors: the RF amp was fooled into thinking the pick-up was reading RF signal (even without a disc) and the CLV servo was intermittently engaged.
    I replaced all caps in the servo board and problems disappeared, the player now works correctly and it is back to the (happy) original owner.
  • #5 19359058
    enryfox
    Replaced all caps in the servo board
