[Solved] Setting up global access to Home Assistant on Raspberry Pi via VPN with Aero2
Błękitny 3432 3
  • Clarifying VPN access and external IP setup
    #1 19329029
    Błękitny
    Rate: 17
    Hello forumers,
    I am asking for some advice and to clear up my doubts. I have Home Assistant running on my Raspberry and would like to access it globally if only from my phone. Locally everything connects correctly but I keep having problems with global access. My provider is aero2 so I guess access is blocked but I don't know because they haven't given me an answer yet, the SIM card is in the modem and the modem is in the router. However, I have come across advice which, as far as I understand it, still directs me to set up a VPN server to redirect connections there. Is there any chance here to marry these devices to each other? The external IP address I think I have is fixed but I am not sure. I've flipped through too much information on this topic today and it's all getting confused....
    gulson
    System Administrator
    Help: 150
    Rate: 6128
    Looks like your provider is blocking outside access or at your home you have NAT and no port forwarding.
    Read about VPN https://www.zerotier.com/ has good integration with Home Assistant.
    It creates its own subnet with private IPs that you can connect to without any problem.
  • #3 19333624
    Błękitny
    Rate: 17
    Hello, just after describing this problem here I came across just such a solution and theoretically I have already configured it however I had no external access, now I have had a bit of a break, if I can figure it out I will describe what and how.
