Stag 300 - Sound signal 3 - Sound signal STAG short 3 times 3 times 3 times
Franklin_ 70026 6
  • #1 17250816
    Franklin_
    Hello, a problem like in the title:
    STAG sound (short pi pi pi) 3 times 3 times 3 times
    The car does not switch to gas
    AG P-250 reducer
    Controller - Stag 300
    When connecting the diagnostic cable, I get "Driver error"
    AcGasSynchro v1.14.1.0 to STAG-200, STAG-300 program
    I tried AcGasSynchro-11.2.0.8.exe - the program v.1.xxx was asking
    I checked the filter at the reducer, I released the gas, the car went on gas the second time, later the same alarm, the ignition blinks, the car burns on gasoline, after firing three times five and five times, again 3 times.
    Please help
  • #2 17251140
    kowal5
    Help: 25
    Rate: 69
    Do you get this error in the "Errors" tab? There is no such error in the STAG instruction. Check whether any of the injectors have unplugged the plug. And it's even better if you put in screenshots of what the configuration program shows you.
  • #3 17251345
    helmud7543
    Help: 1216
    Rate: 1564
    I understand that you do not connect to the driver, how is this error?
    As for the fault itself - without connecting and checking errors will be hard. You can check if the power supply to the switchboard is stable, the map sensor is replaced, the reducer is replaced, and there are many other options. You also see that there is not much sense in the dark.
  • #4 17252860
    Franklin_
    The topic was solved - I replaced the PS-01 pressure sensor.
    Thanks for the help
  • #5 17310688
    Nowotczyński
    Help: 5
    Rate: 12
    That's good, but for the future download old software from the AC website version ACsynch 1.14
  • #6 17311028
    Franklin_
    He also did not want to work, he wrote that no driver was found.
    After a while this problem reappeared. I think the problem is in the old reducer, because it starts to alarm as I give gas uphill, no gas pressure in the installation. If you don't know, you can start it by force: press the gas button and start the car (the car will still take gasoline).
  • #7 17311364
    Nowotczyński
    Help: 5
    Rate: 12
    If it switches when stepping on, it is rather a reducer. Are you choosing ports in the program?
The discussion revolves around a recurring issue with a STAG 300 gas controller, where the vehicle emits a sound signal (short pi pi pi) three times and fails to switch to gas. The user experiences a "Driver error" when connecting the diagnostic cable and has attempted various software versions for troubleshooting. Responses suggest checking for unplugged injectors, ensuring stable power supply, and replacing components like the pressure sensor and reducer. The user ultimately resolves the issue by replacing the PS-01 pressure sensor, although further problems with the reducer are noted, particularly under load conditions.
