Access to the NAS from the outside without a public IP
noel200 11973 49
How can I securely access my NAS photos from my phone from outside the home network if my ISP does not give me a public IP address?
Without a public IP, you cannot run your own home VPN server in the normal way, so the practical options are to buy a public IP, rent a VPS/VPN proxy, or use a service like ZeroTier [#19560572][#19570405] If you do get a real public IP, the clean solution is to enable the VPN server on the ASUS router, use DDNS if the address changes, connect from Android with a VPN client, and then reach the NAS by its local LAN IP instead of the DDNS address [#19570231][#19570276][#19572466] If you want to avoid paying for a public IP, ZeroTier was recommended as the simplest working alternative even without one, but it has to be installed on each device you want to access [#19566091][#19570210] The port-forwarding approach only works if the ISP allows the port and you forward the exact service port; using uncommon ports is safer than exposing standard ones like 80 or 443 [#19560572]
  • #31 19570276
  • #32 19570327
    voxck
    Really. Colleague @Erbit wrote well. The principle of operation of Zerotier is slightly different than I wrote earlier. I had time to delve deeper into the description of the service. Sorry for spreading misinformation.
  • Zerotier uses external servers only for setup
    #33 19570334
    noel200
    Help: 36
    Rate: 815
    I've read now and apparently the external server is only used to set up the connection, and then everything goes p2p.
    Well, but some external apps and servers are always an additional leak point.
  • #34 19570341
    voxck
    Even apart from the technical side, it is a very useful service. This is how I have a PLEX issued for my family. I don't really feel like opening ports so in this case Zerotier works great.
  • ZeroTier needs an intermediary server without public IPs
    #35 19570405
  • Master server required for NAT traversal
    #36 19570419
    voxck
    Erbit wrote:
    So that it's not that I'm so "bad" I will add that this is a very good solution, especially when there is no public IP . It is simply impossible to run your own VPN server without a public IP and then the connection must be initiated "from the inside of the network".
    It's not about 'bad' or 'good' :) . A master server is needed to establish a connection. Hosts don't initiate connection directly with each other (as I thought before) and you were right of course here, because you need a server between them.
    And the service itself is great. I've been using it for a long time and it works really great. Particularly useful, for example, when you want to put even Pihole outside the LAN and have Internet filtering outside the house (and in combination with unbound DNS) it works very well. And that's without opening ports on the router.
  • ZeroTier useful for LAN access without port forwarding
    #37 19570424
  • VPN connected but NAS still unreachable
    #38 19572288
    noel200
    Help: 36
    Rate: 815
    I just tried setting up a VPN. On the router, in the VPN server tab, there are PPTP and OPENVPN. First, I set up PPTP. On the phone with Android 10 and the MIUI 12 overlay, I set a new VPN profile. I selected PPTP there, entered the user and password as on the router. I also gave the server address, i.e. my IP from dyndns. PPP (MPPE) encryption is also set on the phone. I turned it on and it showed that it was connected. The router also shows that there is a connection.
    I have disabled port forwarding on the NAS and from a phone with WiFi disabled, I cannot access the NAS service pages. Doesn't work :( Maybe you need to enter something else in the browser? another port? Or in the router some redirection to this VPN?
    I also tried on the OpenVPN router. I set the user and pass, exported the .ovpn file. I installed the OpenVPN connect app on the phone, loaded this file, gave the user and pass and the effect is the same. What can I be doing wrong? There is no IPSec on this firmware in Asus.
    Check NAS access by local IP address
    #39 19572294
  • Clarifying OpenVPN access mode and NAT address
    #40 19572316
    noel200
    Help: 36
    Rate: 815
    Erbit wrote:
    What IP did you get after logging in?
    Using PPTP on the whatismyip site I have the same address as the router and PC connected at home. But this is not the address I got from the ISP. As I wrote earlier, they still have some NAT redirects? the address shows 109.231.7.x, but from the ISP I have a permanent address 10.9.209.x.dyndns.xxxx.pl.
    Is that why it doesn't work?
    Erbit wrote:
    What's your NAT address?
    This question is probably related to the first one, and I hope I answered above, but I don't know that much.
    Erbit wrote:
    When configuring the OpenVPN server, what did you choose?
    Code: Client will use to access:
    - local only
    - internet + local
    "both"
    Private WAN address likely blocks NAS access
    #41 19572328
  • DDNS WAN IP setting change did not help
    #42 19572350
    noel200
    Help: 36
    Rate: 815
    Erbit wrote:
    When logging in to the NAS, do you use its IP or domain name?
    Remotely, when I enter NAS services, I enter 10.9.209.x.dyndns....:xxx on the phone, and I have port forwarding enabled on the router.
    I guess I'm left with the zerotier. I read, I registered, I have a network id, I installed it on the phone. He did on the VPN phone and connected to the remote server. But I don't know how to install it on OMV.
    Probably via docker, but I have no idea what to type there. With the rest, if the service fails in a month or two, it will be a pile.
    Or maybe WinSCP?
    zerotier is one option, others can be use a VPN, or most simple, use WinSCP to access from outside of your LAN to your data
    (quoted from the openmediavault forum.)
    But isn't that Putty? to SSH?
    Added after 25 [minutes]:
    In the DDNS tab on the router, I changed the "Method to retrieve WAN IP" option from external to internal but it did not help.
  • #44 19572479
    noel200
    Help: 36
    Rate: 815
    Erbit wrote:
    You must use a local NAS address. A VPN "has taken you inside the network".
    It actually works :) But terribly slow :(
  • #45 19572499
  • #46 19572503
    noel200
    Help: 36
    Rate: 815
    Erbit wrote:
    Slower than ddns and redirection?
    Definitely slower. The emba page has not yet loaded.
    Erbit wrote:
    Maybe set PPTP server and check then.
    I've just done that.
  • #47 19574015
  • #48 19575934
    noel200
    Help: 36
    Rate: 815
    Erbit wrote:
    Do you also use IP or domain while connected to WiFi?
    If I have VPN enabled on my phone, it's from IP.
    Now I checked and it works faster. Movies in 4k@60fps take a long time to load, but photos of 10MB on average take 1-2s to load.
    So it's probably as good as it can be.
    Thank you for your help. I'm not closing the issue. I will probably still have some questions and problems.
  • #49 19575939
  • #50 19575950
    noel200
    Help: 36
    Rate: 815
    Erbit wrote:
    I want to know if you are using IP when you are connected to WiFi.
    Yes. If I understood the question correctly.
Accessing a NAS (Network Attached Storage) device externally without a public IP can be achieved through various methods. Users discussed the necessity of a public IP or alternatives like Dynamic DNS (DDNS) to maintain consistent access. The conversation highlighted the importance of configuring a VPN server on the router (specifically Asus routers with AsusWRT) to securely connect to the NAS. Users shared experiences with different VPN protocols, including PPTP and OpenVPN, and emphasized the need for port forwarding to access NAS services. Additionally, Zerotier was suggested as a viable solution for users without a public IP, allowing for easy configuration and direct device access. The discussion also touched on upload speeds and potential performance issues when accessing media files remotely.
TL;DR: 50 Mbps upload and a PLN 5 / month public-IP fee give "so very decent" remote NAS access once you add VPN + DDNS [Elektroda, IC_Current, post #19542520] Secure setup: enable router VPN, use local LAN IPs, avoid port 80 scanning.
Why it matters: Fewer open ports mean fewer attack vectors while keeping photos and 4 K video reachable anywhere.
• Public dynamic IP: PLN 5 / month from KOBA ISP [Elektroda, noel200, post #19542501] • Real upload: 50 Mbps ≈ 5.2 MB/s usable throughput [Elektroda, KOCUREK1970, post #19542630] • AsusWRT ships with PPTP & OpenVPN server tabs [Elektroda, noel200, post #19572288] • Free DDNS issued by ISP maps changing IP to hostname [Elektroda, noel200, post #19556637] • ZeroTier works behind CG-NAT but relays via master server [Elektroda, voxck, post #19570327]
Do I need a public IP to reach my home NAS?
Yes, for direct VPN hosting you need one public IP on the router WAN. Without it you must use relay services like ZeroTier or pay for VPS hosting [Elektroda, IC_Current, post #19542429]
Static vs. dynamic public IP—does it matter?
Dynamic works if you pair it with a DDNS client, but frequent changes break sessions. A true static address removes that risk [Elektroda, KOCUREK1970, post #19542478]
What is the safest way to expose NAS data?
Run the VPN server on the router, keep NAS on the LAN, then connect from phone through the tunnel. No NAS ports stay open to the internet [Elektroda, Anonymous, post #19570262]
How do I enable VPN on AsusWRT in 3 steps?
  1. Open VPN Server tab, pick OpenVPN. 2. Generate keys, set "Internet + Local" access, export .ovpn file. 3. Import file into OpenVPN Connect on phone, enter credentials, connect [Elektroda, noel200, post #19572288]
Can I skip port forwarding once VPN works?
Yes. After VPN connects, use the NAS’s local IP (e.g., 192.168.1.x). Forwarded ports become unnecessary and can be closed [Elektroda, Anonymous, post #19572466]
Why avoid ports 80 and 443?
Shodan lists over 4.1 million devices answering on port 80; automated scanners probe it constantly [Shodan, 2023]. Moving services to high ports reduces noise and log spam [Elektroda, takijasiu, post #19560572]
What if my ISP blocks uncommon ports?
Remap the NAS’s internal port to an allowed external port (e.g., 8080→80). Test accessibility after each change [Elektroda, takijasiu, post #19560572]
Can ZeroTier replace a public IP?
Yes. Install the client on every device; traffic routes through a relay until a peer-to-peer path forms. A master server still mediates setup [Elektroda, voxck, post #19570327]
Why is my VPN session slow?
Encrypted tunnels add 10-15 % overhead. Double-NAT or CG-NAT can add latency. 4 K@60 fps video may buffer on 50 Mbps upstream [Elektroda, noel200, post #19572479]
Edge case: ‘public’ IP shows 10.x.x.x—what’s wrong?
10.x.x.x is private; you are behind carrier NAT. VPN may connect yet external services stay unreachable [Elektroda, noel200, post #19556637]
Which mobile apps work with OpenMediaVault?
OpenVPN Connect, Solid Explorer (WebDAV), and official Plex/Jellyfin apps all access OMV shares once VPN is live [Elektroda, noel200, post #19564690]
What happens if the relay service goes offline?
Clients lose the overlay network, blocking access until servers return. Keep local VPN credentials as a fallback [Elektroda, Anonymous, post #19570405]
