What cooling for the i5-7600K processor?
kurczak737 3354 4
  • #1 16204120
    kurczak737
    As in the subject, do you have any suggestions for good cooling for this processor?
  • #2 16204123
    atomic99
    Help: 171
    Rate: 338
    What budget
    What is your motherboard, RAM and case? ?
  • #3 16204135
    kurczak737
    Computer case: ATX TRACER K2
    Motherboard: MSI Z270-A PRO s1151 Z270
    Memory: Corsair DDR4 Vengeance LPX 16GB / 2400 (2 * 8GB) CL16 BLACK
    The point is to make it good and possibly turn it up a bit in the future. Maybe up to 250 PLN.
  • #4 16204146
    atomic99
    Help: 171
    Rate: 338
    The memories from what I saw on Google are low, so you should be able to mount the cooling without problems [SilentiumPC Grandis 2 XE1436] - price around 190 PLN
    Only what I do not know if this housing will enter this cooling which is 159mm high, because on the Tracer website there is no information what height the cooling will enter.
  • #5 16204177
    kurczak737
    I will take a chance and order it, so dry now I have measured it, it comes out that there is approx. 165 mm of looseness. So when the board enters, it can fit on the contact. Thanks for the help. Greetings.
