BAIRD TI4909DLEDDS Stuck in Burn-In Mode: Need Solution & EEPROM Dump - T.MS3463S.U851 PCB
Bestgear 1695 1
  • Need factory menu access to exit burn-in mode
    #1 19530384
    Bestgear
    Guys
    I have a BAIRD TI4909DLEDDS and it is stuck in burn-in mode.
    I have tried the common menu 1147 and it does not go into the factory menu, so cannot initialise the set.
    Any ideas as to exiting burn-in? I don't have a copy of the eeprom to burn, and cannot find any service manual.
    The PCB is a T.MS3463S.U851 which appears to be used in Cello, Sharp and Akai TVs too - but little information to be found. Panel is LSC490FN03.
    Any help, including a dump of the eeprom, would be very much welcome.
    David
  • #2 19576424
    querij
    Help: 42
    Rate: 228
    Try to press the on/off button on the device for a few seconds
