[Solved] Ryzen 5 3600 CPU Cooling: Is Box Cooler Sufficient for 3.6-4.2 GHz Boost Mode?
mati.ros 14091 12
Is the stock cooler enough for a Ryzen 5 3600 running at its default 3.6-4.2 GHz boost clocks, or should I buy an aftermarket cooler?
Yes, the stock box cooler should be sufficient for a Ryzen 5 3600 at factory boost clocks, but under heavy load it may be audible and temperatures above 70°C are quite possible during long workloads [#18830468][#18834563][#18945398] If it ends up too loud or too warm, you can always replace it later with a stronger cooler such as a Fera 3, Arctic Freezer 34, or Fortis [#18830468][#18831006] Before buying anything, also check the case airflow, because poor ventilation can make cooling ineffective regardless of the cooler used [#18831280][#18831402]
  • #1 18830444
    mati.ros
    Rate: 8
    Good morning,
    I am having trouble resolving the Ryzen 5 3600 CPU cooling issue in my new computer. Is it worth buying a cooling box for this processor, or is it going to do it? I would like to add that the processor will be clocked at 3.6 Ghz - 4.2 GHz (in boost mode), which is as stated by the manufacturer by default.
    Thanks in advance for your help!
  • #2 18830468
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    Hello. You have to judge. It is sufficient, but when loaded it will surely be heard. With a long load of temperatures above 70 degrees quite likely. If you decide that it is too loud, too warm - you can replace it, but if you already get it, you can put it on and see if it will last.
  • #3 18830987
    Facto.
    Rate: 11
    These processors don't get hot like the old ones. My 2600 with Fera 3 cooling is 28-35 degrees with normal operation. The question is what do you use the computer for, because without demanding games it won't heat up much at the moment.
    Certainly decent cooling is quieter. Better work culture. The fan does not turn it like that, but in general you have to treat the computer as a whole. You hear the loudest element. I can't hear the Fery 3 at all. But you can hear 3 fans in the housing. I can reduce the revs and then I can't hear the computer at all, but the breeze is weaker and these 3 degrees more. Not a big difference, but I don't play any demanding games.
    If you throw in a graphics card, you'll probably hear it.
    You can always buy cooling.
  • #4 18830994
    mati.ros
    Rate: 8
    The computer will be used for work but also for demanding simulation games (such as, for example, MFS 2020)
  • #5 18831006
    Facto.
    Rate: 11
    So if you want to help him, buy him a Fera 3 (105 PLN) / Arctic Freezer 34 (110 PLN) or even a Fortis (160 PLN). Even for a third party liability insurance, it should be enough. If you were already buying additional cooling, it probably doesn't make sense for the weaker ones. Some expensive ones, I also think there is no need for them. The more so if you do not plan a civil liability insurance.
  • #6 18831280
    badboy84
    Help: 1198
    Rate: 1487
    It is also worth asking yourself whether the housing is sufficiently ventilated? If the oven is made in the housing, no cooling will help.
  • #7 18831402
    Facto.
    Rate: 11
    It's a fact. I have a ventilated one - mesh front, mesh top, bottom for the power supply in the basement and in the back + 3 fans. With the fans turned off, it is a difference of 3 degrees in normal operation, but when you start heavy loading, you can see the difference.
    In addition, not only the processor heats up - the card, NVMe drives can also heat up quite strongly, so the airflow in the housing is very important.
    Blank gray image with a picture icon in the center.
    I will buy a used graphics card. More on priv
  • #8 18834208
    Marcin125
    Help: 50
    Rate: 282
    I have an AMD Ryzen 7 2700 BOX - and it is enough, you can hardly hear it.
  • #9 18834281
    ITSpec.
    Help: 937
    Rate: 741
    And what? 2700 has the Wraith Spire and 3600 has the Wraith Stealth. This comparison is pointless.
    Think and write something in return.
    Sprawny Komputer Tomasz Kokoszewski
    Patriotów 50, Warszawa, 04-912 | Company Website: https://sprawnykomputer.com.pl
  • #10 18834469
    Marcin125
    Help: 50
    Rate: 282
    BOX it is that you get cooling with the CPU. I have always used AMD and have always used the cooling provided by the manufacturer. There was NEVER a problem.
  • #11 18834508
    ITSpec.
    Help: 937
    Rate: 741
    Come on, don't you say!
    Still don't understand what I wrote?
    Should I write in print for you to embrace?
    WRAITH SPIRE IS BETTER THAN WRAITH STEALTH.
    Capable of dissipating more heat.
  • #12 18834563
    PS3251
    It's best not to buy cooling for now, just put on a box one, download e.g. cpu-z and start the most demanding game. You can check if the temperature and volume are ok. Cooling can always be purchased.
  • #13 18945398
    mati.ros
    Rate: 8
    I close the topic. The temperatures on the box cooling are normal.
The discussion revolves around the cooling capabilities of the stock cooler (Wraith Stealth) provided with the AMD Ryzen 5 3600 CPU, which operates at 3.6-4.2 GHz. Users express that while the stock cooler is generally sufficient for normal use, it may become noisy and struggle with temperatures exceeding 70 degrees Celsius under heavy load, especially during demanding tasks like simulation games. Recommendations include considering aftermarket coolers such as the Fera 3, Arctic Freezer 34, or Fortis for improved cooling performance and quieter operation. Additionally, the importance of proper case ventilation is highlighted, as inadequate airflow can lead to higher temperatures for not just the CPU but also other components like the GPU and NVMe drives. Ultimately, users suggest testing the stock cooler's performance before deciding on additional cooling solutions.
TL;DR: At stock 3.6–4.2 GHz, expect 70°C+ under sustained load; "It is sufficient" but louder when stressed. Test stock first, then upgrade if noise or temps bother you. [Elektroda, dt1, post #18830468]
Why it matters: For Ryzen 5 3600 owners deciding if the included Wraith Stealth can handle work and gaming without extra spend.
Is the Ryzen 5 3600 stock cooler enough for 3.6–4.2 GHz boost?
Yes, for default boost it works. Expect temperatures above 70°C during sustained load and noticeable fan noise. Install it first and judge in your workload. Replace later if it feels too warm or loud. "It is sufficient, but when loaded it will surely be heard." [Elektroda, dt1, post #18830468]
Will the stock cooler handle demanding games like Microsoft Flight Simulator 2020?
Yes, it can maintain stock clocks in games. Temperatures may exceed 70°C in extended sessions, and fan noise will increase. Start with the included cooler and assess thermals and acoustics in your game. Upgrade only if the noise profile or temperatures are unacceptable to you. [Elektroda, dt1, post #18830468]
How loud is the Wraith Stealth when the CPU is loaded?
Under load it becomes clearly audible. With longer, heavier workloads, temperatures above 70°C are likely, and the fan ramps. "It is sufficient, but when loaded it will surely be heard." If you want a quieter experience, consider a budget tower cooler. [Elektroda, dt1, post #18830468]
Will an aftermarket cooler make my PC quieter?
Yes. "Certainly decent cooling is quieter." Example: a Ryzen 5 2600 with Fera 3 runs about 28–35°C in normal use. The loudest component dominates system noise. Slowing case fans can make the PC near-silent, at the cost of roughly 3°C higher temperatures. [Elektroda, Facto., post #18830987]
Which budget tower coolers should I consider for the 3600?
Solid, affordable picks mentioned include SilentiumPC Fera 3 (~105 PLN), Arctic Freezer 34 (~110 PLN), and Fortis (~160 PLN). These are sufficient for stock operation. High-end coolers are unnecessary if you do not plan to overclock. [Elektroda, Facto., post #18831006]
How important is case airflow for CPU and NVMe temperatures?
Very important. Turning off case fans increased CPU temperature by about 3°C in normal use, and the gap grows under heavy load. GPUs and NVMe drives also add heat, so case airflow affects the entire system. "The airflow in the housing is very important." [Elektroda, Facto., post #18831402]
Is the 3600s Wraith Stealth the same as the 2700s box cooler?
No. The Ryzen 7 2700 ships with Wraith Spire, which is stronger than the 3600’s Wraith Stealth. As one expert put it, the Spire is "better than Wraith Stealth" and dissipates more heat, so direct comparisons are misleading. [Elektroda, ITSpec., post #18834508]
What quick test should I run before buying a cooler?
Try this 3‑step check:
  1. Install the stock cooler and assemble your system.
  2. Run CPU‑Z and your most demanding game to load the CPU.
  3. Note temperatures and noise; decide if they meet your needs. You can always add cooling later. [Elektroda, PS3251, post #18834563]
Is ~70b0C safe for a Ryzen 5 3600 under load?
Yes. AMD lists a maximum operating temperature of 95°C for the Ryzen 5 3600. A sustained load around 70°C remains within safe limits for daily use. Ensure proper case airflow to avoid unnecessary thermal stress and noise. ["AMD Ryzen 5 3600 Specifications"]
Do Ryzen 3000 CPUs run cooler than older chips?
Users report lighter thermal behavior in everyday tasks compared to older generations. One owner noted, "These processors don't get hot like the old ones." Your mileage varies with workload, case airflow, and cooler choice. [Elektroda, Facto., post #18830987]
Can I just stick with the stock cooler long-term?
Yes, if temperatures and noise meet your expectations. The original poster closed the thread confirming "temperatures on the box cooling are normal." If you want lower noise or headroom, upgrade later. [Elektroda, mati.ros, post #18945398]
Will adding a graphics card change my cooling priorities?
A discrete GPU adds heat and fan noise, often becoming the loudest part under load. Balance CPU cooling with case airflow so GPU and NVMe drives also get fresh air. If silence is a goal, tune case fan curves after installing the GPU. [Elektroda, Facto., post #18830987]
What if my case traps heat even after a cooler upgrade?
Fix airflow first. If the case acts like an oven, no CPU cooler will solve high temperatures. Add intake and exhaust paths, remove obstructions, and avoid sealed fronts. As stated: "If the oven is made in the housing, no cooling will help." [Elektroda, badboy84, post #18831280]
